Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > Alberta Canada
Old 06-05-2008, 12:25 AM   #13 (permalink)
2500HeavyDuty's Avatar
A silencer ring is a metal baffle placed into the turbocharger inlet to reduce whistle from the turbocharger. It is installed in Ram truck engines at the request of Chrysler. The silencer ring has no effect on engine output, EGT, or boost levels.
Removal:
Remove the flex hose from the front of the turbo that goes to the breather. Just inside the turbo, you will see a snap ring that looks like a piston ring (charcoal color), very gently with a small flat blade screw driver, lift one end of the snap ring out of the groove, then continue to work around the snap ring, lifting it out of the groove. When the snap ring has been removed, you can easily remove the silencer ring.
Image on left is WITH the ring. Image on the right is WITH OUT the ring.
Suncoast StgIV trans. and Some kind of tuner that starts with an "E" and ends with an "e"
2500HeavyDuty is offline   Reply With Quote
Old 06-05-2008, 12:30 AM   #14 (permalink)
Devon E's Avatar
looks easy thanks guys if your ever in edmonton alberta i owe you a beer
05 2500 crew cab 33s ultra wheels smarty revo. Dr.perfomance preditor Volant cold air. Autometer Phantoms. A/C delete, Banks high ram and intercooler, ATS manifold .II silver 66 big brother combo NADP Race Trans big sticks its in the 11s 1/4 mile two 5 inch stacks
Devon E is offline   Reply With Quote
Old 06-28-2008, 01:21 PM   #15 (permalink)
Boodlum's Avatar
So other than the sweet turbo whistle, removing said ring does nothing performance wise? I love scaring moose and deer while flying down the highway!!
Boodlum is offline   Reply With Quote
Old 06-28-2008, 03:25 PM   #16 (permalink)
mainer's Avatar
Thanks, just went out and took mine off too, mileage went down a little, right foot just got a bit heavier. Sounds a lot better.
04.5 2500 5.9, 4x4, Turbo silencer went missing, Intake baffle gone, and gutted air box, Bully Dog Power Pup, 4" Silverline TBE, Isspro boost, pryo,and trans temp, H2 wheels and 305/70 R17 Nitto Terra Grapplers, Full Goerend Trans
mainer is offline   Reply With Quote
Old 06-28-2008, 03:41 PM   #17 (permalink)
redmonster_2005's Avatar
i just did mine too and i got the same results.
04.5 QCSB 6spd afe intake, smarty, gauges, straight piped to 8" stack
redmonster_2005 is online now   Reply With Quote
Old 06-28-2008, 03:49 PM   #18 (permalink)
r_anderson65's Avatar
It makes the whistle alittle less refined but it makes it much louder. At the competition diesel forum site some guys are saying that dyno tested they had proof of 7 hp gain. But i didnt notice a thing so im not sure i believe that.
Robert Anderson-04.5 Qc/Sb 4x4 9" Lift, 37's on 18's, Mag Hytec Covers,Full Synthetics Everywhere, S&B CAI, 4" Banks Exhaust, Banks 6 Gun w/PDA
r_anderson65 is offline   Reply With Quote
Old 06-28-2008, 04:14 PM   #19 (permalink)
BigBusa's Avatar
A few weeks ago I was talkin with a buddy of mine and I told him bout the silencer ring removal. He said he had never heard of doin that before. So since he has an aurora 3000 on his 04' we ventured into his garage to take a close look at his stock holset off the truck and see what would be involved in removing the ring. Removal was easy, but after looking into the turbo it seemed that doin this might actually hinder the proficiency of the turbo. With the ring on, it kind of funnels the air into the turbo from the intake, with it off there are multiple openings that surround the wheel (you can see what i'm talking about in the pics below) that appeared to me would create turbulence when the turbo is drawing air in at a rapid rate. I was going to remove mine but am thinking twice about it now
06' Quad-Cab 4x4 Big Horn Edition. 8" of lift, 37" Toyo M/T's on 18" MKW M19's, Edge Juice/Att. + Hot Unlock, K&N Cold Air Intake, ATS Intake Manifold, MBRP 5" TB, Bushwacker Flares painted to match, Tint.
BigBusa is offline   Reply With Quote
Old 06-29-2008, 02:19 AM   #20 (permalink)
TECH SPECIALIST
Bandit's Avatar
Well I took mine off and really didn't notice anything different....whoa is me.
>>>Mace<<<
94' 2500 12V "modified"
Bandit is online now   Reply With Quote
Old 06-29-2008, 12:46 PM   #21 (permalink)
BigBusa's Avatar
Not even the claimed "louder whistle" ?
Old 06-29-2008, 01:05 PM   #22 (permalink)
TECH SPECIALIST
Bandit's Avatar
NO, my 24V had a louder whistle stock then my 12V does now, I put a BHAF on it and maybe it improved a spec.
>>>Mace<<<
Old 07-06-2008, 09:41 PM   #23 (permalink)
ccmckee's Avatar
I got a lot more whistle when i pulled mine out. I added sound deadning material to my cab and i had to put the ring back in, the whistle was quite annoying on long drives with the trailer.Now it whines like a supercharger belt
'96 slt cc 2wd, #8 tst plate,215's,3k gsk,4"exhaust,afc modded,14.5*,new head,rebuilt auto w triple lok tc & shift kit,rebuilt diff,riderites w/onboard compressor,triple pillar boost,egt,tranny temp,402k km,305hp 686 ft/lbs
ccmckee is offline   Reply With Quote
Old 10-07-2008, 02:25 PM   #24 (permalink)
Four busted screw drivers and alot of cussin'...that damn thing ain't budgin'. Back to try again..that clip is in there so tight there is now waay you can pry it with any screwdriver I have...I'm getting ready to shoot it! Grrrrrrrrrrrrrrrrrr.
Hah!
Racer_X is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
