Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 06-02-2008, 12:30 AM   #37 (permalink)
TECH SPECIALIST
lvin4jc's Avatar
Originally Posted by Austin The DieselTech View Post
The only thing I think we need to worry about is the wear elements in the oil but if a filter with a low micron rating is used then I don't think it would be a problem.
Does anyone have any pictures of what WMO looks like after its been filtered by a low micron filter? Also, since we're not mixing any chemicals together like in traditional bio, is there any reason to wait for settling?
2001 4X4 Auto SLT Laramie - DANA 60/DANA 70, 3.55's - Isspro Gauges, FP, Pyro, Boost, Trans. Temp. - HBS 2" Leveling Kit - Straight Pipe - Amsoil Nanofiber 4510 CAI - Quadzilla XZT+ - Debadged - 285/75/16 Firestone Destination M/T's
230,000 miles as of 08/09 - - All Cummins all the time!
lvin4jc is offline
Old 06-02-2008, 08:16 AM   #38 (permalink)
Hey, new here to the site. I have also really been intrested in running WMO and found a supply. I have looked at buying a processor but they are really high. Any ideas on a cheaper way. Thanks
jb71121 is offline
Old 06-02-2008, 11:56 AM   #39 (permalink)
No pictures but its still black, very black after even 2 hours of filtering through a 2 micron fuel filter/water seperator baldwin #1212.
97 2500 CC LB 4X4 Auto 3.54 215 injectors 4" exhaust 144k glow shift gauges & a couple of German Shorthair copilots.
shorthair is offline
Old 06-02-2008, 12:06 PM   #40 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Yeap... What comes out of my Frantz filter is rather very black and nasty yet... I know it filters way down below what a standard oil filter can do...
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
Mopar1973Man is offline
Old 06-02-2008, 10:50 PM   #41 (permalink)
e-rok's Avatar
My friend just landed me a source at a repair shop, he says I can have all the oil. The owner has an 06 and is interested as well, after I run it in my truck first lol. Now I just have to get everything set-up.
1995 3500 DRW Ext. Cab 2wd
e-rok is offline
Old 06-04-2008, 05:44 PM   #42 (permalink)
BOMBS AWAY!
hipsi's Avatar
Lets say it costs you 150$ to fill up like me, if you run a 50/50 mix and pocket the other $75.. save that money towards VP's or larger issues this may cause.. if it runs like a top for another 50k miles with no issue.. well... do that math.. in therory it could last a very long time.. and at that point when/if it does kill the truck.. you could have had it running on this mix long enough to just walk away from it with your wallet full.
Just a though.
01.5 Flame Red 3500 DRW 2WD LB QC Laramie
47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel, J-Hook, BD Power Pod
hipsi is offline
Old 06-04-2008, 07:06 PM   #43 (permalink)
kdhrick's Avatar
What might be the problems if the WMO is partly syn, which has become very popular???
This would be my biggest worry.
2006 2500 Inferno Red Quad Cab
kdhrick is offline
Old 06-04-2008, 07:59 PM   #44 (permalink)
What the hell just dump in all in there...
After 2 years of battle and study work of trying to protect VP44 and fuel system from damage. Now because of fuel prices it doesn't matter what you dump in your tank...
Well you might as well dump in WVO, WEO, ATF, Gear lube, etc... Synthetic or petroluem... But don't come whine back that your injectors, injection pump and engine is ruined because you tried to save a nickle at the fuel station...
As for me and this thread I'm DONE.
If anyone wants my advise you know where to find me at my web site. Good luck and I hope you guys don't eat a fuel system to save a nickle...
Old 06-04-2008, 09:19 PM   #45 (permalink)
Burn 1200 gal/year in my reznor heater in shop, have to clean heater 2 - 3 times a season for ashes, builds up to the point heater can not burn ( heat ).
My truck don't need that in the vp44
02 3500 slt with camper package, 6 speed HO engine 3:54
http://s174.photobucket.com/albums/w98/saab9k/
saab9k is offline
Old 06-05-2008, 04:43 AM   #46 (permalink)
How are you going to get ashes in your VP44??? Unless you figgure out a way to burn the oil before it gets to the injection pump, then that won't be a problem. Secondly, A VP injects fuel at, what, close to 20,000lbs... atomizing fuel essentially perfect, burning in the cylinder with a bizzilion lbs of pressure and heat. Your space heater, what is it drip feed??? You can't compare how the two will burn it.
I run 75% oil in my 12v as long as the weather is hotter than 70*, when the motor is up to temp, there is no smoke (unless i am flooring it)
I'm not saying you should try it, but don't condemn it unless you have tried it.
'94,2500 4X4, 5 sp, everything but... the stock turbo, still my anchor. peelout
plvaulter06 is offline
Old 06-05-2008, 11:20 AM   #47 (permalink)
Washington Chapter Pres.
Austin The DieselTech's Avatar
The VP doesn't inject the fuel at 20,000 PSI. More aroud 3000-4000 PSI. Now the CR engine can get up to around 20,000. There would be no way to get ash into your VP cuz your not burning the oil before it gets to the ijection pump. Now you might have ash build up in your cylinders and exhaust manifold but with the high amount of exhaust flow I think it would just flow out the exhaust pipe. Just my .02.
Austin
Austin Jenson - Napavine, Wa
2003 2500 6Spd QCLB 4X4 AFE, DiPricols, SBC 3600 DD, Studs, Silver Bullet, Flux 2's, Floor It STG3 CP3 and rail cap, Smarty, AirDog, 6" Miters, leveled 2" on 35's
, Special Thanks to Wally @ FTE Diesel, James @ Rollin Smoke Diesel, and Nick @ Low Budget Diesel Performance
Washington Chapter
Austin The DieselTech is offline
Old 06-05-2008, 03:07 PM   #48 (permalink)
DBLR's Avatar
Why are you so upset this thread is about WEO is it not? This thread has nothing to do with 2 cycle oil or your work so I see no reason to be upset at anyone. If you don't like what they have to say don't read the thread or any post about WEO/Used engine oil!
But if they can do so and not lose $$$ then more power to them as they have found away to stick it to the high cost of diesel fuel and to big oil. Anyway if they have problems and something breaks they are the ones who have to pay the repair bill. I guess if they come back here and complain about the repairs cost then you can say I told you so.
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's
DBLR is offline
