| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
Tech Specialist
My WVO experience......
Alright, I got a little impatient and went ahead and mixed some WVO in my truck. My WVO supply was starting to grow too big and I was running out of room while I was getting my BIO processor together. I have spent countless hours researching BIO and WVO for my trucks. I mixed 15 gal. of WVO and 15 gal. of regular diesel together. I filtered the WVO thru countless paint filters and then thru a 20 micron fuel filter before mixing it with the diesel and then pouring it in my truck. Temps here in AZ right now are in the 70's +or- 5deg. Night time we are in the high 30's low 40's. The real test will be tomarrow morning when I try to start it. So far, I have logged 68 miles and all I can say is wow. I noticed a immidiate change in engine noise. Sounds quieter. Acceleration also feels smoother and stronger. The entire truck just feels different in a good way. So far, the truck really seems to like it. Exhaust smells like burnt french fries. If the truck passes the "cold" start test in the morning...I may increase the WVO ratio. Expecially in the warmer weather coming soon. I am also going to install another fuel filter on the truck just in case. I dont think there is need for a fuel heater just yet....I think I can get by because I am in AZ....but for piece of mind....I will install another filter. If this continues to turns out good, I may just skip the BIO altogether and stick with the WVO...much easier. I will use this post to keep everyone updated with the good and bad of this experience. And the really cool part??? I spent $40 for 30 gallons of fuel....thats 1.33 per gal!Diesel at the pumps here is $2.65gal. Ok...lets hear the comments and suggestions.
2001 Chevy Xcab,4x4,LB7/Allison, Straight4in, predator. Previously a 12valver... Last edited by AZBLACKSMOKE : 01-28-2006 at 09:37 AM. |
#2 (permalink) |
Keep us updated. I'm going to hopefully expirement with WVO in the summer if things work out. 2nd filter was a good idea. Watch for it plugging since ya mixed such a heavy batch of WVO. I planned on running a 10% max. blend at first til the fuel system cleaned out. Then uping it slowly to find the best mix.
http://img.photobucket.com/albums/v3...tinb4k/New.gif 1994 2500 Reg. Cab 4x4 SLT Laramie CTD/DTT 330hp/765trq - Work Truck 2002 Ford F150 Super Cab - Daily Driver |
#3 (permalink) | |
Tech Specialist
The main thing is I think the temps are on my side....and I think that is very important. That and filtering. I learned today, you cant "over" filter this stuff. Stay tuned.......................
2001 Chevy Xcab,4x4,LB7/Allison, Straight4in, predator. Previously a 12valver... |
#5 (permalink) |
I can get some filters thru Amsoil at decent prices. They'd be Wix, Donaldson, or the Amsoil brand filters.
#6 (permalink) |
Tech Specialist
So far so good! The temp was about 40-45 degrees this morning and she fired right up. The idle speed was much lower till she warmed up...but it only took a min. longer than usual for it to idle normal. I think If I would have plugged in the block heater, I would've noticed anything different. I dont think I will go any more than 50/50 for the winter here. I think In the summer, it will be ok run a little more WVO. I dont wanna push my luck. Stay tuned.
#7 (permalink) |
I filter my WVO through 0.5 micron bag filters. As you said, you cannot over-filter WVO! I think the stock diesel filter is 10 micron - so if you aren't filtering it to that level, you may clog that filter sooner rather than later. Make sure there isn't any water to that WVO. A lot of people blend it - but don't get too ambitious with that ratio. If it starts getting too thick due to temperature drops, it will gell up and clog your filter... Do you have a fuel pressure gauge mounted before the IP? It would give you some indication of the filter becoming full. I think I'll break down and start blending as well - I still have to heat up the engine in order to burn straight WVO - if I can drag out the diesel refills, so much the better! |
#8 (permalink) |
Tech Specialist
Update.........
Logged about 75 miles today. Truck is running flawlesly. My buddy even commented on my exhaust smell. He didnt know I was running 50% WVO. As soon as thins tank is gone, I am going to pull my fuel filter to see if I can see anything abnormal. I havent had any problems yet. But something is telling me that this is all TOO easy. But...so far so good. I also let a sample of filtered to 10 micron WVO sit in a glass jar, just to see if I have anything settling or whatever. And I am suprised how clean it is. Its semi dark in color, but there are very few "floatys" in it. I think this is because I get my oil from a fancy, high class resturant and they change their oil frequently. Stay tuned......
#9 (permalink) | |
Tech Specialist
The fuel gauge probably isnt a bad idea. I am thinking of installing another filter on the truck. I havent had one single problem yet...but I think its still to early to tell. But the oil, temps, and general design of the trucks fuel system are on my side...so I think I'll be ok. To further my savings I am thinking of buying my diesel in bulk. I have a 600 gallon diesel tank. I really like the idea of vigerously mixing the two together for some reason. It just seems better to do that rather than dumping WVO in a tank of diesel. My test batches seem to verify this theory.... I thought about converting my truck to 100% WVO but this method doesnt fit my lifestyle. I only have a 10 mile commute to work. So the purging would be very time consuming and pointless. Thats why I decided to blend instead....I see the benefits of this right away....mainly...my wallet doesnt hurt as much and I can now drive more because the ole ladie doesnt freak out when it cost me $80+ to fill my truck up.
#11 (permalink) | |||
The final satisfaction comes in when I can finish up my biodiesel refinery and then do 100% of the trip off diesel! |
#12 (permalink) |
Moderator
Main problem folks run into running WVO is that there is no way to filter out dissolved sugar, salt, MSG, etc in the oil. Eventually this cokes up your injectors, valves and piston top. This is the reason many people who have touted WVO have switched to BD, the dissolved impurities are removed. Give it 25k for problems to start showing up. There was a guy at DTR raving about how he had been running heated WVO for 20k. He PMed me about month ago with engine rebuild questions, haven't seen him post about WVO since then.
Bill '95 2500 4wd auto '95 3500 5 speed heavy hauler Both far from stock |
