| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#13 (permalink) |
Diesel Mechanic
I don't think it matters what type of engine oil. He is running 75/25 mix in the tractor at the moment and its runninig like a top.
Austin Jenson - Napavine, Wa 477HP/862TQ - 2003 2500 6Spd QCLB 4X4 K&N, Gauges, HTT62/71/13SS, Flux 2's, Smarty, TST, AirDog 150, 6" Miters, heater delete, rail capped |
#14 (permalink) | |
TECH SPECIALIST
2001 Quadcab CTD 4X4 - Auto Tranny - 3.55 Gears - Triple gauge A-pillar - Isspro gauges, Pyro, Boost, Tranny Temp - Fuel Pressure Gauge - Silencer Ring MIA - Straight Piped - Amsoil Nanofiber 4510 - Quadzilla Mileage Max (soon to be XZT+) - 2" Leveling Kit - Turbo Timer - 285/75/16 Firestone Destination M/T's ![]() |
#15 (permalink) |
Cummins has a system, Centinal, that takes used engine oil and runs it back to the fuel tanks. Very little at a time though. It has a make up oil tank on it so it keeps the engine oil at the full mark and you just top off the make up tank. Its only used on the heavy duty engines though. Pre 07 also.
2001.5 2500 Quad Cab Short Bed, Patirot Blue over Gray, 4x4, NV4500, DSS, 3rd gen Trac Bar, Optix Gauges, Air Dog 150, DDP 3 Injectors, 4in MBRP TBE, Kevlar/Ceramic Valair, Quad Adrenaline, BD Super B, ICEBOX |
#16 (permalink) | |
im with you on this one... i know i could make it up but idk about this military filtration pod he talks about that is the life of the system and located in the second tank... that would be the only thing that i would be worried about.... but i am highly interested in this since my dad has two peterbilts and thats ten gallons of oil a pop and oil changes come frequently with them... i want to do this
2003 2500 SWB 2wd, Leveled, Smarty TNT, Cool Tube, Silencer Ring & Heater Grid MIA, Train Horns, Magnaflow Muffler, Blue LED Dash and Floor Lights, Recon Big Rig Lights, Prodigy, H2s. Raptor 150, Gauges, Arson Kit soon to come.
#17 (permalink) |
I'm working on one now. I need to find a 2 micron filter tha will fit a Goldenrod bowl. Ops
01 QC, tow package, 4X4, 33" BFG's, Edge EZ, 4:10s with LS, 5" straight pipe. Updated May 07: Holley Black on the frame rail, ISSPRO fuel pressure guage. Modified heachache rack, brush guard, 100w driving lights. Goerend triple disc and VB. |
#18 (permalink) |
Ya, i started doing this time wise, not all that long ago, but ive ran probably 2000 miles now, now problems. My truck sounds AWESOME, much less diesel clatter. Ive ran mixes from 50/50 up to probably 80 percent oil. Averaged close to 25 mpg. One thing that i have noticed with above 60 or 70% oil is that it runs pretty clean when its up to temp. It starts up a bit smokey, and if im cruising and stop, exhaust is 100% clean, but if i go in the store and let idle for 5 minutes it goes back to being a little smokey. Im pretty sure my filter is starting to die, because its starting to spudder just a little bit every once in a while. Ive only been filtering down to 5 micron. Im working on a new system now, it will be filtered down to 1 micron before it goes in the new auxiliary tank, then though a coolent heat exchanger, tank switch over valves, then a 12v heater (vegmax) then into the stock fuel heater/fuel filter and into the injection pump. The goal is 180 degrees and running it straight!!!! I'll report back and let you know how it goes. Right now i love the mix but at over $5 a gallon, i don't even want to pay for 25% diesel
'94,2500 4X4, 5 sp, I've got the "stuff mod." the stock turbo is still my anchor. peelout |
#19 (permalink) |
Oh ya, anyone tried this with a VP-44?? or anyone tried heated straight Veggie oil with the VP?? id imagine it would work better than veggie oil because better lubing. Doesn't the VP use fuel to cool it though??? that could be bad (my buddies truck... i would never abandon my 12v well maybe eventually for a CR)
#20 (permalink) |
TECH SPECIALIST
Wondering the same thing
#24 (permalink) |
2 Cycle Oil Guru
Well... I'm not a fan of WEO at all... It just to risky with the expense of the VP44 pumps and injectors. But I do know of a guy that was using homebrew BioDiesel and dumping WVO in and fuel too... Well needless to say the fuel gelled up and plugged up the injection pump and injectors for about $3200 bucks... There is no short cuts in life... If you going to make fuel make it right... Garbage in...Garbage out... What you use for fuel is the performance you going to get...
Michael Nelson - 2002 Dodge Cummins ![]() |
