Go Back   Dodge Cummins Diesel Forum > Specialty Forums > Alternative Fuels, Additives, Oils & Lubricants
Old 07-30-2009, 12:01 AM   #13 (permalink)
Shagginwagon's Avatar
Originally Posted by TEX View Post
so whats the diff between amsoil severe gear and amsoil long life synthetic gear lube?
i will only tow a 5er thats 9K empty, pick it up on friday so i dont know loaded wt. prob 11-12K so should i go with 75/90?
Send a PM to Duluth Diesel. He is an Amsoil rep here on the forum. He is a wealth of knowledge when it comes to Amsoil products.
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re
Isspro's, AFE Pro Dry, BMK-11, AMSOIL fluids, Debadged, CFM+
S-06, Mag-Hytec Covers
IAFF Local 1159
Shagginwagon is offline   Reply With Quote
Old 07-30-2009, 01:39 PM   #14 (permalink)
TEX
TEX's Avatar
ya i signed up as a dealer threw chuck (DD)
2006 Mega 3500 DRW 4X4 6spd SLT Optix EGT,Boost,Trans-4510 W/Cool hose kit
2005 VW Passat TDI <----Wife's
Wake Up America
TEX is offline   Reply With Quote
Old 07-30-2009, 02:00 PM   #15 (permalink)
O2CUMMINS's Avatar
I was wondering the same about the diff oil. Does the Dana 60& 80 use gaskets or the RTV
2002 Cummins 24v six speed, GR 6" AUSSIES,BHAF W/ K&N air intake tube and heat shield, Quadzilla Adrenaline, Valair DD, 62/65/12, pyro,boost,and fuel pressure gauges, 100 HP sticks, FASS 150.Chris.
O2CUMMINS is offline   Reply With Quote
Old 07-30-2009, 02:32 PM   #16 (permalink)
calhoun's Avatar
I changed mine diff oil this weekend and hit had a built in rubber seal.
2003 3500 DRW, 305/555 Cummins, Quadcab, Longbed, 6spd, 4x4, 4in straight pipe with 5in tip, gutted torque box, homemade CAI, Silencer ring "MIA", 2gen intake, Diablo Sport Predator Programmer, Ranch hand rear bumper, B&W turnover goose neck ball
calhoun is offline   Reply With Quote
The Following User Says Thank You to calhoun For This Useful Post:
O2CUMMINS (07-30-2009)
Old 07-30-2009, 04:41 PM   #17 (permalink)
trbizwiz's Avatar
rubber gasket on the AA axles.
2006 Mega Cab 2500, Cummins 5.9, G56,airaide intake and filter, awesome sound from a resonater thanks Wally, Quadzilla boost fooler, KMC rockstar 20's, goodyear MT/R 35's with kevlar
trbizwiz is offline   Reply With Quote
Old 07-31-2009, 09:46 AM   #18 (permalink)
Shup1's Avatar
I wondered the same but what I saw was that the long life has the ability to run 500k in commercial / over the road trucks...I feel that either is good and I use both (only because my stash was not enough to cover my sons truck and I installed the long life in his 93' F150 since a local dealer had it on the shelf), I even thought they appeared the same in color and flow (weights were same)....I would use either in confidence....But again maybe DD has a more technical description
2006 2wd 2500 - CFM intake - Amsoil oil bypass -Aero 4040XL Muffler - K&N Air - Cool Blue Hose - Delvac Rotella oil, everything else Amsoil - Alpin 505 / Blackbird nav / XM (XM 202 Sirius 197 - O&A RnF) , Optilube Summer blend Future: Coolant Filter, External tranny filter
Shup1 is offline   Reply With Quote
Old 08-08-2009, 05:07 PM   #19 (permalink)
TEX
TEX's Avatar
anyone ever figure out the diff in the 2 amsoil lubes?
Wake Up America
Old 09-08-2009, 02:34 AM   #20 (permalink)
Amsoil "severe gear" oils do not require friction modifiers , normally but they do have an additive if required....h.t.h...Fred
blacksmoker2 is offline   Reply With Quote
Old 09-22-2009, 09:40 PM   #21 (permalink)
Originally Posted by Shagginwagon View Post
Ditto. No Friction modifier needed due to the helical gears. Just the gear lube. I have had no chattering.
when i asked my service manager that i use he said and i quote ....
"Better to have it and not need it than to need it and not have it!"
but what do i know I am still runing the factory oil atleast 'till 100K
Only 2500 more to go.....
Two heads are better than one; even if one IS a GOAT-HEAD!
WOHOSS is offline   Reply With Quote
Old 09-23-2009, 02:39 PM   #22 (permalink)
DBLR's Avatar
Wohoss,
Don't know what year truck you have but the gear oil that was in my 06 was thin like 5w oil so was very glad to have changed it out at 10K. After seeing what they used I sure as heck would not run the factory gear oil for 100K and IIRC Dodge recommends it to be changed every 30K.. IIRC most quality synthetic gear oil already has friction modifier blended in and why most don't add it unless they have chatter.
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's
DBLR is offline   Reply With Quote
Old 09-23-2009, 02:57 PM   #23 (permalink)
ynots57's Avatar
here's 36,000 miles on oem lube, replaced with royal purple 70wt-90. to do it again I wouldn't go over 15,000 (10,000 if heavy useage) on oem lube. Going to run Royal Purple to 30,000 & change.
No increase in MPG
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
Old 11-06-2009, 04:51 PM   #24 (permalink)
I have 2006 2500 4x4 How many quarts for front and rear and do you need a tube of some kind to siphon out the gear oil. Im looking at severe gear 75/90. Ive been using 15/40 marine with ea filter on oil changes and been happy. Its time to change the gear oil. 43,500 on truck right now.
hogrider09 is offline   Reply With Quote
