Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 10-27-2009, 01:42 AM   #1 (permalink)
L6ctdx's Avatar
Interested in making bio diesel!!!
I have plenty of space to have my own bio diesel set up but i'm pretty low on funding for this kind of project. What is the least costly way to make it happen? What kind of set ups do you guys have? any PM's and pictures would be great thanks!
1996 12v gauges. 5x16 EDM inj. dv's. fuel plate. valve springs. 4kgsk. built trans leveled on 35's with 17's. FOR SALE
L6ctdx is offline   Reply With Quote
Old 10-27-2009, 03:12 AM   #2 (permalink)
dirtydeeds's Avatar
appleseed processor only simpler. all you need is a way to pump from the bottom of the 55 gal drum back to the top. you can get a blue pump from harbor freight. plumbing fittings from home depot. probably less than $100, if you can weld yourself.
google: appleseed biodiesel
they sometimes make it more complicated than it is, pour in all ingredients, then pump from bottom to top for a couple hours. then let settle, drain until only bio comes out no glycerin. GOOD LUCK! way easier than it sounds
01 6spd.4X4Duallie, levelingkit, 22.5's Superchips, 4"straightpipe, K&Nfipk, Silencerringjustfellout Quadzillaboostfooler, Wastegate vacuumline cut and plugged, 30psiBoost, Customtracbar andfullheimsteeringintheworks!100hpinjectorsonbenc hneedtobeinstalled
dirtydeeds is offline   Reply With Quote
Old 11-12-2009, 10:52 PM   #3 (permalink)
TEX
TEX's Avatar
basicly you need one main tank and one smaller tank to make the methoxide in and a way to pump/recirculate (sp) and heat it.
more to it but thats a quick answer
like said check out appleseed or search craigslist many ppl r getting rid of their stuff.
2006 Mega 3500 DRW 4X4 6spd SLT Optix EGT,Boost,Trans-4510 W/Cool hose kit
2005 VW Passat TDI <----Wife's
Wake Up America
TEX is offline   Reply With Quote
