| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#193 (permalink) | |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
Edit: BTW, I'm playing around with a dual tank setup on my truck. But the VP44 can't handle the heat due to the electronics being built into the pump. That said. I'll be migrating my setup over to my Samurai with a VW 1.6TD. All mechanical, so no issues!
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
#194 (permalink) | |
At the end of the day, I am only giving you my experience. Which is something that the knockers can not do. You are working on Opinion.. and that is all. Keep paying your $4.50 a gallon, Does not worry me at all... |
#195 (permalink) | |
#196 (permalink) |
Gear Head / Electrician
![]() Join Date: Jun 2008
I'm working on the centrifuge setup similar to patracy. I'll be using it for both motor oil and veggie oil.
2000 2500 2wd 356HP 726TQ (BHAF, Boost, EGT, FP Gauges, Breather bottle delete, Fass 150/150, Fireball 150's, Phat Shaft 62, Some Billet Trans Parts by TRE, XZT+, 4" exhaust, 2" Level, 315/75-16) 03 Jetta TDI 5 spd "Click here for TDICLUB Profile" 903 Miles on 15.03 Gallons. |
#197 (permalink) | |
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods |
#198 (permalink) |
Just saw this article on yahoo. Maybe everybody else is catching on about OCI. The 3,000 Mile Oil Change Myth- Yahoo! Autos Article Page
#199 (permalink) | |
![]() Anyhoo... Have you pulled your injectors to see if there's any coking going on? I thought I recalled you stating that your engine was an IDI though right? That can make a difference.
#200 (permalink) | |
I am a big believer in "if it aint broke, dont fix it" so I have never pulled the injectors or done any of the other tests. Oil get changed every 10,000 kilometres. (6,000 miles) and it is normal oil. Looks the same as my dads when he was never using WMO. Does not seem to burn any oil. But who would know, it might be laking past the rings and staying in the sump. But it never gets any fuller than that the amount that I put in there. So I guess that is a bit of an unknown. But for more than 100,000 miles with no problems... I am not complaining or asking questions.. |
#201 (permalink) |
Yep, the IDI is a lot different. That said, my VW engine is an IDI. So that's a plus. ![]() Post up some pics of your setup if you could. Just curious about your heat exchangers.
#202 (permalink) | |
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods Last edited by Challenger : 08-26-2008 at 11:39 PM. |
#203 (permalink) |
To whom it may concern.
paragraphs would be nice please... Dodge isn't the only company that had problems with this design. VW's EGR system would severely clog the intake of all the TDI's. That's why alot of people just remove them. The means of introducing the particulate is completely different. Cooled exhaust gases of any diesel when piped back into the intake system will form a gooey buildup of sludge. If that same soot is entrained in the liquid of the fuel we are using, then it gets atomized into each combustion chamber, burned, then pushed out of the engine. Also, the design of diesel specific engine oil is made to suspend the soot that gets blown by the pistons, prevent it from depositing in any one location.
#204 (permalink) |
Hmmm? Must be missing a post. I guess our old friend is still running on about this huh?
