Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 07-15-2008, 04:39 PM   #85 (permalink)
Gear Head / Electrician
speed185187's Avatar
I'm waiting for the home water filter setup to come in the snail mail. It's a 3 stage 20-10-1 micron. I got several old computer hard drive magnets that i'm going to use to pull metal particles out.
Whole House Water Filter Sediment Carbon Drinking - eBay (item 310066078279 end time Jul-13-08 10:30:08 PDT)
2000 2500 2wd 356HP 726TQ
(BHAF, Boost, EGT, FP Gauges, Breather bottle delete, Fass 150/150, Fireball 150's, Phat Shaft 62, Some Billet Trans Parts by TRE, XZT+, 4" exhaust, 2" Level, 315/75-16)
03 Jetta TDI 5 spd "Click here for TDICLUB Profile" 903 Miles on 15.03 Gallons.
speed185187 is offline
Old 07-15-2008, 05:42 PM   #86 (permalink)
HELP FIGHT CA SMOG REGS!
dezl's Avatar
a guy I know used it and everytime he thought it was right he would dump it in the truck and within minutes it would clog up his injectors and the truck would fart out. I say no way!
08 Chevy LMM 6" lift 20" monsters w/35's, other than that all stock.
69 Chevelle, BB 427, Ported and polished heads, Custom cam, 10.5/1 compression, Forged TRW pistons, 1.7 Roller rockers, Holley 750 double pumper, Stage 2 TH 400, 12 bolt rear end
dezl is offline
Old 07-15-2008, 08:55 PM   #87 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Originally Posted by dieselfurry View Post
Throw a few magnets in your fuel pump/dispenser filter that goes into your truck and you will be amazed on how much metal it will pull out that oil.......
And how about all the metals that are not magnetic? Like how about aluminum, brass, etc...
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
Mopar1973Man is offline
Old 07-16-2008, 12:01 AM   #88 (permalink)
One of the nice things about WVO or Bio is they hardly ever add lots of metal particles to it,at least not at the greasy spoons I frequent
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods
Challenger is online now
Old 07-16-2008, 12:22 AM   #89 (permalink)
The biggest contributing element in all the oil analyst that's I've seen so far is iron.
Old 07-16-2008, 12:39 AM   #90 (permalink)
lake huron cummins's Avatar
My buddy just ran 600 miles from Michigan to Mrytle Beach, on one tank, burning used trans fluid in his 03 with no issues. There was about 30 gallons of trans fluid and the rest was diesel fuel. He filtered it using a Culligan 3 micron water filter. The only difference was it smoked a little bit more than normal. BTW, the truck is bone stock.
99 2500 q/c 4x4, 4" Silverline exhaust, Edge Comp Hot Unlock, 150hp sticks, HTT 62/71/13, 150 GPH FASS, Suncoast triple disc tc & vb, Mag-Hytec dbl deep pan, AFE Stage 2, 06 17" w/265 Nitto Terra Grapplers, A-Meter Ultra Lite pyro, boost, trans gauge.
lake huron cummins is offline
Old 07-16-2008, 09:40 PM   #91 (permalink)
ISX
ISX's Avatar
Well I got to thinking a little bit more about doing it on the dodge and was wondering if anyone knew if it would be possible to just put an orifice thing on the fuel line, fill the regular tank with diesel and a 55 gal drum with the filtered oil and have the orifice do all the mixing work..?? Would really be nice to have a variable one in the winter, have it turned down to 5% oil or something.. BUT, would the viscosity difference mess the orifice all up? I am not sure if viscosity matters with orifices or not, never really played with them, but it seems like it would be an issue to me, anyone know for sure?
1990 F250 7.3 IDI NA auto 4x4 250k
1997 2500 12V Cummins 5spd 2wd 311k miles #100 plate, SB Con O, 26.6MPG-55mph
ISX is offline
Old 07-17-2008, 08:09 AM   #92 (permalink)
ISX, the only way an orfice works at metering is if your pressure, density, viscosity are static. That's how you determine the size of orfice needed to allow X amount of flow with Y pressure while using Z fluid. Anytime you change one, the flow through the orfice will also change.
The setup i'm working on is a 60' ish gallon truck bed tool box that i'm sealing up and making an aux tank. The clean filtered WMO is going to be pumped into this tank with a 1" drain on the drivers side under the bed. Put a 5 Gallon can under the drain, open ball valve, fill up. Then dump that into the tank via the Fuel filler.
My original plan was to put a pump on the WMO aux tank through a metering device, however all the metering devices start out at $99.99. I'm not going to spend $100 on a device that i can do the same thing with a 5 gallon bucket. I only fill up about once a week anyway. It allows me the same control at metering/mixing the ratio of WMO/D2.
Old 07-17-2008, 08:57 AM   #93 (permalink)
ISX
ISX's Avatar
I thought that was how it worked, but wasn't sure.. I guess I'll stick with the buckets..
ISX is offline
Old 07-20-2008, 01:58 PM   #94 (permalink)
e-rok's Avatar
anyone know if a charcoal filter will take out the ash and stuff in the oil? and I think im gonna get a series of magnets and let thim sit in the oil for a while and take out all the metal particles. hell after all that it should be like new oil lol
1995 3500 DRW Ext. Cab 2wd
e-rok is offline
Old 07-20-2008, 02:12 PM   #95 (permalink)
I actually attached the magnets to the side of the filter assembly on all three stages. If the particles are too far away from the magnet, it won't be attracted by the magnetic flux lines.
Old 07-20-2008, 03:23 PM   #96 (permalink)
How about all the other metals in the oil that are NOT MAGNETIC!!!
Brass, aluminum, copper, lead, tin, nickle, zinc, etc... How do you plan on removing those metals??? This is what they call ASH!
Now how do you plan on removing all the soot out of the oil too???
