| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#169 (permalink) |
so with all this being said....i just changed my oil and tranny fluid, they ended up getting mixed together, about 4 gallons total of this stuff, oil was amsiol 15-40. what is yall opinion on filtering the waste oil/trans fluid mix i have and say using one gallon for every tank n see what it does.. considering i dont have electronic injectors i should be good right?and what would be the best way to filter this as well as where to buy the items needed to filter this and to continue to do so in the future. any advice is greatly appreciated. thanks -scott
99 181k rebuilt rear/rebuilt trans/bd triple diskII 11 HOLE/J/A,afe/bd boots/bd x monitor/Leveled/recons/7x44 mitres |
#170 (permalink) |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
Amsoil is synthetic, don't burn it.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
#171 (permalink) |
Test the Amsoil before using it. Soak up some of the oil with a paper towel and burn it. Compare it to conventional motor oil (doing the same). I found that Mobil 1 burns cleaner than Castrol GTX. For filtration I'm using 0.5 micron polyester felt bag filters with an absolute rating of 99%. Two passes doubled bag the rating is 99.9%. MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2 |
#172 (permalink) |
MikeyB, can you post a link to the source of the 0.5 micron bag? I wonder if you can get a 0.5 micron cartridge filer somewhere. Bob
1997 CTD extended cab 4X4 5 speed. Towing package, SLT, BHAF, 4" straight exhaust Bought 4/28/07 |
#173 (permalink) | |
And I made a mistake in my earlier posting. It's efficiency rating is 96%, not 99%. MikeyB
#174 (permalink) |
I thought of another question: Has anyone analyzed B2 for non-ferrous metals? I wonder what metals are in our fuel that they sell us at the gas station. Is filtered WMO any worse? What I am looking for is data to back up someone's post. People seem to post opinions or gut feelings without ant data to support it. I'm looking for facts. Bob
#175 (permalink) | |
'94,2500 4X4, 5 sp, everything but... the stock turbo, still my anchor. peelout |
#176 (permalink) | |
If you don't wish to run WMO that is your truck your choice, as its others choice to run it.
97 2500 CC LB 4X4 Auto 3.54 215 injectors 4" exhaust 144k glow shift gauges & a couple of German Shorthair copilots.
#177 (permalink) |
we should get facts and opionions for people with mechanical injectors and weather or not it is OK or not to run wmo/wtf. i would like to use this waste and put it to good use but im not willing to do that if it involves hurting my engine in any way.what would you guys think if waste was filtered numerous times throught micron bags,then run past many magnets to catch (id like to say) ALL of the metal debris.-scott
#178 (permalink) | |
MikeyB
#179 (permalink) |
Gear Head / Electrician
![]() Join Date: Jun 2008
Just got my acme juicer in the mail today, ![]() I'll start modifying it to create a centrifuge friday after work. I'm stuck on duty tonight. Posting from my laptop tethered through cell phone.
2000 2500 2wd 356HP 726TQ (BHAF, Boost, EGT, FP Gauges, Breather bottle delete, Fass 150/150, Fireball 150's, Phat Shaft 62, Some Billet Trans Parts by TRE, XZT+, 4" exhaust, 2" Level, 315/75-16) 03 Jetta TDI 5 spd "Click here for TDICLUB Profile" 903 Miles on 15.03 Gallons. |
#180 (permalink) | |
