| Alternative Fuels, Additives, Oils & Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...NO ADVERTISING |
Can I put my used oil in my fuel tank
So is it safe for me to do this. I'm changing my oil and Ive always heard of people doing this. Just wanted to see what you guys think. Its on an 03 cummins. If its safe..about how much should I put in per tank. Thanks |
#2 (permalink) |
I was just talking to a guy last nite who was telling me about doing this, not in a dodge but rather a semi. Also he told me about people running mineral oil as well. I personally would never do this but some people have more $$$ to spend on fixing things then I do.
05 3500 Yellow 6 speed, Mega cab dually fenders, Rumble Bee Scoop, Edge Juice w/ A2, Striker 2, Valair 3600 DD, 5" Silverline exhaust, Icebox with torque tube, Rokkteck, Quad Rail Gauge, Mag-Hytecs, Brite Box w/ Fogzilla |
#3 (permalink) |
Smokin Beast
Yes it is safe, run it through a filter first/strainer type deal to make sure it's clean. I used to use a gallon per fill up. And of course pour it in first, so the fuel will mix together. Cumnspwr
2001 2500 4x4 GB Full Billet Auto HTT Prostreet 66/14, 7X.012's, Some headwork, FMS, Smarty, Nitrous, Lots of other stuff! 750+HP |
#5 (permalink) |
Smokin Beast
Whitmore is right, Like I said make sure it is clean, run it through a strainer/filter first. If you don't want to filter it then don't use it. Other then that it's good lube and you are recycling. Cumnspwr
#6 (permalink) |
i definantly wouldn't do it. what are you going to gain from it that you can't gain from 2 stroke oil? not to mention the time it takes to filter all of it and wow what it would do to your fuel filter. and if its synthetic you definantly can't do it. i wouldnt risk it. Dexter
2002 Cummins SLT laramie. ex cab LB 4x4.Cat and muffler delete,Custom crank case vent,D*pricol gauges. 60lb boost,30lb fuel psi, and pyrometer. BD lift pump and BD pusher pump .Diamond plate bed rails, 6" mitre cut grandrocks stacks,MADS smarty, K&n torque tube and heat sheild with BHAF & scilencer ring MIA and some tranny work |
#7 (permalink) | |
Smokin Beast
#8 (permalink) |
2 Cycle Oil Guru
The only reason why I don't like the idea is...
http://www.frontiernet.net/~mopar197..._cycle_oil.htm
Michael Nelson - 2002 Dodge Cummins ![]() |
#9 (permalink) | |
sic-and-Fk'n tired of Trolls, CF included. Good luck all |
#12 (permalink) |
2 Cycle Oil Guru
Whitmore... think about it... Soot size would have to just below the filtering limit of the filter... So what ever the filter is good down to the soot is going to be just a bit smaller... Think about something else too... That's why we use oil that rated for diesel engines... It keeps the soot and dirty in supension so it can be filtered off... But if the particle is small enough it will pass through the filer and remain floating in the oil... Regardless if its synthetic or Dino oil... There are some diehard 1st gen owners that do it without any problems. But look at the pumps they got. Mechanical LP and that indistructible P-pump! Something you can't kill easy as a VP44...
