Tried WMO heres results - Dodge Cummins Diesel Forum
post #1 of 148 (permalink) Old 01-29-2010, 04:15 PM Thread Starter
BridelessRacing's Avatar
This is all 6 injectors out of my 91 cummins motor. These were rebuilt about 6 months ago. For experementing I tried to run 50/50 diesel and waste motor oil. heated and filtered to 5 micron. On a 700 mile pull the truck got so weak it would slow down to 50 MPH on small hills. 1st Changed filters still no power, 2nd removed pump took it to tallulah injection 45 minutes on test stand no problems. Reinstalled pump and pulled injectors 3 were stuck open. on a pop tester thet wouldnt even chatter they just let diesel flow through.
Mine 2000 TDI jetta 5 Speed 47 MPG every day
Hers 2002 TDI beetle auto 40 MPG
Toy Mercedes 5 cyl turbo diesel powered YJ Jeep runs on WVO
BridelessRacing is offline
post #2 of 148 (permalink) Old 01-29-2010, 04:33 PM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
How far was it filtered down? That looks pretty rough, how many miles did you run it? were you running it straight or cut with diesel?
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #3 of 148 (permalink) Old 02-01-2010, 11:37 PM
Desert Dually's Avatar
Question
Man, that is weird. I've never heard of that happening, especially after only 700 miles! I've known guys who've run WMO for tens of thousands of miles in their 12 valve Cummins with nary a hiccup. Then again, I'm not sure at what ratio they ran it, maybe it was thinner mixture than yours? I am waiting for somebody "more in the know" to weigh in here with an opinion or two.
07 MegaCab SLT 4x4 Dually - 5.9 48RE, Line-X, 2" leveling kit, Safari Off-Road trackbar, flares, 315/70-17 Yokohama Geolander's, Powersteps, Tekonsha P-3, Firestone Ride-Rites
Desert Dually is offline
post #4 of 148 (permalink) Old 02-02-2010, 04:56 PM
carroll7645's Avatar
Is this your first time using WMO at this ratio? Did you use any synthetic oil? This was a perfectly running vehicle before you added the WMO?
87 K30, 94 12V, balanced, .030 Mahle, Piers HX40, 325cc, 3k, 370's, 47re, CTM shafts, 8in., 38pj's, 16x12 Alcoa, AGR crossover, Dana 70 80 4.11, 400/1000?
carroll7645 is offline
post #5 of 148 (permalink) Old 02-02-2010, 09:43 PM Thread Starter
1st time in this concentration. Oil was rotella 15/40. and yes truck ran fine before and runs good again now that I have 6 used injectors out of a wrecked truck in mine.
post #6 of 148 (permalink) Old 02-03-2010, 04:15 AM
Banned
Very Interesting, so what's your conclusion?
Challenger is offline
post #7 of 148 (permalink) Old 02-04-2010, 12:48 PM Thread Starter
I wont do that again
post #8 of 148 (permalink) Old 02-04-2010, 04:41 PM
Are you going to give up on WMO all together or just the high ratio's? I would call 50% a high ratio. I have been burning WMO for lots of years at 5% or less, including gear oil and synthetics, and still feel it's profitable. I'm surprised more WMO burners haven't chimed in.
post #9 of 148 (permalink) Old 02-04-2010, 05:55 PM
Banned
with the injectors stuck open like that would you think over time your cylinder walls might get washed down, or any other possible scenarios?
post #10 of 148 (permalink) Old 02-08-2010, 03:17 PM
Banned
This should be a alternative fuels sticky, can you give us an idea of your total costs to get your truck fixed and back to running normal. As well as down time. Were you able to limp back home to fix it,or did it have to be fixed on the road trip.
post #11 of 148 (permalink) Old 02-08-2010, 03:41 PM
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
What was the filter media you used to filter the oil?
patracy is offline
post #12 of 148 (permalink) Old 02-11-2010, 03:28 PM Thread Starter
[QUOTE This should be a alternative fuels sticky, can you give us an idea of your total costs to get your truck fixed and back to running normal. As well as down time. Were you able to limp back home to fix it,or did it have to be fixed on the road trip.[/QUOTE]
Truck drove back home on its own. One day of removing Injection pump. drive 40 miles to run on test stand at Tallulah Injection for 45 minutes. No problems with pump That cost me JB80 (being a chemical rep has advantages) Leave Tallulah drive 80 miles to wrecking yard to pull 6 used injectors for $10 each out of 95 cummins truck. drive back home 30 miles. tear all 12 injectors down to swap injector bodies. mine have 12mm threads for the fuel lines and the injectors I bought have 14mm so I just used the tips on my old bodies. To sum it up this cost me $60 in cash 5 cans of JB80 1 lost day of work. All the fuel I burned was in a customers Powerstroke. I had just built the rearend for. He told me to drive it and make sure he wouldnt have any problems so I did.
