| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
Amsoil Oil report for 5w30 HDD
Well I told a few of you that I would post this once I received my report back so here it is. BTW I also included the other 2 UOA's. =================================== Oil Brand Amsoil 5W-30 HDD Oil Filter Fleetguard Stratapore Sample Miles 7695 6564 6972 Vehicle Miles 34291 26396 20032 Sample Period 10/02/08 to 10/05/09 Make Up oil NONE IRON 77 37 41 CHROMIUM 2 2 1 LEAD 5 6 6 COPPER 6 7 7 TIN 0 0 0 ALUMINUM 2 3 6 NICKEL 0 0 0 SILVER 1 2 2 SILICON 5 6 10 BORON 2 2 4 SODIUM 2 6 0 MAGNESIUM 8 14 29 CALCIUM 3558 3620 4009 BARIUM 0 0 0 PHOSPHORUS 1173 1236 1328 ZINC 1334 1238 1533 MOLYBDENUM 0 1 3 TITANIUM 0 0 0 VANADIUM 0 0 0 POTASSIUM 16 0 0 FUEL (%VOL) 0.5 0.9 0.5 VIS @ 40C, cSt NA NA NA VIC @ 100C, cSt 11.2 11.37 11.19 WATER <.1 <.1 <.1 SOOT 1.0 0.7 0.5 TBN 9.24 10.39 10.03 OXID 36 5.0 4.0 NITR 15 8.0 6.0
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's |
| The Following 2 Users Say Thank You to DBLR For This Useful Post: | TEX (10-13-2009), Thundercraft (10-13-2009) |
#2 (permalink) |
![]() Join Date: Dec 2007
Iron looks a little high, and is steadily climbing...Is the same oil tested three times or is it a chage every time? Mine did the same thing until about 40k then dropped like a rock...
2006 2wd 2500 - CFM intake - Amsoil oil bypass -Aero 4040XL Muffler - K&N Air - Cool Blue Hose - Delvac Rotella oil, everything else Amsoil - Alpin 505 / Blackbird nav / XM (XM 202 Sirius 197 - O&A RnF) , Optilube Summer blend Future: Coolant Filter, External tranny filter |
#3 (permalink) |
TBN sure looks good for one year, silicone is nice & low too... good air filtration. Iron looks high at first glance (although it can safely go higher), but again, what are the mileage/time on the other samples. You changing the oil & going for round 2, or you keeping it in longer?
01 2500 SLT Laramie LB 6-Spd 4X4 LB 3.55s Synthetic bumper to bumper |
#4 (permalink) |
Glad I stumbled onto this thread. I just picked up this oil today and am going to install a bypass system before I do the oil change. Figured this pic would be a good addition to the topic.
'01 3500 Dually 6 spd, AFE stage 2 intake, AFE 4" exhaust brake back, 50hp injectors, 65hp Bulldog + boost elbow, HD clutch, AD 150 in the box in the spare bedroom..ugh, Amsoil dual bypass, NOT a 53 block, big and shiny. Last edited by TJT-Rav : 11-04-2009 at 04:16 AM. |
#5 (permalink) |
I changed the oil every time I took a oil sample being the oil had been in the engine one year that an I have an extended warranty so I have to change it out once a year. I'm not to worried about the Iron yet but I was not happy to see it show Potassium at 16 when it had been a zero the other two times so wonder why it showed up this time. I think it maybe time to save up and install an oil by pass system just to be safe. I see that I did not list the oil filter I used, it was a Fleetguard Stratapore and is the same brand filter for all 3 oil test. Oh in case some missed it I did list the miles for each sample and then total vehicle miles below. I see that when it showed up on the web page they got run closer together so I will try again to space them out below so its easier to read: Sample Miles: 7695------6564------ 6972 Vehicle Miles: 34291-----26396-----20032
#6 (permalink) |
DBLR, did you notice any reduction in oil pressure when you switched to a lighter weight oil?
07 MegaCab SLT 4x4 Dually - 5.9 48RE, Line-X, 2" leveling kit, Safari Off-Road trackbar, Smarty, flares, 315/70-17 Yokohama Geolander's, Powersteps, Tekonsha P-3, Firestone Ride-Rites |
#7 (permalink) |
No I did not, but I did notice less engine noise going from synthetic 5w40 Rotella to 5w30 HDD.
#8 (permalink) | |
A bypass will not help you in any of the concerns you have, Iran a Baldwin B50 and a Amsoil BP110 with a Amsoil full flow filter with no help in readings! Still get the bypass...just don't think it will be saving grace
#9 (permalink) |
Location: Work in Montana but like to spend time on our New Mexico property
Here's my remote Amsoil by-pass filter giving me close to a 14 quart capacity system. I run the Amsoil Series 3000 5W-30 Heavy Duty Diesel oil. I change the oil once a year (approximately 12,000-15,000 miles). Most engine wear is caused by 5 micron particles or larger, the Amsoil by-pass system filters down to less than 1 micron. This system will filter all 14 quarts in approximately 11 minuets. ![]()
'06 5.9L, Quad, 4X4, 48RE, 3.73, Dr. Performance 2017 Module, Aero Turbine 4040XL, PSM Air Intake, Cool Hose, T.A.G., MAG-HYTEC, Amsoil 5W30, by-pass filter, Husky Mats, 265/70R17 Toyo Open Country H/T. "Jesus Christ is still the KING" Last edited by dieselenthusiast : 11-03-2009 at 02:05 AM. |
#10 (permalink) |
nice set up, where did you get the filter mount from?
04 3500 DRW 4dr 4x4 CTD (555) few mods. 07 Trailblazer SS, LS2 400hp, magnaflow exhaust, tinted windows, full of Amsoil, leather, navigation, and every other possible option. |
#11 (permalink) |
Thank you, and I bought the filter mount from an Amsoil Dealer in California. I can PM you the phone number if you are interested.
'06 5.9L, Quad, 4X4, 48RE, 3.73, Dr. Performance 2017 Module, Aero Turbine 4040XL, PSM Air Intake, Cool Hose, T.A.G., MAG-HYTEC, Amsoil 5W30, by-pass filter, Husky Mats, 265/70R17 Toyo Open Country H/T. "Jesus Christ is still the KING" |
#12 (permalink) |
SBW
![]() Join Date: Mar 2008
Thanks for the post, been thinking about switching to this 5W30. that is a great set up dieselenthusiast. I'm going to have to look for that here in Canada.
2006 Silver Cummins QC 4x4, 5.9L. Icebox, cool tube, Magnaflow TBE duals, Smarty/MP-8, 4-gauges O/H + Quadz RP. BD Power flex plate, Maxflow fuel pump, intake horn, steering box stabilizer. II SilverB 66. ATS manifold ceramic-coated. Glacier Diesel 2um fuel filter+big line kit. 48RE: DTT,Sonnax plus DTT Shift Enhancer. FTE rail cap. Mag-Hytec DD pan and r.diff cover, Geno's condenser guard. ESPAR D5. Waiting for install: Vulcan silicone IC boots and Fluidampr |
