Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 06-07-2009, 02:15 PM   #1 (permalink)
littlecountry_22's Avatar
Amsoil gear lube
Hey was just wondering who out there runs amsoil in there diffs and if they saw any increase in mpg or any other gains from it. and what weight they are running. thanks
05 QC 2500 Georend tranny, Bully Dog Crazy Larry w/ Outlook, 5in magnaflo,AFE pro7, Banks high Flo intake elbow, Boost and Tranny gauges on steering columm
94 12 valve stock...for now
littlecountry_22 is offline   Reply With Quote
Old 06-07-2009, 02:22 PM   #2 (permalink)
Shainer's Avatar
Synthetic in the diffs should me mandatory if you ask me. Doesn’t have to be Amsoil. Don't expect MPG gains though, you can expect the gears to last a lot longer. That’s a lot of torque to redirect; synthetic is the best lube for the job.
'98 24v. 5 speed. 4" exhaust. Some extra air and fuel here and there... The anti-Union.
Shainer is offline   Reply With Quote
Old 06-08-2009, 08:00 PM   #3 (permalink)
Shup1's Avatar
Running the severe service 75w90...no increase in mileage, none expected. But if you go to the higher weight expect some slight mpg loss.
As above run a quality synthetic....whoever's you can get, also don't spray brake cleaner ect into the case when you have the cover off...just wipe out the gunk.
2006 2wd 2500 - CFM intake - Amsoil oil bypass -Aero 4040XL Muffler - K&N Air - Cool Blue Hose - Delvac Rotella oil, everything else Amsoil - Alpin 505 / Blackbird nav / XM (XM 202 Sirius 197 - O&A RnF) , Optilube Summer blend Future: Coolant Filter, External tranny filter
Shup1 is offline   Reply With Quote
Old 06-08-2009, 10:09 PM   #4 (permalink)
Thundercraft's Avatar
Haven't run enough tanks to say if any change in mileage.
01 2500 SLT Laramie LB
6-Spd 4X4 LB 3.55s
Synthetic bumper to bumper
Thundercraft is offline   Reply With Quote
Old 06-09-2009, 12:29 AM   #5 (permalink)
Shagginwagon's Avatar
X3^^^^^^^! Amsoil severe gear 75W-90.
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re
Isspro's, AFE Pro Dry, BMK-11, AMSOIL fluids, Debadged, CFM+
S-06, Mag-Hytec Covers
IAFF Local 1159
Shagginwagon is offline   Reply With Quote
Old 06-09-2009, 06:07 PM   #6 (permalink)
trbizwiz's Avatar
I have a mega cab too, they have the AA equivelant of the dana 60 front and rear axel. Amsoil shows the rear to have a limited slip, doesnt even show a 60 for the front. DO you run the limited slip additive in your diffs front or rear? I am trying to figure out which exact oils to run, but I want to do a full amsoil synthetic switch.
trbizwiz is offline   Reply With Quote
Old 06-09-2009, 07:39 PM   #7 (permalink)
Shup1's Avatar
Run the severe duty 75w90, no limited slip is needed..IF you had some chattering then maybe but I have not had any on mine in two years
Old 06-09-2009, 08:35 PM   #8 (permalink)
Ditto. No Friction modifier needed due to the helical gears. Just the gear lube. I have had no chattering.
IAFF Local 1159
Old 06-10-2009, 02:45 AM   #9 (permalink)
doesn't seem to be needed in our old Dana's either....
6-Spd 4X4 LB 3.55s
Old 06-10-2009, 03:57 AM   #10 (permalink)
ynots57's Avatar
i run 75/90 royal purple, easy to find, no special ordering. if your often towing heavy use a heavier oil. correct, you don't need any friction additives, you will find that some gear oils already have them anyway
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
Old 07-29-2009, 05:07 PM   #11 (permalink)
TEX
TEX's Avatar
so whats the diff between amsoil severe gear and amsoil long life synthetic gear lube?
i will only tow a 5er thats 9K empty, pick it up on friday so i dont know loaded wt. prob 11-12K so should i go with 75/90?
2006 Mega 3500 DRW 4X4 6spd SLT Optix EGT,Boost,Trans-4510 W/Cool hose kit
2005 VW Passat TDI <----Wife's
Wake Up America
TEX is offline   Reply With Quote
Old 07-29-2009, 07:50 PM   #12 (permalink)
calhoun's Avatar
I just changed mine and put in lucas 80w/90.
2003 3500 DRW, 305/555 Cummins, Quadcab, Longbed, 6spd, 4x4, 4in straight pipe with 5in tip, gutted torque box, homemade CAI, Silencer ring "MIA", 2gen intake, Diablo Sport Predator Programmer, Ranch hand rear bumper, B&W turnover goose neck ball
calhoun is offline   Reply With Quote
