| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#73 (permalink) | |
Gear Head / Electrician
![]() Join Date: Jun 2008
I'm about half way done with the setup. I got a supply of used oil from an auto shop, more than i'll be able to use. Steel drums, assortment of pipe. I just have to put it together this weekend. I'll be picking up about 40 gallons of oil today to start. Also have a steady supply of WVO from a local McDonalds. Already have half of a BioDiesel Reactor set up. I'll be burning that in my VW. Will post pics this weekend too of my setup
2000 2500 2wd 356HP 726TQ (BHAF, Boost, EGT, FP Gauges, Breather bottle delete, Fass 150/150, Fireball 150's, Phat Shaft 62, Some Billet Trans Parts by TRE, XZT+, 4" exhaust, 2" Level, 315/75-16) 03 Jetta TDI 5 spd "Click here for TDICLUB Profile" 903 Miles on 15.03 Gallons. |
#74 (permalink) | |
Here's one for you. If you use synthetic motor oil, and you go through all the hassle of "Sub Micron Filtering", why not just dump it back into the crankcase and reuse it as a lubricant. Once you remove the abrasive particles, synthetic oil would be nearly good as new.... This past Saturday I was in tears at the local dump as I poured out 40 gal of WMO from my various vehicles. The town uses it to heat the DPW truck barn. I was saving it for my truck, but I just couldn't bring myself to dumping it into the fuel. If it wasn't a 3rd gen truck, I would have used it. |
#75 (permalink) | |
That's a good idea but the only issue is the additive package has been depleted. But adding Lucas oil stablizer can bring it back up. MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2 |
#76 (permalink) | |
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods |
#77 (permalink) |
ok well I ran a little test batch since I had about 5 gallons of WMO laying around like 1/4 of a tank of diesel on my truck. Im still waiting for funds for a transfer pump and inline filter so it was just filtered thru a 1 micron filterbag. Took about a day to make it thru the system but once it did I immediately noticed the horrid exhaust smell lol. not like I care, im not driving behind myself. anyways its too early to determine MPG increase but I did notice that the buzzing/load kind of feeling I used to get when shifting into 4th (hard to explain but maybe others know what im talking about), from the lower RPMs from the low 4th grear Im assuming, anyways that feeling and sound decreased drastically. engine definately runs smoother. I also just got a job at a resturant so I might have access to lots of WVO so I'm not sure which I will stick to.
1995 3500 DRW Ext. Cab 2wd |
#78 (permalink) |
i start with filtering the WMO to 1 mic, then heated tank+inline heaters. Is everyone ready for it... drum roll please: 100% WMO. I'm now creeping up on 10,000 miles and still waiting for any slight sign of the motor running poorly, much less IP failure or injector failure. Truck is still running much smoother, w/ more power, and better milage. I've heard water/meth helps w/ the carbon buildup. I went through fuel filters like mad running unheated, 50% mix of WMO, but since the heaters i haven't pluged up the current fuel filter. Im going to bump the timing up a bit more in the next few weeks, i think oil would be more tolerent of farther advance in timing due to the lower cetane number. But by all means people, be careful not to experiment with running any kind of oil, it could be bad, just leave it all for me
'94,2500 4X4, 5 sp, everything but... the stock turbo, still my anchor. peelout |
#80 (permalink) |
I ran WMO in my F250.. Filtered it down to 5 micron through a filter bag and dumped it in 50/50 mix. The only problem I see is starting, which heaters should solve, I never used one and if it was cold enough in the morning it wouldn't start or would start like crap, as if it already didn't start like crap on diesel... One thing I did notice though, was that on diesel I had to use the glow plugs to get it to start within a couple cranks if it sat for over half an hour, with the WMO mixed in, I could start it within, o say, 4 hours of turning it off last without the glow plugs.. might not sound impressive but my 7.3 has no compression or anything so I thought it was amazing.. And also, my mileage went through the roof.. I have no way of really knowing how many MPG's I gained since I had crude ways of doing everything, but I could get a rough average, and it gained at least 3 mpg.. (I actually picked up 8mpg but I am going to say at least 3 since I am a little unsure of how much I exactly added and the fact that an 8mpg increase from a POS seems bogus.. I was talking to people at work though who used it in a 1st gen cummins and they had a substantial increase in mileage as well. From what I have read, WMO contains 140k BTU's whereas ULSD is around 132-129k (thanks to all this extensive filtration, LSD is above 135k..) gasoline is 125k, so we are almost down to gasoline levels, which shows why WMO gives such an increase in mileage.. I am going to put some in the dodge since it actually has compression and gets over 20mpg no matter what I do, so I hope to see 30 driving it 65mph.. On the carbon and ash thing, if biodiesel is such a solvent, will B20 clean all that up, or does it just clean up the fuel system?
1990 F250 7.3 IDI NA auto 4x4 250k 1997 2500 12V Cummins 5spd 2wd 311k miles #100 plate, SB Con O, 26.6MPG-55mph |
#81 (permalink) |
I believe motor oil has a BTU rating of around 156k. So its about 22k more BTU's than ULSD per gallon. MikeyB
#82 (permalink) |
ive heard 153,200. It probably depends on the weight of the oil. In any case its definatly more than #2 and ULSD
#83 (permalink) |
www.myspace.com/jaredmtfd
I like the toilet paper filtering idea. Sounds cheap and effective. Where can you buy a 1 or 2 micron filter setup?
Truck: 2001 Ram 2500. Quadcab, Longbed, 4x4, HO, NV5600 6-Speed Mods: Leveling Kit, Southbend Clutch, 5" Straight Exhaust, BHAF w/Outerwears and custom heatshield, 40hp Injectors, 70hp Timing Program in Computer, Quadzilla 120HP Xzillaraider, Vulcan Big-Line Fuel kit w/Holley Blue pump, Dipricol FP, Pyro, Boost Gauges Extras: XM Radio, VHF Mobile Radio, Strobe/LED Emergency Lighting, Security System: Ruger P95 9MM in door pocket. WWW.FARMBOYSDIESEL.COM |
#84 (permalink) |
Throw a few magnets in your fuel pump/dispenser filter that goes into your truck and you will be amazed on how much metal it will pull out that oil.......
Fore Sale: 01 5sp pulse/adrenaline, airdog 150,valair, 150's FBD,super b special (maybe),leveled.Projects: Code Green & Silver Bullet 6/26/09 NEW truck 02 4x4 auto edge drag comp,air dog 150 bout to but the super b special on it... |
