proof of 2 stroke oil - Dodge Cummins Diesel Forum
post #1 of 154 (permalink) Old 01-17-2008, 10:09 PM Thread Starter
SmokinRam01's Avatar
well I just added a small bottle of Wally World 2 stroke oil, it was @ 1/4 tank and I added the 16oz bottle and added fuel till it was about between 3/4 and full...........man she ain't never been that quiet........still have to do the valve job, she has 120,000 miles on her........maybe this weekend
2001 Sport Quad 4X4, Edge Juice w/Attitude "Hot",stacks with soft bed cover, MotoMetal 951 wrapped in 315x75x16 Falken Rocky Mt.,level kit,Airdog 150,FBD's 150's, II 62,BHAF with Outterwears,SunCoast Tripple Lock Converter and TorqLoc switch 865-806-8151
SmokinRam01 is offline
post #2 of 154 (permalink) Old 01-17-2008, 10:15 PM
Duluth Diesel's Avatar
Yep, that's why I run AMSOIL 2 stroke oil in my '02.
-Chuck
Duluth Diesel is offline
post #3 of 154 (permalink) Old 01-17-2008, 10:17 PM
2-stroke in mine too
you can o-most hear your self around it now lol
05 Dodge Ram 3500 QC SB SRW
5 inch FBD to 6inch stacks , 37s, 6inch lift, TST R49, Smarty, SB 550,Airdog, II PS 62 over an S475
stark is offline
post #4 of 154 (permalink) Old 01-17-2008, 11:37 PM
bmac's Avatar
Is 2-stroke really the way to go? I have been running Lucas and Cetane Boost, but really like the idea of 2-stroke from what everyone keeps saying on here. I can get plenty of this anywhere around here. The Lucas gets really expensive.
Does 2-stroke risk injector damage or increase the risk of any failures? Have any performance or improved MPG claims been proven? I would not want to see anything happen as it's finally running perfect. I would hate to fry a VP or any injectors.
FOR SALE!!! 99 Dually, Edge 5 (not tapped), 100HP sticks, ATS 5dsk Trans and Co-Pilot, FASS150, Cammed, Gages, ATS 3-piece Header, Banks Intake, 4:10s & Lockers, AmSoil, Hadley air horn, 5-inch exhaust
bmac is offline
post #5 of 154 (permalink) Old 01-17-2008, 11:48 PM
duramaxin14's Avatar
2 stroke pervernts injector damage along with pump damage and everything eles 2 stroke luburicats the injectors and the injection pump. Me myself i run ATF in ever other tank of fuel. Its just what i perfer u get more. I have ran 2 stroke 2 and really cant tell the differnce between that and ATF but your truck will no there is something luburcating. I get better fuel miliage with it also
Snow flake 2004.5 D/A Efi live, And way to many other mods. 2wd sled puller
K&P Diesel House
duramaxin14 is offline
post #6 of 154 (permalink) Old 01-17-2008, 11:55 PM
Burgundy Bomber's Avatar
working on my first gallon-O 2 stroke... my engine is insanely loud (2nd gen whaddya expect) how long should it take till It quiets down? if ever... I've heard it takes several tanks for the full effect then you can run it every other or so...
Not sure if 2-stroke is the cause or if it helped, but. This weekend I added it to my tank, I'm down to a 1/4 tank now... put on new air filter, changed oil at 7k, and a new fuel filter, and wow... Whatever did it or the combo, it put the demon back in my truck!!! none of what I replaced was in bad shape... just general maintenance.
Truckless, Carless, Homeless, Jobless
so I'm having a rough decade...... oh well.
Burgundy Bomber is offline
post #7 of 154 (permalink) Old 01-18-2008, 12:24 AM
If u want it to quit down quicker add more then 1 quart add 2 quarts to every tank or more until it starts to quit down
K&P Diesel House
post #8 of 154 (permalink) Old 01-18-2008, 08:37 AM
pwr2tow's Avatar
Just a warning on using ATF in your diesel fuel. The modern day ATF's have friction modifiers that are not made to burn. ATF can also lead to premature failure of the injection system. Useing ATF is from the old days with mechanical injection systems and ATF didn't have the additives and modifiers like todays ATF.
The vp44 truck should definetly run something for more lubricity in their diesel fuel. The cp3 injection system was designed to accomidate the lower lubricity in diesel, no need for more lub. I have not seen any proof that adding 2-stroke does or will increase fuel MPG. I've read guys claiming it does but never experienced it in any of the three diesels I've owned, 1 vp44 truck and 2 cp3 trucks.
I have also read where guys that have torn down engines or replaced injectors after using 2-stroke have commented on how the injector tips were covered in a tar like substance.
My recommendations is to use a product thats formulated for diesel fuel.
2016 2500 auto 4X4, 2017 Torque 325 Toyhauler, 2009 Challenger B5 Blue Classic 5.7 Hemi, 2012 Harley Davidson Softtail Classic. Sold 2014 Ram 1500 3.0 Ecodiesel, 2009 Ram 2500 6.7 Cummins, 2006 Ram 2500 5.9 Cummins, 2005 Ram 3500 5.9 Cummins, 1999 Ram 3500 5.9 Cummins.
pwr2tow is offline
post #9 of 154 (permalink) Old 01-18-2008, 09:04 AM
Boosted's Avatar
Nothing wrong with using a tcw3 rated 2 stroke oil at all. A friend that has a diesel shop has been using it in diesels for years and nevr a problem. He also said he has not seen the inside of a motor after using the 2 stroke oil as they have yet to get one back in from a failure. I run it in my truck and about ever 7 or 8 tanks i run some diesel clean through it.. Not a problem and my vp truck is allot quieter and feels like it has a few more ponies..
2011 3500 CC DRW 4X4 Lone Star SLT - Auto - Race Me Programmer - DPF Delete - EGR Delete - S&B Cold Air Intake, Diamond Eye 5" straight pipe exhaust into a 7" tip
12 SRT8 Challenger 604RWHP
Boosted is offline
post #10 of 154 (permalink) Old 01-18-2008, 09:13 AM
Originally Posted by SmokinRam01 View Post
***........still have to do the valve job, she has 120,000 miles on her........maybe this weekend
Valve job? you talking check/adjust or something else?
Good luck all :thumbsup
jefff929 is offline
post #11 of 154 (permalink) Old 01-18-2008, 01:37 PM
Arrow ATF .... BIG.... no no
Listen to what pwr2tow said about the ATF..... it is a HUGE MISTAKE to run it in your fuel.....
Go here and check it all out for yourself... several days worth of reading here .......
First Time w/2stroke Oil
Pay particular attention to what Mopar1973Man, WorkHorseDiesel, & Dorkweed have to say... IMO, of course...... :thumbsup
I have been running 2 Cycle for over 20 K miles ... my old truck has never run better!
No question about. I quit using any other additives about 11 or 12 K ago.
Just Wal Mart Super Tech 2 cycle .....
...1 ounce per gallon....
Have a good one & remember....... "Your mileage may vary." <>< __________________________________________________ __________
1993 D-250 LE Club Cab ... 5.9 L / 360cid CTD ... 5 spd Getrag ... SRW
269,000 miles... 21.8 MPG Hwy.
MDH / 030817
..Pretty much stock as far as I know... ??? ... .... 160 hp / 400 ft.lb. ...... 2 Cycle / 1oz. per gallon
cap-j is offline
post #12 of 154 (permalink) Old 01-18-2008, 03:24 PM
Question! Why would 2-stroke oil leave a tar like substance on injector tips? I thought the stuff was designed to burn cleanly.
Cap-J, no offense, but your 93 CTD doesn't have a VP-44. I'm just wondering what are the benefits of using 2-stroke in your truck. Maybe prolonging the life of the injectors and/or LP? Just curious.
2002 2500HD QC Laramie SLT SB; 2WD; Auto; 3:54 AS; Camper/Tow Pkgs; 4" Exhaust; Optima Redtops; Bilstein shocks; DSS; Isspro EV 30psi mechanical FP gauge; Vulcan 3/8ths LP relo kit to VP44; Mag-Hytec diff cover & tranny pan.
billmac is offline
