So im out today and trying to find Rotella T 15w40 to do an oil change. Every ,and I mean every, store is out of Rotella T. I had a hard time believing this so I came home and started doing some searches and making some calls figuring Id have to order some. Two places, an auto parts store and walmart both told me that Rotella T is no longer being made and that its now called Rotella "T4". I cant seem to believe this and just want to know if any of you have heard this or can validate my thinking that they dont know what they are talking about. Ive gotta have my rotella t........
ok, thank you. i didnt know that. i guess we'll be running t4 then. maybe i should call shell and see how far off from original it is. do you know? is it the same formula with a new label? .......
found some write ups. looks like the new "T4" is replacing the "T". T4 will have the same ZDDP content as T but be better at wear and high temps.....heres some links.....guess its going to be T4....hope this helps the next person. thanks again for posting with me~
I just switched to valvoline in my cummins. Seems like I could smell the t4 every time I would shut the truck of or sitting idle. My truck has no blow by just the smell coming from the slobber tube.
OK question about smell since you brought it up im a new owner and I am.getting a heavy exhaust smell.in my cab when I'm at slow speed or idle and when I shut it off is that my exhaust leaking which is what I think or could it be the oil smell your talking about?
These are all my local walmart had. They didnt have T in the gallon jugs only the quart bottles. The T4 kind of threw me off and wanted to wait and find out more before buying. Or should I just go buy all of the quart bottles of T? I believe T5 is a synthetic blend and T6 is a full synthetic.
T5 is a synthetic blend (says on the jug) and T6 isn't full synthetic but enough to label it as such. IMHO just pick a jug I don't think there's that big of a difference if any between T and T4.
Don't know if it applies to the Diesel engines but I know in older high mileage gas engines (at least the ones I own) when I went from conventional oil to full synthetic they would seep oil from the seals. My 250-300k mile Honda, my charger 265k miles uses 1 qt of full syn but only 1/4 semi syn but my diesel with 215 and just towed 10k from KS to TX didn't burn a drop of valvoline blue jug.
Synthetic oil didn't cause the leaks it just found them.
Synthetic oil particulars are smaller than dino oil (think baseballs vs basketballs) so as the seals get old and wear out synthetic will leak before dino.
Well found out where the smell was coming from anyway it was one of my fuel supply lines the thread was Cross threaded and leaking fuel I took it all apart and that seems to have fixed just wanted to update thanks
