| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
#13 (permalink) | |
'05 2500 4x4 QC/SB, 33" BFG AT, Ranch Hands, 5" Magnaflow TBE, Banks Ram Air Intake, Banks Intercooler, Banks High Ram Intake Manifold, Fass 150gph, Smarty, MP-8, FTE Rail Cap, Autometer Phantom II: EGT, Boost, Tranny Temp, Fuel Pressure, Fumoto Valve, Amsoil |
#14 (permalink) |
Actually what strips the fuel of its lubricity is the process that is used in removing the sulfur. I used 2 stroke oil in my 7.3 (1oz per gal) and it was good for 1mpg on average interstate driving and it made it a little quieter than without it. I credit the mpg increase to the fact that is raises the BTU value of the fuel and like the idea of lubricating my fuel system and injectors considering the ULSF we have to run now. A good fuel additive will do the same as the two stroke oil, i use Stanadyne with great results.
2006 MEGA CAB 2500, Smarty Jr, K&N Filter. |
#15 (permalink) | |
'01 3500 Dually 6 spd, AFE stage 2 intake, AFE 4" exhaust brake back, 50hp injectors, 65hp Bulldog + boost elbow, HD clutch, AD 150 in the box in the spare bedroom..ugh, Amsoil dual bypass, NOT a 53 block, big and shiny. |
#16 (permalink) |
And it's like I said he might be wrong as well. Just because his job IS sulfur content doesn't mean he knows about its lubricity. But I think he SHOULD know. No biggie either way.
2006 Mega 2500. Smarty, XZII, HOT J/A (gauges), HTS trans, Edge TC, GM gov sol, AirDog II, Silverline muffler, 35's on 18's, 4" lift, -cat, -baffles, -silencer. 2001 Corvette C5. Tuned by BLUECAT. |
#17 (permalink) |
As stated above sulfur is not a lubricant. However, the process used to remove the sulfur also depletes the natural lubricating properties of the diesel. The refinery is supposed to re-add lubricants to the diesel, but you know how well they can be trusted. Also, I would much rather run low sulfur diesel and add two stroke oil than to have the old high sulfur fuel. The sulfur combines with the combustion byproducts in the engines oil to create sulfuric acid especially in short trip and excessive idling applications
2006 3500 SRW MC g56 4x4 Laramie / Isspros (FP, EGT, Boost) / GDP MK-2 micron fuel filter / severely allergic to cat & EPA / Smarty Jr 5.09 SW2 Tm4 Tq2 POD45 |
#18 (permalink) | |||
Hydroprocessing (refining) removes sulfur and significant amounts of polar and aromatic compounds that give conventional diesel fuel adequate lubricating capability. The refiners will add lubricants back into the fuel to meet the ASTM D975 standards for lubricity. Like any other company they are a bunch of penny pinchers, dont expect anything beyond bare minimum.
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO |
#19 (permalink) |
What brand of oil are you using?
2003 2500 4 Door 4x4 Laramie, Quadzilla Monster Air Intake, Pusher Intake Manifold, Quadzilla XZT 3 Setting 140hp Module, Boost Fooler, Siliencer Ring Out, Straight pipe With 5in Tip |
#20 (permalink) |
I run 16 oz every tank and I've noticed 2-3 mpg increase, The problem with the newer Diesel Fuel is they've cut down the sulfer to lower the emissions, The sulfer Is what gives the fuel the lubrication the engine needs, so Adding the TCW-3 2 stroke motor oil, Adds the lubrication back to the fuel... And it adds some SMOKE too....... I just buy the Cheap gallons at walmart, they are in the blue bottles......
93 1st gen with prince of DARKNESS 100 hp injectors, 60x14 turbo, custom 5 inch exhaust, pump upgrades.... ![]() 03 HO 6speed long bed Quad cab, quadzilla xzillerator 100 hp...... |
#21 (permalink) |
yup, been running 12oz to every tank for 2 years, truck runs smoother at idle on it....
2007 5.9 laramie QC,THUREN trac/stab/,MBRP'S,CFM,ARP'S,FASS,F1SPRINGS,STAGE3 CP3,TNT-R,MP-8,R700'S,IIDUAL RAIL,DDP'S,HELIX2,BD INTERCOOLER,HTS,W/METH,OPIE'S,11.82@113,video 12.01http://s33.photobucket.com/albums/d9...0417092040.flv |
#22 (permalink) |
Thanks for the suggestion on this guys. Went and got some of the tcw-3 yesterday and it smoothed out the motor and it just runs alot better with it. GOOD ADVICE GUYS THANKS
#23 (permalink) |
I am 100 miles from a Wal Mart, is any tcw-3 ashless two stroke oil any better than any other?
2005 Dodge 2500 Crew Cab Long Box,5.9L Cummins H.O., 48RE, 295/70/17 Toyo M/T's, Silencer Ring 'MIA', 5'' TBE |
#24 (permalink) | |
