| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#73 (permalink) | |
The Sermonator
Basically it's just a big battery, only instead of storing electricity with H and O2 as a byproduct, it was designed to produce H and O2 with stored electricity as the byproduct. So I'm assuming that the metal plates would be the same as in a battery. Maybe zinc and lead? Now keep in mind this was a big unit in a room all by itself. But it worked really well. We just vented the O2 to the atmosphere since we didn't use it. Also the H2O breaks down into twice as much H as O2. What I don't understand about this process is how the H helps the combustion process so that you get so much better emissions and mileage. I can see where the O2 would help, but I know the unit wouldn't produce enough O2 to make it worth your while. Just my 2¢
'05 2500 SLT 4X4, 5.9L, Brute Force Air Intake, CFM+ Intake Manifold, Bully Dog Triple Dog Downloader w Outlook Monitor, Aero Turbine muffler, FS2500 Bypass oil filter, Line-X bedliner, Peragon tonneau cover, XM Satellite radio. Now with propane injection!! ![]() "If you, O LORD, kept a record of sins, O Lord, who could stand? But with you there is forgiveness; therefore you are feared." Psalm 130:3-4 Last edited by Diesel Pastor : 11-22-2007 at 03:57 PM. Reason: corrected typo |
#74 (permalink) | |
The Sermonator
If there was a way to do this, then most of the new manifolds are already ported for H2O/methane, propane, NOS kits. The H2O/methane and propanet kits use Hobbs switches to measure boost to know when to inject the gas. I'm assuming you could inject gas into the manifold if you wanted to though.
'05 2500 SLT 4X4, 5.9L, Brute Force Air Intake, CFM+ Intake Manifold, Bully Dog Triple Dog Downloader w Outlook Monitor, Aero Turbine muffler, FS2500 Bypass oil filter, Line-X bedliner, Peragon tonneau cover, XM Satellite radio. Now with propane injection!! ![]() "If you, O LORD, kept a record of sins, O Lord, who could stand? But with you there is forgiveness; therefore you are feared." Psalm 130:3-4 |
#76 (permalink) | |
The Sermonator
#77 (permalink) | |
The Sermonator
Of course, I could just be experiencing the same confidence of the guy that jumped off a building thinking he could fly. As he passed the fourth floor on his way down he thought to himself "So far so good!"
#78 (permalink) | |
Hope that helps. |
#79 (permalink) | |
#80 (permalink) | |
Propane is a good alternative, the major difference here is I pay .53 per gallon of distilled water and a teaspoon of baking soda, I don't have to have a storage tank that takes up valuable space, and my system paid for itself within 4 weeks of installation saving me an average of $478 per week in fuel per truck. to address the other question you posted. Hydrogen being up to 5X more volatile then gasoline, allows the combustion in the chamber to happen faster and while the piston is at a higher point, so as it explodes, the piston is travelin further without expending that energy sooner.. LEt me try to explain this clearer so I understand it ![]() If the piston has to reach a certain point before combustion actually occurs in normal situation, say 20% of the way down, it is using energy from other pistons to create the energy to make that reaction occur. If that reaction could occur at say 10% of the way down instead of 20, it is using that additional energy for pushing the vehicle and not trying to explode the next reaction. Does that kind of help? I am not very good at explaining these things without going into a lot of detail which most would not read anyway. I am happy to answer any questions. |
#81 (permalink) |
Location: Washtucna WA, a small farm town in eastern Washington
dodgerep, have you had any success in setting up the venturis so that the system will accept the H at higher boost levels? I am a little skeptical putting this on a big rig because when they are pulling 105,500 down the road they are usually sitting at about 15 psi of boost, and this would be the typical situation that I would want to see the engine using the hydrogen, when it is under load. There is a distributor in Michigan, I think it was extreme truck and trailer, and they are going to do some R&D to see about setting up a venturi that will allow the system to accept the gas at about 18 psi of boost. So I think that I am going to wait a little bit.
2001 Cummins with AEM Intake, BD pusher pump, Edge J/A and Smarty stacked, FBD VP44, Jake Brake, HTT hx35/40 hybrid, Coaltrain 5 in. Exhaust, Coaltrain 100 hp sticks, RevTec leveler, Nitto's, Valair 500hp Clutch, Bully Dog Fluid Damper, Firestone Air Ride... |
#82 (permalink) | |
#83 (permalink) | |
Yes that is what I was concerned with. If in any case water past the bricks could that kill an engine. Dodgerep I was viewing the video they have on you tube and they placed the nozzles on the intake tube near the throttle body on a natuarlly aspirated engine. So your saying the safest position to install on our engines would be on the intake horn, basically where they plumb for a boost gauge, correct? If I installed an on and off switch when would you want the Mag Drive off. Would you want to let the engine reach operating temp then turn it on? Excuse all of my questions but this maybe a break through for all the high diesel prices. BTW thanks for sharing any of your information.
2007 5.9 4x4 6 speed Lone Star Quad cab. Equipped with Hot Edge Juice/Att straight piped. Isspro Fuel, Egt, Boost With Cool Blue hose, Amsoil 4091 and an IceBox |
#84 (permalink) | |
