Welcome to the forum. I own a 2012 that I ordered in June of 2012, and took delivery August of 2012. I have always put in Valvoline Premium Blue 15/40. The EVIC gives me a 'Oil Change Due' message when the on board computer says its time. I know the manual states change oil every 7,500 miles or when prompted by the EVIC. I change when the change oil message appears. It will vary from owner to owner depending on driving habits.
If you live in a cold climate, it is recommended to use 5/40 oil, IIRC. That is for when temps are at Zero degrees or lower. Makes it easier on the engine for cold starts. Any oil that meets specs is good. I stayed with the Valvoline Premium blue.
To reset the oil minder, turn the key to the 'on' position, do not start. Push the go pedal to the floor 3 times within 10 seconds, turn key off. When I have the change oil message, it will disappear when I have done the reset correctly.
From my owners manual:
Engine Oil Viscosity (SAE Grade)
Use SAE 15W-40 MOPAR or an equivalent engine oil
meeting Chrysler Material Standard MS-10902. Products
meeting Cummins CES 20081 may also be used. The
identification of these engine oils is typically located on
the back of the oil container.
In ambient temperatures below 0°F (-18°C), SAE 5W-40
synthetic engine oil that meets Chrysler Materials Standard
MS-10902 and the API CJ-4 engine oil category is
required.
I have a Fumoto oil valve in place of the drain plug. Works very well, and lots less mess when changing oil. Get a 93mm, 16 fluted cap to fit on the end of the oil filter for removal. I use a long 3/8 extension with ratchet to remove the filter. Make sure the old "O" ring comes off when changing the oil filter. I add a quart of new oil to the oil filter before installing it.
A couple of links if you are interested.
https://www.genosgarage.com/category/oil-filters
https://www.genosgarage.com/category/fuel-filters
I use oil filter LF16035, and Fuel filter FS53000, both Fleetguard. Amazon has the better price on the FS53000 fuel filter tho. I order my oil & air filters from Genos in July, and get a years supply, when they have their 10% off sale.
Go here to down load a owners manual if you want.
https://www.mopar.com/ramtrucks/en-us/care/owner-manual.html
Go here, put in your vin #, you can view the build sheet for your truck.
https://dodge.custhelp.com/app/dodg...sion/L3RpbWUvMTQzOTY2MzU0OC9zaWQvcm0yTTZfdG0=
This is a great forum, ask it, you will get answers. Maybe not the one you want, but you will get them. I hope the above info is useful. Anymore questions, please feel free to ask.
You may find this useful too:
6.7L Cummins Maintenance Schedule:
Maintenance Procedure: Interval:** Description:
Oil & Oil Filter Change* 7,500 miles or 6 months Change engine oil & engine oil filter.
Lube Chassis 7,500 miles Grease/lubricate tie rods & front suspension components.
Air Filter Replacement Check every oil change. Replace as necessary. Truck is equipped with a "Filter Minder" to prompt replacement. Replace engine air filter.
Fuel Filter Replacement 15,000 miles or 12 months Replace diesel fuel filter.
Tire Rotation 7,500 miles Rotate tires to prevent uneven wear.
Change Front/Rear Axle Fluid 15,000 miles Change front & rear axle fluids (front on 4 wheel drive models only).
Change Transfer Case Fluid 60,000 miles or 48 months Change transfer case fluid (4 wheel drive models only).
Clean EGR Cooler 67,500 miles Clean EGR (exhaust gas recirculation) cooler.
Clean EGR Valve 67,500 miles Clean EGR (exhaust gas recirculation) valve.
Replace CCV Filter 67,500 miles Replace CCV (crankcase ventilation) filter.
Flush & Change Coolant 100,000 miles or 60 months Flush engine coolant system and replace with new coolant.
Transmission Service Normal: 120,000 miles
Severe Duty***: 60,000 miles Change automatic transmission fluid & auto transmission filter. Change manual transmission fluid.
Adjust Valve Lash 150,000 miles Adjust valve lash clearance.
