| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
Synthetic ATF
I'm coming up on a fluid and filter change and was wondering if it's ok to top off with valveoline synthetic atf, thats what is available locally. I don't know if the mopar fluid thats in it is synthetic or not and I don't know if I should mix them and I don't want to spend the money on a flush plus I just don't think it's needed. I'm at 60,000 miles btw. Any thoughts?
2006 5.9 2500 Quad Cab 4x4 SWB, 48RE, Smarty Jr, Icebox with S & B, Straight Pipe with FTE resonator, dipricol optix guages, 2" HBS level Kit, 35x12.50 Toyo MT's, BD flex plate, Goerend triple disc converter, Goerend VB |
#2 (permalink) |
it is ok we do it all the time
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets |
#3 (permalink) |
![]() Join Date: Dec 2007
All the ATF+4 is synthetic...What you need is really up to you! Stick with a quality fluid, i.e. Valvoline, Mopar, Amsoil and you cannot go wrong
2006 2wd 2500 - CFM intake - Amsoil oil bypass -Aero 4040XL Muffler - K&N Air - Cool Blue Hose - Delvac Rotella oil, everything else Amsoil - Alpin 505 / Blackbird nav / XM (XM 202 Sirius 197 - O&A RnF) , Optilube Summer blend Future: Coolant Filter, External tranny filter |
#4 (permalink) | |
Super Moderator
![]() Join Date: Nov 2006
The fluid in your transmission SHOULD already be ATF+4 and therefore a synthetic. Any brand ATF+4 will do fine, Mopar, Valvoline, Super Tech...etc etc...
Dennis 04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB 1997 Fleetwood Prowler 26.5" Check out: Rig of the Month! ![]() http://www.cumminsforum.com/forum/rig-month/ |
#5 (permalink) |
Location: Work in Montana but like to spend time on our New Mexico property
I have a MAG-HYTEC transmission pan with the drain plug, so it makes it easy to drain and fill. Unfortunately my T.C. doesn’t have a drain plug, but I drain and fill the trany pan with Amsoil ATF about every 10,000 miles. So far, my trany fluid seems to stay nice and pink. The drain plug also is magnetic, so it picks up any metal dust circulating in the oil. Heat kills transmissions, so I am a big advocate for running the absolute best transmission fluid and changing if often.
'06 5.9L, Quad, 4X4, 48RE, 3.73, Dr. Performance 2017 Module, Aero Turbine 4040XL, PSM Air Intake, Cool Hose, T.A.G., MAG-HYTEC, Amsoil 5W30, by-pass filter, Husky Mats, 265/70R17 Toyo Open Country H/T. "Jesus Christ is still the KING" |
#6 (permalink) |
I run amsoil syn universal atf, get on the amsoil site, become a perfered customer and youll get the stuff for the same price as off the shelf valvoline.
04 3500 DRW 4dr 4x4 CTD (555) few mods. 07 Trailblazer SS, LS2 400hp, magnaflow exhaust, tinted windows, full of Amsoil, leather, navigation, and every other possible option. |
