| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#349 (permalink) | |
www.Mopar1973Man.com
![]() Join Date: Feb 2006
Michael Nelson - 2002 Dodge Cummins For Technical Assistance With Your 24V 2nd Generation Cummins - Click Here! Or Search CF.Com for an Answer Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
#350 (permalink) |
Then let me ask this then..........
You said "I've tested 2 cycle oil at 128:1 ratio down to -20*F and never had a problem period." Ok, I am new to having my own diesel. I live in WV and assume we get winter blended fuel. Does a person need antigel here? What happens when you add the two stroke? I mean, does it help or hinder geling? Does it do neither? Someone else may have to answer this question. Is WMO blended with diesel more or less prone to gelling? Just trying to learn. Jim
1997 2500 4WD, stick, granny rears, 2wd low capable, 10 plate (yes on gauges), sport lights w/harness, 4" stainless w/something that looks like a muffler. LOVE my Genos cupholder!! |
#351 (permalink) | |
Ok I'll give you this much the anti-gel is actually called " pour point depressant". Here do a bit of read here in the search I did... pour point depressant - Google Search= So now both 2 cycle oil and #2 Diesel use the same pour point depressants so if normal diesel has a pour point to roughly -20*F and snowmobile 2 cycle oil is down to -40*F and it has the same pour point depressants. I would say it help it. Pour point is when your substance is completely solid and doesn't pour (frozen solid). Cloud point is when the substance is still fluid but wax crystals start forming. So now if you check out some of the high performance snowmobile oils you find some as low as -50*F for a pour point. So this would be the excellent 2 cycle oil to add to the fuel knowing that the same pour point depressant is present in the 2 cycle oil. NOTE: Synthetic 2 cycle oil have no wax in there contents so they do NOT contain any kind of pour point depressant. They will not aid in the pour point temps at all. Synthetic oils are produced in a lab from non-pteroleum stock so they are natural low pour point temps... WMO might and it might not change the pour point of diesel fuel. But it will change the viscosity (making it thicker) which will cause damage to the IP pump and injectors in cold winters. Remember Cummins fuel system are intended to run 1 cSt to 5 cSt viscosity. Not 100-140 cSt which engine oil is... This becomes even thickier in the winter time cold.. Specs from the 2002 Dodge Owner manual...
#353 (permalink) |
Mopar since I don't own a vp pump & don't ever intend to I won't worry about it but I do have over 4 years experince with WMO in a db2 pump & it worked just fine down to 0* at blends of 50% without using a block heater. I will keep my P pump & be happy with cheap parts & ease of replacement plus it'll run on near anything that will burn. P.S. even 140 gear lube.
97 2500 CC LB 4X4 Auto 3.54 215 injectors 4" exhaust 144k glow shift gauges & a couple of German Shorthair copilots.
#354 (permalink) | |
#355 (permalink) | |
#356 (permalink) |
vp44 is worthless.... thats all there is to it. i have ran ATF, and used motor oil and cold starts are a little slow but still ok... the p7100 will take a lot gear old and hydrolic oil one of them it gets thick but it still does alright
JUST SOLD:1997 Dodge Ram 2500 4x4 12 valve 5 spd 229,*** patriot blue full replacement bumpers fabtech leveling kit 35" dick cepeks 4" turbo back straight BHAF silencer ring mia pump work |
#357 (permalink) | |
![]() ![]() Or my record high.. ![]() I've got 85K miles on this VP44 and doing just fine. Cranking out high MPG numbers...:thumbsup
#358 (permalink) |
Super Moderator
![]() Join Date: Nov 2006
Yeah the P-pump engines should be called multi-fuel engines, they seem to run on anything diesel, kero, WVO, WMO, rat piss.
Dennis 04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB 1997 Fleetwood Prowler 26.5" Check out: Rig of the Month! ![]() http://www.cumminsforum.com/forum/rig-month/ |
#359 (permalink) | |
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods |
#360 (permalink) |
Gear Head / Electrician
![]() Join Date: Jun 2008
I'm ok with not being able to make black smoke. I would actually prefer not to. It's just wasted fuel going out into the air. You have to blend in the winter to prevent fuel gelling. Both of my vehicles are on a B75 or B80 mix right now. It's been droping just below freezing at night sometimes.
2000 2500 2wd 356HP 726TQ (BHAF, Boost, EGT, FP Gauges, Breather bottle delete, Fass 150/150, Fireball 150's, Phat Shaft 62, Some Billet Trans Parts by TRE, XZT+, 4" exhaust, 2" Level, 315/75-16) 03 Jetta TDI 5 spd "Click here for TDICLUB Profile" 903 Miles on 15.03 Gallons. |
