Oil & Filter Longevity - Log - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 01-24-2011, 08:14 PM   #1 (permalink)
prestinb's Avatar
I purchased my 2008 used with 25k miles on the odometer. I drove it home and changed all the fluids (engine, G56, transfer case, front diff, and rear diff) to Amsoil products; however, I use the Fleetguard full flow oil filter. I also changed the fuel filter...to what I believe was the first time since it still had the old housing. Anyway, updated the housing to the new model and then drove it for 5k miles. At 30k miles, I deleted everything including the EGR cooler, installed the smarty jr. ME software, changed oil and filter again to establish a baseline without soot and fuel dilution. From that date, I have now driven 7k miles (37k total). I took an oil sample and sent it to Oil Analyzers to see where I stood. Attached is what I received back. Bottom line is they suggested leaving everything intact...including the oil filter...and conducting another check in an additional 7.5k miles (45k miles). I am going to try and keep this post updated as I increase in miles to see how well it compares to others who are running a bypass system.
2008 Dodge 3500 DRW Reg Cab 4x4 3.73 G56, SBDD3250, 37x12.5x17, H11 Studs, AD165, Arson III CP3 Kit, Shimmed FPRV, GDP Ladder Bars, EFILIVE
prestinb is offline   Reply With Quote
Old 01-28-2011, 09:18 PM   #2 (permalink)
Thundercraft's Avatar
looking good.
01 2500 SLT Laramie LB
6-Spd 4X4 LB 3.54s
Synthetic bumper to bumper
Thundercraft is offline   Reply With Quote
Old 01-28-2011, 11:26 PM   #3 (permalink)
I couldnt read that as it was killing my eys trying to read it. But anyway, I run the donaldson/amsoil oil filter and do an analysis at 10k, and I usually get around 12-15k before I have to swap the oil filter out, per blackstone. I personally would run the donaldson/amsoil filter as its a slightly better filter. 15micron vs 25micron.
2012 2500 CTD HO, Dual coolers, snow plow/cold weather prep, Line x, PPE 5inch tip, Bak Flip F1, Mopar fender flares, Husky mud flaps, Weather tech mats, Valvoline PBE/Donaldson filter, vision x light bar, Mag Hytec rear diff cover, Thuren overland suspension.
MPD106 is offline   Reply With Quote
Old 01-30-2011, 12:11 PM   #4 (permalink)
DBLR's Avatar
Darn good UOA.
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's:
DBLR is offline   Reply With Quote
Old 11-25-2011, 11:30 AM   #5 (permalink)
prestinb's Avatar
Just an update...
Just completed another oil analysis with 15k on the oil and filter...everything came back great. They suggested that I not change anything and resample in another 7500 miles. It took me quite a while from my last oil sample to accrue enough miles because I was deployed the entire summer...
Does anyone see anything wrong with continuing to use the stock full-flow Fleetguard filter? Obviously the oil is still being filtered efficiently...just didn't know if the filter would break down after a certain time frame...
prestinb (Brandon)
Old 11-26-2011, 09:23 AM   #6 (permalink)
wzeman's Avatar
I dont know anything wrong with it but It couldnt hurt to change it.
2002.5 Ram 3500 4X4 225000+ miles, Rebuilt NV4500 5 Speed, Val air 13" Upgraded Clutch, FRRP fuel pump, RV275 Injectors, Edge EZ, Scanguage 2, Extra Lights Front and Rear, Viper Alarm 350 Plus, Glowshift Fuel Pressure and Boost
wzeman is offline   Reply With Quote
Old 11-26-2011, 11:52 AM   #7 (permalink)
the filter will not deteriorate, and it filters better than a new one
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets
carl48 is offline   Reply With Quote
The Following User Says Thank You to carl48 For This Useful Post:
prestinb (11-29-2011)
Old 11-29-2011, 01:44 PM   #8 (permalink)
lco
lco's Avatar
where do you send your oil for analysis? how much does it cost?
-2010 2500 ccsb 4x4 68rfe bighorn(wife truck)
-DD-'95 rclb 2wd - burnin homebrew
-Street/Strip-'95 2500 rclb full billet 47rh, 13mm pump, sb66, DDP4's
lco is offline   Reply With Quote
Old 11-29-2011, 01:48 PM   #9 (permalink)
prestinb's Avatar
I purchase one of the following kits and all the directions are included...
AMSOIL - Oil Analysis Kits
prestinb (Brandon)
Old 11-30-2011, 03:00 PM   #10 (permalink)
DBLR's Avatar
My self I would not run the Fleetguard Stratapore oil filter longer then 1 year/15K (10K for severe duty) what ever one comes first, the cost to replace it is not all that much so why take a chance by not changing it out once a year!
Old 11-30-2011, 04:27 PM   #11 (permalink)
The Donaldson -7349 is a better choice than the Stratapore for the FF filter. Look up NAVYDOOD on BITOG for another example of long OCI (different truck spec, though).
2004.0 DODGE Ram QC/LB 2500 2WD/NV-5600 305/555 ISB. 7,940-lb. Stock. 192,000 miles/4,900-hrs @ 39-mph average. 35' 9k GVWR TT. 14.6-cpm solo & 25-cpm towing; 21-mpg average past 41k-miles
slowmover is offline   Reply With Quote
The Following User Says Thank You to slowmover For This Useful Post:
prestinb (12-07-2011)
Old 01-07-2012, 11:50 PM   #12 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
Good thread. Solid proof that running a top tier oil is worth the money to protect your Cummins engine. Better oil and better filtration wins, especially on modified engines that soot load at significantly heavier than stock rates. The AMSOIL EaO oil filters are 15 micron, whereas the Fleetguard Stratapore filters are 25 micron. For the best filtration to pull soot and particulates from your oil, consider a 2.00 micron AMSOIL Bypass Filtration system as well.
For information on what makes AMSOIL different than other synthetic oils, here is some good reading: *** Synthetic Oil Technology Explained ***
-Chuck
Proud Cummins Forum Sponsor since 2006 - SUPPORT YOUR CUMMINS FORUM SPONSORS, WE SUPPORT YOU. THANK YOU!
Specializing in AMSOIL everything
Duluth Diesel is offline   Reply With Quote
