Mixing synthetic with conventional - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 01-27-2012, 05:23 AM   #1 (permalink)
schroederMP's Avatar
I about to change my tranny fluid. My tranny was built by the previous owner...and I'm unsure what the shop put in it as far a tranny fluid (they have failed to call me back)
My question is... lets say they put conventional tranny fluid in it, then I put synthetic fluid in it when I change it. Will that hurt anything?
I'm not flushing, just changing the gov selinoid and filter.
Dont wanna fry my tranny...do expensive to do guess work.
I tried searching and failed
Thanks
2005 CTD 4x4-5" Turbo back exhaust, Icebox CAI, Smarty, AirDog, built tranny, 5"RC Lift, 35s
schroederMP is offline   Reply With Quote
Old 01-27-2012, 05:52 AM   #2 (permalink)
TRig's Avatar
You'll be fine. Every synthetic oil I've used is compatible with conventional oils. On the tranny, you're not going to get all of the oil out unless you performed a true flush.
06QC/SB 4X4, 48RE. GDP MK-2 Fuel Bypass, Amsoil BMK-11 Oil Bypass, PSC Steering Brace, Line-X liner, Pacer LED Smoked Cab Lights, Amsoil throughout
TRig is offline   Reply With Quote
The Following User Says Thank You to TRig For This Useful Post:
schroederMP (01-27-2012)
Old 01-27-2012, 05:57 AM   #3 (permalink)
Awesome...thank you for the quick reply!
Old 01-30-2012, 06:59 PM   #4 (permalink)
rufushusky's Avatar
Thanks
Factory spec for the 48re is ATF+4 which is a synthetic fluid to begin with...
2002 Ford F-350 ECLB 7.3 4R100 4X4, 6637 intake, 203* T-stat, 08 diff cover, HPX, Stancor Relay, 6.0 trans cooler
Gone:
04.5 Ram 2500 Reg Cab 48re 205k miles
Cat fuel filter
rufushusky is offline   Reply With Quote
The Following User Says Thank You to rufushusky For This Useful Post:
schroederMP (01-30-2012)
Old 01-30-2012, 08:26 PM   #5 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
You'll be fine, synthetics are compatible with conventional oils. ATF+4 from most manufacturers is a Group III mineral oil based synthetic. AMSOIL ATF is a Group IV. The Group IV synthetic is more thermally stable and will protect a hot transmission better, but even Group IV AMSOIL can be mixed with the lower grade Group III products.
-Chuck
Proud Cummins Forum Sponsor since 2006 - SUPPORT YOUR CUMMINS FORUM SPONSORS, WE SUPPORT YOU. THANK YOU!
Specializing in AMSOIL everything
Duluth Diesel is offline   Reply With Quote
The Following User Says Thank You to Duluth Diesel For This Useful Post:
