| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#62 (permalink) |
Yes, those are gains that I have seen. I do tow, every day and I disclosed those results to. I opted to go with a 12a System and 3 addittional bricks, which is what is used on a big rig. The reason being is I needed to be able to go 2-3 months between cleaning the system. I am still required to flush the system every couple thousand miles, takes about 15 mintues and just requires water. I can do it while fueling up. Then every couple months I have to pull the system off and thoroughly clean it.
#63 (permalink) |
You should take some pics, so the rest of us can see how you ran your system. How does that work with the grid heaters? Where do you put the tubing into the intake of your truck? Any problems with the system yet? This is very interesting.
04.5 ctd cc, auto, 4x4, 2" leveling kit, Quad Commander, Walbro 392 Custom, Smarty Programmer SW3, Afe torque tube, EAAU 4090 air filter, All lubes synthetic amsoil, Muffler gone, Nasta s.s. nerf bars, Access Tonneau Cover NEWEST ADDITION - 2001 qc, auto, 4x4 lb |
#64 (permalink) |
The system is fairly small, and can be mounted a number of places on the truck, mine is mounted under the hood and on the right side firewall. The system is completely self contained and is fed into the intake just prior to the intake manifold, where the rubber boot is. The system does not effect your truck no matter how you have it set up, it does not store Hydrogen and it produces it as it is needed based on the vacuum created by your intake. There are several web sites that can explain how this works, I have the MagDrive system and am very happy with it, not a single problem. |
#65 (permalink) |
How does that work with the grid heaters? I'm just kind of cautious about putting an explosive gas into the intake before the heaters. Also what about freezing? Today it is only 29 degrees here this morning.
#66 (permalink) | |
MXer Turned Diesel Nut
Dodgerep.. What kind of boost #'s are you running towing. Also, running three bricks should be drawing a substantial amount of amps. compared to just one. So because you are running three bricks does that mean you are producing 3 times the hydrogen of one brick? If that is the case, mpg results will be much less with just a single unit. How many miles are you traveling before you need to refill with water supplu tank? thanks
2006 3500 Mega Cab, S&B intake, Tripple guage cluster, Line X, Skyjacker 2.5 lift, 5100 shocks, Aero Turbine 5" turbo back, bully dog , 305 Mckys on 20" moto metal's, EMS off road Free Spin Kit, Mag Hytec Diff cover, Amsoil Sythetic , Bushwacker fender flares, Custom mud flaps, 92 4X4 cummins 4" lift, 47rh trans, custom flip shacles in the rear, , |
#67 (permalink) | |
#68 (permalink) | |
Soemone was worried about freezing, when you start the truck, let them run up to normal temperature, and then turn the system on. (mine is in the engine compartment) the electrical charge will thaw any ice almost immediately as the system comes on line.
#69 (permalink) |
Sounds good, that is what I am going to do when I get mine. Have it set to ignition pwr, but on a switch so I can turn it on and off when I want. So running empy, no load. you went from say 20mpg to the mid 30's? Also you plumbed it right before the intake horn, wouldn't it be eiser to drill and tap the manifold insted of the intercooler boot. Plus it would be closer to the motor. Just my thought. What do ya think. there must be a reason why you put yours where you did??
#70 (permalink) |
Hopefully there is more than one positive feedback on this. I have become leary about things that sound to good to be true by learning the hard way. If this did what it said why doesn't everyone have them? Hopefully some more people will try this with good results. I have about gone broke trying things that people told me I coulndn't live without. I heard the good side of the propane issue and tried it and didn't see the gains I was told I was going to get and I ended up getting my money back. All I got was a bad cylinder that was blamed on the use of propane. I have ruined 2 CR's listening to other peoples advice so I think it is someone elses turn.
6/06, MegaCab, dually, 4x4, g56, 3.73's, S-06, 75hp sticks, ARP's, HTT62/65/13ss, ATS ex/man, cfm+, HGD, FASS150/95, 1R-0749, Quad BF, PG-7, PRXB, SB3250 sh dd, Fluidamper, air bags, Fastcoolers, mag-hytec diff covers. |
#71 (permalink) |
Yup, I here ya. Cummins dont like propane. They like water. But I;m sure you know that by now. I am gonna get one as soon as the distributer gets the parts in.
#72 (permalink) |
I wonder how dealers would view this as far as a warrenty issue on our trucks?
Diesel Freek 07 2500 RegCab. Long Box. 4x4 5.9L 4-speed auto. 3.73R, and Jake brake. Silverline 4" t/b exhaust. |
