My Magdrive HHO test Results - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 12-22-2007, 10:14 PM   #1 (permalink)
Thumbs up My Magdrive HHO test Results
Ok I made the trip home with the new Magdrive HHO installed. The injection point was the cold air tube before the turbo. Here is how it went. I received the unit and quickly installed it. I only had a couple of hours on Wednesday and took another hour and a half on Thursday to finish it. I installed it in the parking lot where I’m staying. It was a little cold out so I didn’t spend the time on it as I should have and the facilities wasn’t the best garage for installing but it’s on.
The unit was producing a lot of bubbles so it appeared to be working well. On Friday I drove the truck to work which was about 25 miles. Noticed the rust looking water already.
After work we headed home for the holiday, around 1000 miles. Ran down the interstate at between 65 and 70, No wind, High humidity (foggy), temp 38 to 40F. The first tank of Diesel took us 478 miles on 25 gallons of fuel. That was 19+ mpg.:thumbsup The truck has never got over 15mpg. The truck has about 16,000 miles on it so it’s not broke in yet. After we filled up the fuel tank I started the truck and looked at the tube that the hydrogen exits the brick which was really rusty (thick) looking. I didn’t see any bubbles any more so I thought I would drain the circulator trap a lot of dirty water came out. I let it drain until clear. I then refilled the water reservoir. I didn’t see any bubbles (the hose seemed very stained) was eager to get going so we headed down the road. After 200 miles it was looking like the fuel was going fast. We stopped for a rest break and looked for a possible problem. Found the fuse was blown. Changed the fuse and the bubbles were back. Filled up the truck to get a fresh mpg reading. It was 16. Don’t know why so good (relatively speaking). I’m pretty sure now, that the fuse was blown out when I checked at the first fill up. Now on the road again. The mileage didn’t get any better as we ended up with a 30 mph head wind and I sped up to between 75 and 80mph. The last time I topped off the tank the truck got 14.6 mpg. It was making bubbles so it should have been working. That’s back to what I normally get. The first 500 miles was done in perfect weather conditions for testing this unit (no weather changes). I was very impressed with the 19 mpg. That’s more than 30% improvement. I think the washer motor went out as it won’t pump today. I don’t know when it went out but it was working during the last fill. I will be working on the system to get it setup better on the truck during the next couple of days. I hope this helps some. I'm very upbeat about this...I believe it does work and quite well. More time will tell.
Fuzzy
2006 Ram 2500, SB, 4X4, Auto, Edge, 5" home made air tube, Magdrive HHO, stock exhaust.
eslfuzzy is offline   Reply With Quote
Old 12-22-2007, 10:31 PM   #2 (permalink)
MXer Turned Diesel Nut
DNRCUSTOMS's Avatar
sounds pretty good, A headwind will kill mpg. So you think the unit works good, but it needs a little attention as far as ?? Why didn't you put in the intake plenium, I heard that is the optimium spot. Too much is lost through the turbo. Sounds good though
06 3500 Mega, BD R700s, Lots of guages,181/210 cam, Comp Studs, Ad150, STI 100s,Billet Trans, E-fans, EFI, Aero Turbine 5050xl, 3.5" lift, 35" Mckys 18" pro comps, Free Spin Kit, Mag Diff cover & dd trans pan,DNR ladder bars 680hp 1345trq
DNRCUSTOMS is offline   Reply With Quote
Old 12-23-2007, 10:42 AM   #3 (permalink)
I do think the unit works good. I just need to do a more perminate and cleaner install. I couldn't place it in the plenum because the of the pressure provided by the turbo. I need to either build a venturi or buy one. The venturi that comes with the unit is not a true venturi, more like an injector that places the gas in the center of the cold air stream. The unit needs a vacuum to pull the hydrogen into the engine. I also didn't get teh right water. I grabbed the drinking water instead of the distilled. That may be where the larger amount of rusty water is coming from.
Scott
Old 12-23-2007, 11:29 AM   #4 (permalink)
Posting to see results .
johntf is offline   Reply With Quote
Old 12-23-2007, 12:02 PM   #5 (permalink)
There is a disributor in AK that sells the venturis. He is very informative.
2007 5.9 4x4 6 speed Lone Star Quad cab. Equipped with Hot Edge Juice/Att straight piped. Isspro Fuel, Egt, Boost With Cool Blue hose, Amsoil 4091 and an IceBox
penche07 is offline   Reply With Quote
Old 12-23-2007, 12:25 PM   #6 (permalink)
pblankenship, on another post here, posted the phone number to the Arkansas dealer with the venturies. I do plan on checking them out.
it is here, http://www.cumminsforum.com/forum/ge...-gains-15.html.
I hope I did the link right.
Thanks, Fuzzy
Old 12-23-2007, 12:38 PM   #7 (permalink)
dakota001's Avatar
Fuzzy
What are you using with the distilled water, salt?...If you are then the water will turn brown very fast.. don't worry about the sludge...it's normal with salt.....also, your mileage will die if you're not using distilled water
2001 Dodge 2500 Quad Cab, Power Everything, Leather, 4x4, Auto, 3.55's, HX35W, Quadzilla Boost Fooler, Diablo Power Puck, BHAF, AmsOil, Holley Blue, Banjo Bolts, Banks 4" Turbo Back Exhaust,
dakota001 is offline   Reply With Quote
Old 12-23-2007, 01:40 PM   #8 (permalink)
Using 1/2 teaspoon of Baking soda per gallon. The instructions also discuss using distilled white vinegar (5% solution) to keep the unit clean. It says no mixing Just pour it in full strength and go. Has anyone tried this yet?
Fuzzy
Old 12-23-2007, 03:42 PM   #9 (permalink)
dakota001's Avatar
Fuzzy
I have tried pure vinegar to make HHO...it worked, but the output I thought was low. Went back to using baking soda but will try adding a tablespoon or two of vinegar to the mix. Also, how large is the hose coming from the unit to the injection point pre-turbo and what amp load are you drawing at 1/2 teaspoon baking soda?
Old 12-23-2007, 11:55 PM   #10 (permalink)
This is interesting stuff, do you have any pictures of your setup?
Whats next?
socal2ks is offline   Reply With Quote
Old 12-24-2007, 08:35 PM   #11 (permalink)
Anybody else have this setup, you guys almost have me convinced on buying one. Overall, how satisfied would you say you are with the system.
2001.5 2500 24V QC LB 4X4
2001.5CTD2500 is offline   Reply With Quote
Old 12-27-2007, 02:43 PM   #12 (permalink)
Ram04SLT's Avatar
Well from what I am reading thus far, it sounds promising!!!
But it sounds like it still needs some fine tuning of sorts
Anyone else have any reports on there findings? Please enlighten us!!!
Corey...... Proud member of the ICC
Silver, 04.5, CTD, 325/600, Quad Cab, SB, 4x4
S-Ring removed, all current flash updates...Of course all Mods and subject to FINAL APPROVAL by Higher Headquarters!!
Ram04SLT is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
