Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 08-01-2008, 05:25 AM   #157 (permalink)
Originally Posted by Desert Dually View Post
thank you for the reply:thumbsup I enjoy a good debate too, and I will freely admit I have been schooled on certain things during debates. But there is a way to have a polite debate without sounding condescending or holier than thou. Just my 2 cents. :thumbsup
BTW, I too have heard about that 700 degree cracking by some guy on the BITOG forums, and the process and its final result appears to be the real deal, but a bit more complicated than I am willing to step into at this point. As for now, I am enjoying my own forays into using WMO as fuel, building my own high efficiency filtration system, making new connections for WMO acquisition, etc. Seems a heckuva lot less work than making biodiesel and the cost per gallon is literally next to nothing once the filtration system is constructed. Since motor oil contains over 10 thousand more BTU's per gallon than diesel fuel itself, it actually adds noticeably to the power my truck makes. It's a seat-of-the-pants difference.
How long have you owned that 64 'vette? Is it a drum braked car? I drove one of those for a while. For having drums and not discs, the brakes were surprizingly effective
Good points,for me the wmo fuel subject is a bigger issue than I wanted to let on.It could probably be settled by a few slides under a microscope,collectively as a cummins forum it is very important to get a clear answer good or bad with no ambiguity at all,because if we think it is good and it isn't then we are wrecking cummins engines,and in effect promoting something that is destuctive to other cummins engines,pickups to semis,these ideas can take off in a huge wave(think subprime,some similarities,more serious for sure,but I still can't believe that anyone would buy into that, but millions did) So are we as a forum going to be part of a wave that destroy these engines,devalues our own trucks,create a bad name for cummins engines over all,makes it harder to know if the future used truck we want to buy is close to being toast, become the laughing stock of forums for promoting the destruction of our own trucks. the vettes a rush,the drum brakes work good,don't care for the single master cyl:thumbsup
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods
Challenger is offline
Old 08-01-2008, 11:18 PM   #158 (permalink)
ISX
ISX's Avatar
I think the reason it keeps coming up is because there are other people who have ran it for tens of thousands of miles and have saved umpteen hundred dollars on fuel.. Which being $150 to fill the dodge, it really would pay for anything that messed up... Besides that, the only thing I can see is selling it to someone who is going to care for it and run 8 different oil filters on it, etc, etc, and then has things go wrong because the previous owner dumped oil in it.. But as long as you tell them, and they are planning on doing the same thing...I see no problem.. The people with 20000 miles on WMO running it 50/50, say 20MPG, 35 gallon fillup.... would take $4430 on all diesel or $2215 on 50/50 which means you saved $2215, which is plenty to get anything that breaks, especially on a 1st gen.. And then theres those that have gone over 50k without anything breaking... But what do you think is worse, oil with tiny particles, or lube ridden ULSD?? I never heard of anything failing on WMO, but everyday it seems someone on ULSD trashed another VP44...
1990 F250 7.3 IDI NA auto 4x4 250k
1997 2500 12V Cummins 5spd 2wd 311k miles #100 plate, SB Con O, 26.6MPG-55mph
ISX is offline
Old 08-05-2008, 11:51 PM   #159 (permalink)
Originally Posted by Challenger View Post
mafia do you burn wmo?
Let's just say I have a big tank in the bed of my truck.
Judging by your responses, you are either one of those clowns who won't drive his truck in the rain, has every oil change and tire presure check logged in your owners manual, drives 5 mph below the speedlimit, or you are a closet oil burner yourself.
rock mafia is offline
Old 08-05-2008, 11:58 PM   #160 (permalink)
GA VP...so close to 500hp
patracy's Avatar
I've got ~55 gallons I need to do something with. I'm going to try a new way of filtering.
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
patracy is online now
Old 08-09-2008, 10:54 PM   #161 (permalink)
None of the above, i need to be able to depend on my trucks to go coast to coast,trouble is a funny thing it finds us easy enough without going looking for it
Old 08-10-2008, 12:01 AM   #162 (permalink)
Gear Head / Electrician
speed185187's Avatar
Just ordered a centrifuge. Should be here in a couple of days. Another new toy to play with.
2000 2500 2wd 356HP 726TQ
(BHAF, Boost, EGT, FP Gauges, Breather bottle delete, Fass 150/150, Fireball 150's, Phat Shaft 62, Some Billet Trans Parts by TRE, XZT+, 4" exhaust, 2" Level, 315/75-16)
03 Jetta TDI 5 spd "Click here for TDICLUB Profile" 903 Miles on 15.03 Gallons.
speed185187 is offline
Old 08-10-2008, 03:01 PM   #163 (permalink)
Desert Dually's Avatar
very cool! :thumbsup
I have two of those on my "want list", one for WMO alternative fuels, one for the truck itself.
07 MegaCab SLT 4x4 Dually - 5.9 48RE, Line-X, 2" leveling kit, Safari Off-Road trackbar, Smarty, flares, 315/70-17 Yokohama Geolander's, Powersteps, Tekonsha P-3, Firestone Ride-Rites
Desert Dually is offline
Old 08-10-2008, 09:07 PM   #164 (permalink)
It's actually an acme juicerator from ebay. It will do the same thing though. I'm on a fixed navy income so I can't spend alot every month unless I go months without spending anything.
Old 08-11-2008, 03:27 PM   #165 (permalink)
I recently just purchased my first Diesel which is an 07 5.9. From the advice in these forums I just put in my first quart of 2-stroke oil and I am pleased thus far. It seems like everyone is mostly after some cost saving and running used oil sounds fine assuming the appropriate filtration, but what about new oil? I saw an add recently where after rebate I could get some cheap brand of 5w30 for .69 a quart after rebate. Thats only 2.76 a gallon. Whats to stop me from buying a bunch of cases and dumb 6 or 7 quarts in per tank. Small savings yes but why not?
ryry444 is offline
Old 08-11-2008, 04:40 PM   #166 (permalink)
ya new oil is even better, you don't gotta mess with it at all. I've done that before, picked up a couple cases real cheap from G.I. Joes. I was putting them in the tank in the parking lot and i got some real funny looks.
Oh ya, and the lighter weight of oil the better. If it's 10 or 20 weight oil i'll run my truck on it straight. 30 or higher i usually mix w/ 5 or 10% diesel
'94,2500 4X4, 5 sp, everything but... the stock turbo, still my anchor. peelout
plvaulter06 is offline
Old 08-19-2008, 04:22 PM   #167 (permalink)
I have a question for those that are worried about non-magnetic metals in the WMO and those who burn WMO (pretty much everybody): Do you think that these particles are smaller than 1 micron? if they aren't there shouldn’t be a problem with non-magnetic particles suspended in WMO if it is filtered to 1 micron, correct?
Bob
1997 CTD extended cab 4X4 5 speed. Towing package, SLT, BHAF, 4" straight exhaust
Bought 4/28/07
bob95065 is offline
Old 08-19-2008, 06:02 PM   #168 (permalink)
The particles are defiantly smaller than 1 micron. After the oil filters through all three of my filters 20-10-1 micron, it passes by a set of computer hard drive magnets. There is always a noticable layer of very fine magnetic metal on it. Which tells me that it is indeed smaller than 1 micron.
The only way to sufficiently filter out particles smaller than this is to use a centrifuge. Now most people will argue that these particles will cause damage to the engine. They are right, but it will take some time. These sub micron particles of wearable metal from engines will errode the injection pump, nozzles, and very likely be depositing small amounts of metal on top of the piston and exhaust turbine.
