2 Stroke Oil + Diesel, not so good - Dodge Cummins Diesel Forum
post #1 of 101 (permalink) Old 12-06-2009, 05:53 AM Thread Starter
ChrBro's Avatar
As a small engine mech i use to work in a lawn mower shop. Working on everything from chainsaws to garden tractors. Working on 2 stroke engines (especially the old 2 stroke lawn boy push mowers) i noticed alot of gum build up around the exhuast ports and exhuast related components. Like every 2 stroke you will notice gum build up in the exhuast components. this is why they call 2 stokes "Dirtier" engines is becuase they are dirty. The reason 2 stroke engines use the mixture of gas and oil as fuel is to lubricate the engine. They don't have oil filled crank cases becuase due to the porting of the cylinder the carb is ussually mounted ON the crank case. Having the crank case filled with oil it would interfere with the fuel getting sucked up from the carb to the cylinder. Most 2 stroke don't have head valves somewhat becuase of the gum build up caused by 2 stroke oil. Thats somewhat why they have ports in the cylinder is to iliminate moving valves. I thought i'd bring up this topic for the guys that think 2 stroke oil mixed in with thier diesel fuel would improve lubrication in thier injector systems in their diesel engines. using 2 stroke oil in diesels would form gum deposits on exhuast components such as valves, manifold walls, and even turbo impeller fins. Maybe resulting in higher EGT's and sticky valves? It might work well for the injector components but it probably aint so good for the exhuast components. Show me a used chainsaw engine that doesn't have greasy gum deposits around the exhuast ports or in the mufflor. Now to the amount of gum deposits it would produce in a diesel engine i don't if it would matter so much. You could maybe use a cleaner such as injector cleaner to solve this gumming issue but i don't think it would do much cleaning effect on the exhuast components after it was burnt in the cylinder. If you want to use a fuel additive to replace the lost lubricants in todays ULSD i would just use a diesel injector lubricant. Something that was designed for lubricating injection systems in diesel engines. I wouldn't want to worry about what 2 stroke oil does to my exhuast components. it's like dumping a bottle of orange crush in someone's fuel tank. A good way to put thier car out of commision. Just my 2 sense. I'm open for dispute.
2004 Dodge 2500 SLT quad cab 4x4 automatic, 5.9L 24V Cummins, 196,000k on it. Short box Burgandy, bone stock
ChrBro is offline
post #2 of 101 (permalink) Old 12-06-2009, 09:22 AM
PUNISHER629's Avatar
Ive been runnin 2stroke oil in mine and just took the engine apart and it was clean as could be. including turbos and valves
99 2500 5IN SUPERLIFT WITH 315/75/16, 12valve with enterprise cam, ats twins, ddp injectors, lazer cut dv,215pump.
SPECIAL THANKS TO BENZYS DIESEL PERFORMANCE!!!
PUNISHER629 is offline
The Following User Says Thank You to PUNISHER629 For This Useful Post:
DodgeMech (02-01-2010)
post #3 of 101 (permalink) Old 12-06-2009, 09:29 AM
This is going to get good:
99 2500 QCSB
IAFF Local 706
firemanram is offline
The Following 2 Users Say Thank You to firemanram For This Useful Post:
BlueBallz (01-31-2010), tyoneil54 (11-13-2014)
post #4 of 101 (permalink) Old 12-06-2009, 09:32 AM
rpainter's Avatar
you also have to take into account that we mix the 2-cycle a lot less than the chainsaws. I put 8oz to 10 oz of 2 cycle into 35 gallons of fuel.and also since diesel fuel has a higher btu value wouldn't than help burn off the oil prior to the ex valves opening???
2004.5 3500 a few upgrades. big turbo and big sticks
rpainter is offline
post #5 of 101 (permalink) Old 12-06-2009, 09:46 AM
Rather than buy diesel additives, I've been buying Sunoco Gold Diesel to get the extra lubricity in the ULSD. It's 2/L more than their regular diesel so a 100L fill-up would cost $2.00 more.
As for the 2-stroke oil, I think the consensus is to use ashless outboard motor oil (API TC-W3). See "Which Oil Is Right For You?" in Esso 2-Stroke Oil.
fraso is offline
post #6 of 101 (permalink) Old 12-06-2009, 11:45 AM
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
The reason you saw the gummed up small engines is because people overdose 2 stroke engines all the time. Also we're talking a very small ratio of 2 stroke oil. (A quart to 34 gallons) Third, the cyl temps and pressures are WAY different.
I've been running two stroke. I've had my exhaust manifold and turbo off several times. No gumming here. I'll keep running it.
patracy is offline
The Following 2 Users Say Thank You to patracy For This Useful Post:
DodgeMech (12-14-2009), norwood dodge (12-06-2009)
post #7 of 101 (permalink) Old 12-06-2009, 11:55 AM
dieseljay74's Avatar
iTrader Score: 4 reviews
I feel a cat fight comin...
'03 2500 CTD
RAPTOR RP100 W/GDP 2 MICRON INLINE KIT
6" TGC LIFT
37" MT/R Kevlars on XD Enduros
DIABLOSPORT PREDATOR w/AEM BRUTE FORCE CAI
BANKS HIGH RAM & 5" TBE w/30" FTE RESONATOR
GREAT LAKES CUMMINS CREW MEMBER
[SIGPIC][/SIGPIC]
dieseljay74 is offline
post #8 of 101 (permalink) Old 12-06-2009, 12:02 PM
COAL,GUNS,FREEDOM
CowboyCummins01's Avatar
just wait till mike gets here
08 Ram 2500 QCSB 4x4, 6.7, G56. aFe Stage 2,South Bend OFEK, FLO-PRO, Sinister Diesel ,Shibby Engineering,,EFI Live-Draconian Diesel, B&W, Pusher Intake, Edge CS2 Insight Breathing easier, and some other goodies in the bonnet......
01 Ram 2500 SCLB 4x4 5.9, 6 speed...Lots of goodies 380/815...SOLD
04.5 Chevy 2500hd LLY Duramax CCSB (The GF's) MBRP 4" Dp Back, S&B mouthpiece, AFE Stage 2 intake, Turbo Timer, B&W.
Wyoming Chapter Eastern VP
CowboyCummins01 is offline
post #9 of 101 (permalink) Old 12-06-2009, 12:09 PM
TJT-Rav's Avatar
That was my first thought also.
'01 3500 DRW 6 spd, AFE stg 2 , 4" turbo/exhaust brake back, 50hp injectors, Edge EZ, boost elbow, clutch, Amsoil dual bypass, AD150, a few Autometer gauges, 55 block, bunch of other crap not worth typing, big and shiny.
TJT-Rav is offline
post #10 of 101 (permalink) Old 12-06-2009, 12:25 PM
norwood dodge's Avatar
Mike will have fun with this one !!!!
I use 2 stroke oil also. No problems or signs of gumming any where !!
4.5 D3500 auto 4X4, Smarty Jr, van Aaken 3.1, Dipricol gauges, straight piped, silencer ring MIA,Stage II AFE w/ Amsoil nano-fiber filter, CFM+ and heater delete, Amsoil from end to end, Silver Bullet HD Trans w/ Billet converter !! 9/27/08 427hp and 815tq !!!
norwood dodge is offline
post #11 of 101 (permalink) Old 12-06-2009, 01:03 PM
allispuller1952's Avatar
i use it off and on, no complaints, quieter engine, better mpg, i havent used it in a while because i use Lucas add. i heard a guy say one time to use a regular additive every other couple fill ups rather than 2 stroke just to clean everything out good,
1994 dodge, 4x4, nv4500, single cab long bed, autometer guages, #100 plate slid, exhaust, and cold air intake.
allispuller1952 is offline
post #12 of 101 (permalink) Old 12-06-2009, 01:19 PM
Only in a HEMI
BBRam's Avatar
iTrader Score: 13 reviews
Not to worry here, there is no need for that stuff in my fuel system!
2012 Ram 2500 5.7L HEMI
2012 Dodge Challenger SRT8 6.4L HEMI
2015 Hellcat, and ya, it's got a HEMI
BBRam is offline
