| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#229 (permalink) | |
Washington Chapter Pres.
![]() Join Date: Sep 2007
Austin Jenson - Napavine, Wa 2003 2500 6Spd QCLB 4X4 AFE, DiPricols, SBC 3600 DD, Studs, Silver Bullet, Flux 2's, Floor It STG3 CP3 and rail cap, Smarty, AirDog, 6" Miters, leveled 2" on 35's, Special Thanks to Wally @ FTE Diesel, James @ Rollin Smoke Diesel, and Nick @ Low Budget Diesel Performance Washington Chapter |
#230 (permalink) |
Super Moderator
![]() Join Date: Nov 2006
I know seriously! I see the new hp number in your sig by the by. Congrats.
Dennis 04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB 1997 Fleetwood Prowler 26.5" Check out: Rig of the Month! ![]() http://www.cumminsforum.com/forum/rig-month/ |
#231 (permalink) | |
#232 (permalink) |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
It's not going to be a large volume. He's got a diesel as well. I'll only see about 15 gallons a week or so. I plan on getting a tank and stockpiling though!
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
#233 (permalink) | |
#234 (permalink) | ||
Super Moderator
#235 (permalink) | |
Not that anything I've done thus far has "wrecked my fuel system". The VP44 of mine is still running fine. It was just setting off those codes due to the heat from the WVO setup. Taking thin jet-a and thickening it up is a lot easier on things than the other way around.
#236 (permalink) |
I know a few people running Jet-A. They get it free for the same reason. Must be nice! MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2 |
#237 (permalink) |
I have a bypass filtration system on my pulling truck, and change the oil every 10 hooks. I just started dumping it into my vp44 truck. I have a Fass and the stock filter still. I figure between the fass and the stock filter I should be ok. Heck it is only 2.5 gallons put in a 34 gallon tank, and I burn 15 gallon to 34 gallon every hook, so minimum I am running 150 gallon through the truck to every 2.5 gallon I put in. One reason I change the oil at 10 hooks is because of the large amount of fuel that gets into the engine oil.
B&B performance: Industrial Injection, HTT, EDGE, Bully Dog, BD, South Bend Clutches |
#239 (permalink) |
Super Administrator
![]() Join Date: Jan 2006
[quote=Challenger;818171][url="http://www.cumminsforum.com/forum/technical-service-bulletins-recall-supprt/7801-bulletin-14-007-06-2006-2007-diesel"[/QUOTE] Not working.
![]() 03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph) July 2009 Cummins Forum ROTM Winner 95 1500 Sport 2wd Cummins Drag Truck under construction. "In search of the Magic Dyno"
#240 (permalink) |
Super Moderator
Yeahhhh.....
