Go Back   Dodge Cummins Diesel Forum > Speciality Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 03-30-2006, 08:52 PM   #13 (permalink)
Willy91's Avatar
If you want a chep additive try 2-cycle ashless oil.
img]http://i151.photobucket.com/albums/s152/bow2no1/im age.gif [/img][/url]
Willy91 is offline   Reply With Quote
Old 03-30-2006, 09:39 PM   #14 (permalink)
Moderator
Monster Truck's Avatar
Why would you put diesel in your tranny?
Originally Posted by illflem
Should I put Power Service in my tranny?
How about some diesel fuel?
95 Ext Cab SLT, Loaded, built 5spd with hurst, 3.54s, Leveled 4'' Lift 35'' Toyos, optima redtops, 4'' Straight into a 5'' bed kit with 6'' Mitres, Protech, Super B 57/66/14, Stage 2 Sticks, 3GSK, #60 Valve Springs, Stage 2 clutch, BHAF, Plateless, Boost and EGT on the pillar fuel pressure on the colum.
Monster Truck is offline   Reply With Quote
Old 03-31-2006, 06:54 AM   #15 (permalink)
Willy91's Avatar
Exactly, so why would you put ATF in your engine.
Old 03-31-2006, 08:18 AM   #16 (permalink)
Guest
Posts: n/a
I guess I dont understand........they make all kinna fuel additives and conditioners so whats the deal with ATF ?
cost wise the fuel additive is prolly about the same as ATF
Old 03-31-2006, 06:01 PM   #17 (permalink)
Tech Specialist
WorkhorseDiesel's Avatar
Well, if you guys are that serious about putting ATF in your fuel, why don't you just use Marvel Mystery Oil at it's recommended strength?? It's basically the same formulation as ATF, just without the harmful, non-fuel system additives commonly found in most types of trans fluid. And, here's something you might try and find interesting. If you have any Marvel Mystery Oil around, take a clear bottle and pour a little bit of it in and....viola! Guess what?? The MMO looks just like ATF...not a coincidence, hehehe. It's been a long standing fact that ATF was a good lubricity agent for diesel engines. The only drawback was the harmful additives. MMO just took the ball and ran with it. Well, I'll tell you from experience using MMO straight, full-strength, one-third quart (10.5 oz give or take), it really worked pretty good. Bumped my fuel mileage a bit too. So, before you go dumping Brand-X ATF fluid in your tank, maybe try the MMO straight and see what you think. Just my $.02
2001.5 White 2500 Reg-cab • 4x4 • NV4500 • 4.10 • BHAFWALBRO GSL392Edge Juice + AttitudeVALAIR HD OFEScangauge II • 315 Cooper S/T's • Optimas • custom black grille & blue graphics • ** Diesel Fuel Treatment is here **
WorkhorseDiesel is offline   Reply With Quote
Old 03-31-2006, 06:56 PM   #18 (permalink)
ndurbin's Avatar
Originally Posted by hammerman3406
power service.. truckers use it for a reason......
Causes it's cheap not necessarly the best. I have used Standyne Performance Formula in mine only in the winter to help with gelling.
http://img.photobucket.com/albums/v3...tinb4k/New.gif
1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck
2002 Ford F150 Super Cab - Daily Driver
ndurbin is offline   Reply With Quote
Old 03-31-2006, 07:34 PM   #19 (permalink)
Originally Posted by nycetrk
Atf is free from work so why not.
you're kidding right
sic-and-Fk'n tired of Trolls, CF included.
Good luck all
jefff929 is offline   Reply With Quote
Old 03-31-2006, 07:45 PM   #20 (permalink)
Moderator
Adding AFT is a leftover from the days when ATF was just oil and designed for diesel fuel additives weren't available.
Modern ATF is designed not to burn and will leave damaging ash deposits in your engine with little benefit.
Most of the guys recommending it are over 75 years old or heard from somebody over 75 years old.
Step into the present.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Both far from stock
Old 03-31-2006, 08:04 PM   #21 (permalink)
Guest
Posts: n/a
This from Dave Fritz's site
Any red dye in a tank of fuel is detectable by the sampler the DOT uses, even when diluted by a large quantity of undyed fuel. As little as 1/2 qt of ATF in a tank of fuel will be detected as untaxed fuel and can cause a major headache for the driver.
http://dodgeram.org/tech/dsl/FAQ/die...htm#onoff_fuel
Old 03-31-2006, 08:08 PM   #22 (permalink)
mschn99's Avatar
IF your GAS motor is having lifter noise....then running half to a full quart of ATF in the place of a quart of oil for ONE oil change interval can clean out the lifter SOMETIMES enough to keep it quiet....i have to do this on my explorer for lifter noise about once a year........but in a diesel....especially a modern diesel....there are too many detergents and the ATF is not near thick enough to run at all....it will just cause nothing but problems.....and i would NEVER put ANYTHING in your fuel but cetane additive........Marc
mschn99 is offline   Reply With Quote
Old 04-16-2006, 04:17 PM   #23 (permalink)
cummin69's Avatar
keep your ATF in your transmission!
i have ran ATF in my fuel for several years because i was told the crappy fuel needed extra lube. it served its purpose & did increase fuel mileage. the problems didnt come until modern technology brought the new injectors with o-rings. as anyone who has used ATF in place of power steering fluid knows, it will swell rubber parts. it only took me one (1) round of replacing injectors because the o-rings swelled to learn that i had been mis-informed about running ATF in fuel. this is a bad idea & reminds me of something mom said when i was young. if all your friends are gonna jump off a bridge, are you going to? im alot more careful who i listen to now.
cummin69 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
