Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 07-22-2008, 09:30 AM   #109 (permalink)
McLarenross's Avatar
Location: Shepherd, Texas, USA!!!! (North of Houston a bit)
If you havent tried the WMO and dont have actual results then you shouldnt condemn it and the people who have used it.
Snapper, thanks for your input. Congrats on the WMO working for you. Thank you for actually trying it.
Challenger, how old are you?
Mopar1973man, until you try it and have first hand experiance with something you shouldnt dismiss it. Youve done great work with the 2 Cycle oil, but dont dismiss other options. Thats no better than 2 ricers sitting around comparing the specs of their hUndahs and arguing whose is faster but never actually racing.
2004.5 2500 4x4. Torque Tube gutted and Silencer Ring removed. Grid Heater gutted. Custom made 3" Intake Horn. Straight pipe'd. Edge Juice w/Attitude. 4" Superlift. H2 wheels w/ 315/70/17 BFGs. Smoke Switch. PROPANE!!!!
McLarenross is offline   Reply With Quote
Old 07-22-2008, 11:53 AM   #110 (permalink)
2 Cycle Oil Guru
Mopar1973Man's Avatar
That's thpoint I do have data on heavy usage of 2 cycle oil and it effects the MPG and power of a vehicle. This is why the suggest ratio was ranging from 100:1 to 200:1 so it would effect the MPG's. I've had another member of a forum report back that my ratio of 100:1 to 200:1 is finer but when he went up words of 3 quarts in the fuel he lost over 50 HP on the dyno from it... So I know any oil is going to alter fuel characteristics and it not for the good...
I got a guy that is running up to 2 gallons of 2 cycle oil now and lost 5-7 MPG over it. Now is there much difference between 2 cycle oil and waste engine oil??? Not really... Just the fact remains that there is a heavy ASH and CARBON level that Cummins doesn't suggest for WEO fuels... I just about willing to try up to 5% but for the price of a injection pump and injectors is it really worth it?? I really don't have that kind of money to make a gamble like that...
That's why I've been working at improving my MPG... As for testing I got guys doing testing for me all the time...
Old 07-22-2008, 12:25 PM   #111 (permalink)
haha well he can dump all the crap through his truck all he wants... but i filter down to 1 micron before putting anything into my truck, so i don't think that is the problem.
I'm sure the added heat is just a bonus. Running 95% WMO, the truck runs fine without the line heater on, (as long as its hot outside). I don't know exactly how hot it gets the oil, but pretty darn hot. After the truck has been running for a while the fuel filter and the line that feeds the p-pump are way too hot to touch. (well without getting burned)
'94,2500 4X4, 5 sp, everything but... the stock turbo, still my anchor. peelout
plvaulter06 is offline   Reply With Quote
Old 07-22-2008, 01:16 PM   #112 (permalink)
GA Chapter Vice President
patracy's Avatar
Well it takes 18ft of coolant heated 1/2" fuel line in my WVO setup to get the oil up to ~165F. There's a heck of a lot more surface area to that. Just my testing...
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse , BHAF, FBD 150 sticks, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan.
Parts to come: turbo and bigger exhaust, both seriously needed now!
patracy is offline   Reply With Quote
Old 07-22-2008, 01:33 PM   #113 (permalink)
SO... where is this data and all these facts from you and "this guy" you know?? dyno results?? anything?? all I've seen is posts with nothing to back it up. hmm hmm, restating from an earlier post....
Not tryin to be a smarty about it, but writing down miles and calculating MPG's on the back of a reciept from waffle house isn't real accurate.
2001 Cummins 4x4
111,000 and keeps on tickin
snapper is offline   Reply With Quote
Old 07-22-2008, 01:56 PM   #114 (permalink)
I have an uncle that runs pure filtered motor oil in his ps and he hasn't had any issues at all. Its pretty simple all you need is a 1 micron filter and run it through about twice and you good to go. I think if theres a problem with metal deposits in the oil maybe you should run a magnet before your filter system(just a thought)
Too many cars to list. Drag truck is in the plans for next winter as my project.
Cummins 429 is online now   Reply With Quote
Old 07-22-2008, 02:04 PM   #115 (permalink)
Dad
Administrator
Dad's Avatar
Let's cool this down a notch or three..
Thanks.
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune
Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's
Dad is offline   Reply With Quote
Old 07-22-2008, 02:11 PM   #116 (permalink)
Oh sorry you guys are already all over the magnet thing and I didn't really think of the other types of metal
Old 07-22-2008, 05:00 PM   #117 (permalink)
ISX
ISX's Avatar
Snapper, what kind of mileage are you getting running that WMO? I gained a lot with the ford but I did it too crudely to really know for sure, but I have had a couple people around here with cummins' do it and tell me they are getting more MPG's with the WMO so I just wondered if your results were the same as theirs, and mine..?
1990 F250 7.3 IDI NA auto 4x4 250k
1997 2500 12V Cummins 5spd 2wd 295k miles #100 plate, SB Con O 26mpg O/D 1850RPM Cruise C..
ISX is offline   Reply With Quote
Old 07-22-2008, 05:45 PM   #118 (permalink)
Dad
Administrator
Dad's Avatar
Thank you gents. We've a lot to learn from each other if we try a little...
Cummins used to say you could run up to 10% weo in your fuel in the earlier VE and P pumped motors. They have been silent to my knowledge on VP and CP3 pumped trucks. Deposits seem to be the biggest issue. As with running straight veggie, I would think engine operating temp would be key to preventing deposits from contanminents if you are running a heavy dose of weo. There are easily referenced examples on line of diesels getting coked up from veggie oil when the vehicles are used as daily drivers.
Old 07-22-2008, 05:49 PM   #119 (permalink)
patracy's Avatar
I'm hoping my 18ft of hose in hose plus another heat exchanger I'm building will prevent that. I'm also going to add diesel kleen + cetane boost to each tank.
Old 07-22-2008, 06:02 PM   #120 (permalink)
this forums strategy is in part to promote ideas that support and improve cummins engines and drive trains in our trucks,i have been around long enough to say dirt is probably our engines #1 enemy,whether it comes in the intake or via the fuel.i am interested in alternative fuels,especially WVO but in particular bio made from WVO,I like the reports from those running WMO and their critism,you will shorten the service life of your engine,it will cause premature failure,20k is nothing in the lifespan of a well cared for cummins,but 20 k of WMO could equal 100 k diesel or more, and once you reach a certain threshold it will eat itself apart internally rather quickly,but hopefully you will have sold it just prior to that right,but hopefully not to another member of this forum!
96 Dodge CTD 3500 4x4 black extracab dually auto 3.54 no mods 1980 Mack Cruise-Liner Cummins N14 370/430 hp 10spd,air ride
Challenger is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
