| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#445 (permalink) | |
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods Last edited by Challenger : 01-09-2009 at 01:45 PM. |
#446 (permalink) | |
Actual experience!!!!!!!!!!!!!!!!!!!!!!!
1997 Dodge 2500 3/4 ton ext. cab 4x4 5sp., Dana 80 rear, 3:55 gears, Dual 5 inch stacks, 116,000 miles |
#447 (permalink) | ||
#448 (permalink) | |
When I go to work every day I expect to put my best effort into my work. If a public servent is not doing his duties then he needs to step a side and let some one who will. If a police officer is afraid of his job god help us all when we need them the most. Sorry to take this thread off topic, just wanted to let readers know that red fuel can be detected even if you cover the color up. |
#449 (permalink) | |
Thanks for the info! A also do not recomend using Red Die as it will not save you that much in the end unless you drive you truck for a living. |
#450 (permalink) | |
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods Last edited by Challenger : 01-09-2009 at 10:05 PM. |
#451 (permalink) |
here in texas the "tax" people have a light they can shine under the hood or fuel filler, if you have used dyed fuel the light reacts to the dye, it might be a uv light i have not seen the light only the ticket they got.
96' 3500, DRW, 5 speed, no mods, running wmo mix. I forgot about my alarm system. her name is Madison. |
#452 (permalink) |
Hey, it would be great if all those on wmo from near the beginning and middle of this thread could update us on how it's going,any problems or issues,modifications they made etc.mileage and miles on wmo etc,we haven't heard back from the lad who filters it through his t-shirt for a bit....someone was telling me that the Titanic ran very smoothly on 100% WMO
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods |
#453 (permalink) |
Still goin strong runin bout 60/40 split right now cause diesel is cheap and been on the road travelin alot.. I have run it thru a hankerchif in a pinch before....I have about give up on this thread though. Can we get it back on topic.... I mean weve established (it least in my mind) its not a good idea in the new engines but in the older ones weve had hardly any probs... the less you filter it, the more clogged your filter in your tuck will get, but i still believe tha tif you filter it down to 1-2 micron..anything left in your oil is smaller than the stock cummins filter allows anyhow. In my mind that say its below the allowable size of anything else runnin thru your injectors... I for one am for WMO in 89-98 12 V motors....I wouldnt chance a vp motor and def not a newer 3rd gen. Colder weather means less WMO and more #2...i also run powerservice quite often and i still havent had any probs...I am currently drivin a 97 2500 right now with 340K on the clock. My 98 i had mentioned earlier is still runnin fine but its 2wd 3500 and the weather hasnt been so nic eup north...so the 4wd is comin in useful. thats my update...Still chuggin along..hope all had wonderful holidays... ZC Are we on the same page? |
#455 (permalink) |
I've been running wmo in my 1990 ex ford uhaul box truck since this thread started. I run about a average of 5 gallons some times 10 of wmo every day depending how far away the job is. I figure I have gone through about 1500 gallons since doing it, and still have not had any problems. The wmo is filtered through a 15 micron water block goldenrod filter than through a 10 micron goldenrod and than a 2 micron chem tec with magnets. We pour the oil directly into the tank and about the third time we pump in about 15 gallons of #2 along with the oil. about every 10 days we run it for a couple of days on straight #2 just to keep it mix up. I would not do this with my 99 cummins because of the vp44 but would with a 12 valve,also I have a 1985 vw golf running on straight used veg. oil about 10 gallons a day. And as soon as I can find time to set up a 250 gallon tote I am going to have bio delivered for the 99. thats my update
