| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#25 (permalink) |
TECH SPECIALIST
![]() Join Date: Oct 2006
I guess I need help understanding this. In my proposed setup, the oil will be passed through a series of filters that ends with a 1 micron filter as well as a magnetic filter. Given that information, the oil should be about as pure as the 2-stroke oil that you and others swear by, correct? Am I missing something? Please let me know because I am planning on doing this. (Also, I would not be using WVO, it seems to me that you need to pick one or the other and stick with it)
2001 4X4 Auto SLT Laramie - DANA 60/DANA 70, 3.55's - Isspro Gauges, FP, Pyro, Boost, Trans. Temp. - HBS 2" Leveling Kit - Straight Pipe - Amsoil Nanofiber 4510 CAI - Quadzilla XZT+ - Debadged - 285/75/16 Firestone Destination M/T's 230,000 miles as of 08/09 -
- All Cummins all the time! |
#26 (permalink) | |
BOMBS AWAY!
![]() Join Date: Apr 2008
I would try it, 1 micron is like 6 smaller than the factory filter allows to pass.
01.5 Flame Red 3500 DRW 2WD LB QC Laramie 47RE, 55 Block, BHAF, 4" Rapid Flow, DNA Muffler A.R.E Z Series Cap, Optima Blue Tops, AMSOIL, Anti Spin Diff, Line-X, Mopar Brush Guard, Silverstars, 235/75R/16 Dunlop Rover RVXT, Brembo Brakes, XZT+, RV275's, ISSPRO EV's Trans, Turbo, Fuel, J-Hook, BD Power Pod |
#27 (permalink) | |
www.Mopar1973Man.com
![]() Join Date: Feb 2006
ASH CONTENT and CARBON CONTENT... Both of these are extremely high highier than what Cummins specifies for fuel... 2 cycle oil is ASHLESS and CARBONLESS... ![]() CARBON RESIDUE Measures residue in fuel - can influence combustion. The tendency of a diesel fuel to form carbon deposits in an engine can be estimated by various tests to determine the carbon residue after 90% of the fuel has been evaporated ASH CONTENT Measures inorganic residues - The small amount of non-combustable metallic material found in almost all petroleum products is commonly called ash. Ash content should not exceed 0.02 mass percent. remember there is more than steel in a engine... Brass, cooper, aluminum, etc... ![]() Not to mention that WEO did NOT improve the fuel lubricity at all... ![]() But 2 cycle make a huge gain... Look at my Signature... Catch me if you can...
Michael Nelson - 2002 Dodge Cummins For Technical Assistance With Your 24V 2nd Generation Cummins - Click Here! Or Search CF.Com for an Answer Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
#28 (permalink) | |||
TECH SPECIALIST
Second, if Ash is a "metallic material" wouldn't my magnet catch it? Quote:
#29 (permalink) |
![]() Here's my quick setup, 5 gallon container with a pipe connected to the bottom, routed to a Goldenrod waterblock (7 micron) filter. I'll run the WMO once I replace the 10 micron truck fuel filter with a 2 micron type. Cummins, at one time, had a spec for running WMO in diesel fuel. Also, the HD trucks cycle some of the engine oil into the tank and add fresh oil to the crankcase, so as not to change the engine oil but burn it thru the engine. Anyone care to comment? Ops
01 QC, tow package, 4X4, Edge EZ, 4:10s with LS, 5" straight pipe. DSS steering brace, AGR steering box. Holley Black on the frame rail, ISSPRO fuel pressure guage. Heachache rack, brush guard, 100w driving lights. Goerend triple disc and VB. |
#30 (permalink) | |
https://quickserve.cummins.com/info/.../centinel.html But I don't think it large quanities of oil are being used like most people here are trying to use 50% and highier volume... I think Centinel uses less than 5% volume of WEO used in there system... ![]() 5% WEO = 1.75 Gallons at 35 gallons of fuel... If it was highier these engine would consume extremely large amounts of engine oil...
#31 (permalink) |
hope that pipe is a stand pipe and you're not taking out right from the bottom of that drum...........if so...............yummy...............i can just imagine the stuff that possibly will settle out.
2006 SRW MEGALIMO 4X4 3500 5.9CUMMINS, VAN AAKEN C5,COMMANDER GUAGES,MUFFLER DELETE PIPE, ICEBOX WITH NANO 4091:.....................................$: it's only money.......unless you're broke ! ![]()
#32 (permalink) | |
TECH SPECIALIST
What?
#33 (permalink) |
I was referring to the Centinel System on large Cummins engines... If Centinel use 5% WEO in fuel that would mean in 35 gallons of fuel you would consume 1.75 Gallons of engine oil. I would consider that a extremely high rate of WEO burn... It wouldn't be cost efficent. Basically in one tank of fuel in our truck we would consume the entire crankcase of oil.. ![]() Like a lot of people here are wanting to run a Cummins on high volumes (greater than 5%) of WEO which is not suggested. Like myself I'm running 0.7% of 2 cycle oil in my fuel (128:1 Ratio). 20:1 Ratio = 5% Volume = 224 Ounces (1.75 Gallons) 128:1 Ratio = 0.7% Volume = 35 Ounces (Basically 1 quart of WEO to a tank of fuel... More realistic!) 200:1 Ratio = 0.5% Volume = 22.4 Ounces
#34 (permalink) |
I have a 7 micron water block element in the filter on the oil outlet, and a drain cock to drain out the slime. I found a part # for a 2 micron fuel filter for the engine mounted final filter. Believe it or not, an oil filter is about 20 microns, and the standard fuel filter is 10 microns. I'm gonna go forward with this, I do have a source of waste oil. Ops
#35 (permalink) |
Gentlemen- I like this idea and would like to go forward with it if it's proven safe for the VP-44. I think there is one point being missed thus far-- yes, waste engine oil has soot and carbon in it. Agreed. But, think of how it got there: byproducts from burning fuel. There are only so many things going into the engine in quantity- air, fuel, and oil. These contaminants in the oil (excluding wear metals) can only come from two places- air or fuel. The fuel has already brought this junk into the oil so we've already exposed our engines to it anyway. So, unless we worry about filtering our air and oil to 1 micron also, I don't see the trouble with it (except carbon coking/buildup, any thoughts?)
01.5 QC/LB HO/Handshaker, Adrenaline/Pulse, BHAF, Straight Pipe, Big Smile! Powered by Biodiesel...Starve a terrorist! |
#36 (permalink) | |
Washington Chapter Pres.
![]() Join Date: Sep 2007
The only thing I think we need to worry about is the wear elements in the oil but if a filter with a low micron rating is used then I don't think it would be a problem.
Austin Jenson - Napavine, Wa 2003 2500 6Spd QCLB 4X4 AFE, DiPricols, SBC 3600 DD, Studs, Silver Bullet, Flux 2's, Floor It STG3 CP3 and rail cap, Smarty, AirDog, 6" Miters, leveled 2" on 35's, Special Thanks to Wally @ FTE Diesel, James @ Rollin Smoke Diesel, and Nick @ Low Budget Diesel Performance Washington Chapter |
