| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#49 (permalink) |
Double post
01 QC, tow package, 4X4, Edge EZ, 4:10s with LS, 5" straight pipe. DSS steering brace, AGR steering box. Holley Black on the frame rail, ISSPRO fuel pressure guage. Heachache rack, brush guard, 100w driving lights. Goerend triple disc and VB. Last edited by Ops : 06-05-2008 at 03:46 PM. Reason: doulble tap.. |
#50 (permalink) |
![]() The filter on the right is a 2 micron fuel filter, it takes about an hour or so for 5 gallons of duel to trickle thru. the filtered oil is brown instead of black. I'm getting 2 mpg more, (20) with plenty of power and a much quieter engine. I may cut down to 15% due to concerns with cold flow to the VP44. And yes, I am still adding 2 stroke oil. I'll keep you posted. Ops
01 QC, tow package, 4X4, Edge EZ, 4:10s with LS, 5" straight pipe. DSS steering brace, AGR steering box. Holley Black on the frame rail, ISSPRO fuel pressure guage. Heachache rack, brush guard, 100w driving lights. Goerend triple disc and VB. |
#51 (permalink) | |
BOMBS AWAY!
![]() Join Date: Apr 2008
In all fairness, they would be saving more than a nickle at the gas station. I think most people relize that they are their own warranty once they start to dump things other than diesel fuel into the system.
01.5 Flame Red 3500 DRW 2WD LB QC Laramie 47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel, J-Hook, BD Power Pod |
#52 (permalink) |
Just got here... if it hasn't been asked yet, how'd WEO work with a 98 12 valve? Anyone here tried it on a big truck? Got a couple of older big trucks than the ones in my sig I would want to try it on. If it works in a tractor it'll work in a otr detroit..... Right??? Know a couple of guys that run WEO in their big trucks after an oil change but not even close to these ratios. Sure would be nice to not spend $1/mile on fuel!!
98 3/4 ton ext cab 12 valve, 2wd, #10 plate (kind of... home ground), tranny coming soon 07 6.7 rolling smog filter, bone stock till warrenty is out 07 KW W900L flat top cummins ISX 565,07 Pete 379ext hood flat top, Cat C-15 475 |
#53 (permalink) | |
TECH SPECIALIST
![]() Join Date: Oct 2006
2001 4X4 Auto SLT Laramie - DANA 60/DANA 70, 3.55's - Isspro Gauges, FP, Pyro, Boost, Trans. Temp. - HBS 2" Leveling Kit - Straight Pipe - Amsoil Nanofiber 4510 CAI - Quadzilla XZT+ - Debadged - 285/75/16 Firestone Destination M/T's 230,000 miles as of 08/09 -
- All Cummins all the time! |
#55 (permalink) |
I'm about to start once the 1 micron bag filters arrive. MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2 |
#56 (permalink) |
remember you do oil changes to get that crap out of your engines,its no stretch to imagine that adding it through the fuel system would do anything but take years off the service life of the engine
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods |
#57 (permalink) |
Yep, im sure its just killing the service life of the motor. It runs smoother, quiter, and with more power. Im sure its just tearing up the insides. Not. anyway, the truck has drank another couple hundred gallons of motor oil w/ no problems
'94,2500 4X4, 5 sp, everything but... the stock turbo, still my anchor. peelout |
#58 (permalink) |
Plvaulter06, It is a good thing you are using your cummins as a test mule for WMO,We here like this type of real hands on science.Your stats that your truck drank "another couple hundred gallons of motor oil" doesn't add up with your previous post declaring your new to this and have 2000 miles of WMO use on your truck.Unless you get less than 10 mpg. We need your statistics to be clean pure measureable science.I can find BS anywhere!For example the subprime mortgage debacle,I didn't buy into that friggin disaster either.Remember the bypass centrifuge oil filters remove dirt from the oil down to about a tenth of a micron.Your engines symptoms of running quieter,with more power I don't dispute.You are running dirty fuel through your fuel system.A baseline oil analysis,and every 10k would help prove your experiment.As for that and your test mule,better yours than mine! Happy Motoring!
#59 (permalink) |
Don't think running used oil that's highly filtered is going to cause a problem. The Fleetguard Statapore oil filters down to 25 micron. The typical fuel filter is 7-10 microns. Externally filtering the used oil down to 1-2 microns should be good. MikeyB
#60 (permalink) |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
You'll have to ignore challenged if it's not endorced by him, you're an idiot. Personally I ran WEO in my truck for a while, but it killed the fuel filter. I wasn't pre-filtering though. Just drain and in the tank it went. I noticed that mileage seemed to suffer a bit with it. Add to it, my truck smelt like it was burning oil. So I stopped runnning it. I'd assume that lower doses and a pre-filtered oil would be fine though. Perhaps I'll revist this once I get a few larger things in my life taken care of. But I'll just keep running dino in the tank with 2 stroke oil in there for now. I've got to finish my WVO setup though.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
