Amsoil EaBP100 Filter Cross Reference - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 09-09-2011, 11:58 PM Thread Starter
D45
D45's Avatar
iTrader Score: 16 reviews
I am also getting ready for an oil change.....
I just checked and Amoils Ea080 oil filter (that I have been using forever) is $24.80, FOR ONE FILTER!!!!
The Donaldson ELF7349 is the same exact filter, with just a different label.......for $13.00!!!
My Amsoil BMK-21 Bypass Kit uses an Amsoil EaBP100 oil filter, which is $41.40, FOR ONE FILTER!!!
I just need to now find a Donaldson cross reference for the bypass filter and I am set......anyone know???
I cannot believe how much Amsoil is charging for their oil filters......insane
04 QC/LB, 4WD, 305/555 HO CTD, 6" Lift, 37x13.50 Toyo Open Country MT on 20x10 BMF SOTA 8, MBRP 5", GDP Power-Flo, GDP Air Boss, GDP Grid Delete, IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special, SMARTY SR POD, ARP Head Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Edge CTS Monitor, Built 48RE Trans
D45 is offline
post #2 of 13 (permalink) Old 09-11-2011, 12:09 PM
DBLR's Avatar
I bought my Amsoil EA80 oil filter in July and it only cost me $18.95 from my Amsoil dealer ( that only $4.95 more then I pay for Fleetguard Stratapore oil filters) so don't know why yours charges you $24.80 unless your dealer is charging you retail price and not member wholesale price. Sounds like you need to find a new dealer like Duluth Diesel here on CF.
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's:
DBLR is offline
post #3 of 13 (permalink) Old 09-11-2011, 04:07 PM Thread Starter
D45
D45's Avatar
Regardless, I still found the Donaldson Endurance ELF7349 for $13, which is still cheaper...........and the same filter as the Ea080
D45 is offline
post #4 of 13 (permalink) Old 09-11-2011, 04:07 PM Thread Starter
D45
D45's Avatar
Bound and determined to find a cross reference for the EaBP100!
D45 is offline
post #5 of 13 (permalink) Old 09-11-2011, 07:14 PM
for one thing do not change the bypass filter until it no longer flows oil. as the larger holes fill up in the filter it starts to filter better, and at the time it clogs up it is at its best. at oil change interval just run the engine holding up the cap, if it still runs oil it is good. you will get more oil changes out of it than you would expect. when the 100 does need to be changed go to the 110. we all think the filter is made by luberfiner but they do not have a cross refrence. we use the 9750 and it has the exact same specifications except it is three times bigger and has a zink adder.
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline
post #6 of 13 (permalink) Old 09-12-2011, 04:29 PM Thread Starter
D45
D45's Avatar
The EaBP110 is much longer that the EaBP100
BP100: 7.25"
BP110: 10.44"
Not sure if I can squeeze it in to my mounting location or not.....
D45 is offline
post #7 of 13 (permalink) Old 09-12-2011, 04:30 PM Thread Starter
D45
D45's Avatar
So Lubrifiner 9750 is the cross reference to the BP110?
D45 is offline
post #8 of 13 (permalink) Old 09-14-2011, 10:26 PM
Duluth Diesel's Avatar
D45 don't pay full retail. Shoot me a PM if I can help you. Better prices are available. A few years ago I tried to answer this question, and what I came up with was that while you can get the Donaldson ELF7349 to match to the Eao80, the EABO100 is an AMSOIL proprietary filter. You may find filters with the same thread type and diameter to fit on the AMSOIL bypass mounts, but they won't be anywhere near 2 microns. Also, any AMSOIL warranty on their system and oil in your engine is voided if you mix and match non-AMSOIL parts. Anyway, let me know if I can assist you.
-Chuck
Duluth Diesel is offline
post #9 of 13 (permalink) Old 09-25-2011, 06:00 PM Thread Starter
D45
D45's Avatar
Bypass Engine Oil Filter Converter~1"-16 X 3/4"-16~New | eBay
Looks like someone found a way around the odd sized threads on the Amsoil kit
D45 is offline
post #10 of 13 (permalink) Old 09-25-2011, 07:46 PM
Did you check the prices from Chuck? That's where I get my stuff!
99 2500 QCSB
IAFF Local 706
firemanram is offline
The Following User Says Thank You to firemanram For This Useful Post:
Duluth Diesel (09-28-2011)
post #11 of 13 (permalink) Old 09-30-2011, 11:01 PM
firefighter56's Avatar
So lets just ignore the fact that you will not be getting the full advantage of the Amsoil filter when you swap it out for another. Instead of 2 microns absolute you may get 10 or more with another filter that you put on. Is it really worth the extra change that you will save? The EABP100 bypass filters are rated at 50K miles, so an extra $5-10 every 50K miles to void any warranty that Amsoil offers and not getting as good of protection? Not really worth it is it?
2006 Mega Cab 4X4 with a Cummins, Bully Dog with some Crazy guy, a full DTT transmission, DTT shift enhanser, Amsoil, Air Bags and compressor, 5" TBE with a Donaldson 100580, and a LONG wish list. IAFF Local 4416
firefighter56 is offline
post #12 of 13 (permalink) Old 10-01-2011, 01:12 AM
btolenti's Avatar
Are people really running bypass filters for 50k????? I use amsoil, and change the full flow every 10k and bypass and oil at 20k.
06 Silver QC 4x4 Auto
-Thuren leafs/Sway Bar/Kings/Carli bags, PSC Support, 37" Toyos, Hoss 17x9
-Smarty, Airdog100/Liberty Setup, ISSPRO Gauges,
btolenti is offline
