Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 06-17-2008, 05:05 PM   #61 (permalink)
mailman1175's Avatar
Originally Posted by 451Mopar View Post
...at this level it appears there is a small savings of about 1.5 to 2 cents per mile. (I dont have hand calculated mialage numbers for these driving conditions on Diesel only?)
For comparison sake, my cost per mile, diesel/Lucas is about $0.26. That's the truck in my sig, driving very conservatively with the latest hand-calculated (and adjusted for slightly oversized tires) figures. I'm probably running a little bit more cheaply than that, but I don't have any more recent numbers (the last tank had a low-pressure fuel pump change about 75 miles into it, so I lost some fuel to that, throwing my numbers off a bit). Mileage figured @ 17.9 mpg.
Using the numbers you've got above, you're running about $0.28/mile with propane.
'94 3500 DRW 4x4; 47RH; 4.10s; 10' flat bed; BHAF/heatshield; FBD budget 5" TBE w/ cat delete; boost and pyro pillar gauges
mailman1175 is offline   Reply With Quote
Old 06-17-2008, 10:52 PM   #62 (permalink)
451Mopar's Avatar
My average mialage when I do about 50% highway and 50% city is in the mid 17's too, but I have been avoiding some of my unnecessary longer trips (due to the fuel cost), so out of the 520 Miles I drove maybe about 100 miles of that was highway, the rest was short trips to work and the store where the truck dosen't even fully warm up, and I'm lucky to get past 40 MPH to get into overdrive, and the torque converter to lock up. I think under these conditions with diesel only I might have gotten 15-16 MPG?
2005 Ram 3500 QQ/LB, Cummins 610/48rfe, AFE2/Stg7, Edge Hot Juice, Magnaflow 5", Banks Techni-cooler/highram kit, MSD/Superchips Digital propane Injection.
451Mopar is offline   Reply With Quote
Old 07-09-2008, 10:21 AM   #63 (permalink)
what does the msd one use to inject the propane into the engine? an orfice in the intake hose of the turbo? any pics or ideas of how its setup?
88 Chevy airforce crewcab 1ton 6bt 47rh modified 4K GSK Pcola 2's starwheel and preboost tweaked.
72 Scout 4bt 1tons http://4btswaps.com/forum/showthread.php?t=1667
K204DR is offline   Reply With Quote
Old 07-09-2008, 06:33 PM   #64 (permalink)
451Mopar's Avatar
Here is the installation instructions:
http://www.msdignition.com/pdf/pro-d...148_PN4870.pdf
The orffice is at the regulator outlet, then it goes through a good sized tube (1/2" or 5/8"?) to a discharge fitting in the intake before the turbo.
Been running at 30% setting and mialage dropped a bit, and my propane place raised their prices to $2.71/gallon so I'm not seeing much if any fuel cost savings with the propane at that setting.
I might hook up the computer and tune the propane on-the-fly while having someone drive at highway speed, the increase the propane amount until the exhaust drone smooths out. I know at 50% setting the propane really reduces the exhaust drone.
Old 09-26-2008, 11:14 AM   #65 (permalink)
Infinitely Fast Snail
Snailpower's Avatar
any more updates 451?
2005 RAM 2500 QC SPORT OIL BURNER - Mineral Gray, 2WD, 48RE
2008 Chrysler T&C Limited 4.0- Brilliant Black, all the bells and whistles
1970 Dodge Coronet - FE5 Bright Red, white guts, 366 turbocharged small block, 518 trans
Snailpower is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
