| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#85 (permalink) | |
#86 (permalink) |
www.Mopar1973Man.com
![]() Join Date: Feb 2006
've been watching several HHO threads on forums. I know if you build a big enough system you can gain some MPG's but how much are you losing to make the coversion from water to HHO? Here is a 30 Amp unit... ![]() Here is 85 Amp unit... ![]() Now you losing 30 to 85 Amps of electricity to the conversion process how much are you gain back from the production? this is what I want to know... Like myself I'm still running petroluem diesel fuel and pulling a good solid 21-23 MPG daily. I topped out once at 26.6 MPG. So when someone lese here can exceed me with HHO I start listening... ![]() If you don't trust electronics then do the math on my entry...
Michael Nelson - 2002 Dodge Cummins For Technical Assistance With Your 24V 2nd Generation Cummins - Click Here! Or Search CF.Com for an Answer Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
#87 (permalink) | |
#88 (permalink) |
I am new here but interested in how Diesels would be able to take advantage of HHO. In a gasoline (petrol) engine car, the principle is quite simple. You can trick the engine management system into thinking up to half the air is actually entering into the engine by simply reducing the voltage on the MAF or MAP sensor, it therefore injects half tha amount of fuel. What prevents detonation is the HHO. People are always hung up about energy in producing hydrogen vs. energy in combustion. In this particular case it is not so much the energy HHO combustion produces but rather the fact that it prevents detonation (pre-ignition due to lean mixture) also that's why you get a lot more savings with gasoline. With Diesel, the combustion process relies on detonation (or a controlled form of it). I am very new to diesels. I am not sure how diesels determine how much fuel to inject but if that can be tricked also to reduce the amount of fuel injected, you would see more gains in economy (not in power though). I will read this thread again to see if I missed anything.
#89 (permalink) |
Any more info K.C?
Black 2003 Dodge 2500 QCSB, 4X4, 5 speed, 6" Aussies, Smarty, KC Customs intake manifold, 90HP Dragon Flow Injectors, AirDog 150 , Quad Boost Fooler, DiPricol FP Guage, Isspro Performax: Rail Pressure, Pyro, Boost, Few other interior goodies |
#90 (permalink) |
The reason this doesn't violate the 2nd law is that breaking water down into HHO is not the same process as combustion. So yes, it can work without rewriting the laws of thermodynamics. Seems to me the biggest problem of getting good results in a modern engine is that the onboard computer isn't tuned to cohabitate with HHO. IF you can make a reliable HHO generator and IF you can reliably modify the engine's computer than there should be big advantages to this system. Seems like a good application of a custom Edge or Smarty with a reliable HHO generator would yield results. IMHO, until you can do both of these it's a waste of time. Probably much easier to make it work on a pre-EFI engine because the computer won't fight you. You simply tune the carb and ign to work with the alternate fuel source. |
#91 (permalink) | |
It's my name ^
![]() Join Date: Jan 2008
More fuel injected = more power Less fuel injected = less power You can inject more fuel to make more power pretty much until you run out of air, but the motor will run to hot, and destruct (burn up). (So, just ad more air )The less fuel you inject, you will make less power, until the engine is not getting enough fuel to even run, which is how idle rpm RPM is attained. Inject just enough fuel to keep the engine turning over. Air is not metered in a diesel. Pretty much, the more you put, the better. To inject less fuel, just pick up your foot a little bit. OF course, now you will be running a little less RPM.... but, you are injecting less fuel! LOL. Merrick
'98.5 3500 2wd 6-speed Dual Wheels, turbo's, and clutch. Almost 500HP(497/1020). Looking for a 2010 Ram... |
#92 (permalink) |
There is gonna be a write up in DieselPower mag next month. Heads up for those interested.
#94 (permalink) |
I havnt read it yet. I guess ill quit holding my breath for something groundbreaking.
#95 (permalink) | |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
