Radio Problems, Doesn't Work Now - Dodge Cummins Diesel Forum
Accessories & Installations Exterior, Interior & Electrical Accessories help
post #1 of 15 (permalink) Old 11-05-2008, 04:33 AM Thread Starter
Chris4937's Avatar
The other day I had to jump my friends car, while the truck was on during the jump my radio was working fine(stock CD player unit) I then shut the truck off, pulled the jumper cables off and put them away.
After turning the truck back on to leave the radio no longer worked, I can push the volume knob inwards and the clock will display for a few seconds but that's it. I tried pushing every button on the cd player, turning the ignition on/off a few times, and putting the ignition to accessory mode. I also pulled the radio out, unhooked the wire harness etc and re-connected it, still same issue.
I checked every fuse under the dash, nothing is blown(including the fuses with the retainers)
My truck didnt come with a key fob for keyless entry, as I was told it didn't have that option.
But after doing some research I found this website Dodge Ram RKE procedures
There it says
"Rolling Door Lock - Optional.
This feature is only available on vehicles equipped with Remote Keyless Entry. When this feature is enabled your door lock, will lock automatically if the speed is above 15 mph and both doors have been closed for the past 5 seconds. This feature is shipped enabled, but can be disabled you using the following procedure..."
However this is for a 2001, my truck is a 2002, but it does have the Rolling Door Lock feature, its currently enabled... Not sure if there is a factory alarm or something not allowing the radio to turn on. Also does this mean I have keyless entry and could go to the dealer and purchase a key fob?
I also would like to know if there are any programming features for my truck and how to change them, example would be radio staying on after ignition off but turns off when door opens, doors unlock when key is turned to off position...etc
Help would be appreciated, I need me some radio
2002 Ram 2500 4x4 Cummins SLT
1998 Camaro Z/28 383 Stroker
Chris4937 is offline
post #2 of 15 (permalink) Old 11-05-2008, 07:09 AM
Pursuing the Great Commission
JWH_03_Dodge's Avatar
are your dome lights not working also? gotta run soon, so I can't look it up, but I'd start by looking for a fuse that says "IOD" and its probably protected by a black shroud. Did you look under the hood too?
There are ways to turn all that off. The owners manual has a surprising amount of information.
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline
post #3 of 15 (permalink) Old 11-05-2008, 08:29 AM
Wow... there are 3 fuses going to the radio on your truck. Fuse 5, 8, and 12, all on the fuse panel in the cab.
The symptoms almost tell me that it sounds like its getting battery power, but not ignition. If fuse 8 is ok, i'd probe the red/white wire on the gray connector, and see if you get 12V with the ignition on.
John
post #4 of 15 (permalink) Old 11-05-2008, 01:53 PM Thread Starter
Chris4937's Avatar
I checked the IOD last night, and it was fine, cab lights were working during the radio issue.
I will check the num 8 fuse, then with the volt meter.
post #5 of 15 (permalink) Old 11-05-2008, 07:03 PM
i think it was a surge which popped a fuse,you are lucky it didnt blow the computers up
2007 dodge ram megacab 3500 4x4 dually 5.9l cummins with 5 inch stacks.
07-24-valve-MEGA-CAB-DRW is offline
post #6 of 15 (permalink) Old 11-05-2008, 08:46 PM Thread Starter
Chris4937's Avatar
Which fuse though? All of them appear to be fine.
The radio did the same thing to me 2 days before this issue came up, but after I started the truck again the radio was working fine. It worked fine up until yesterday.
post #7 of 15 (permalink) Old 11-05-2008, 08:51 PM
If all the fuses are good, i'd check for power on that red/white wire on the gray connector for the radio. If you're not getting power there with the key on, that's where your problem is, if you do, I'm leaning toward your radio, and would be best to try it in another truck to rule it out. any chance of finding a buddy with the same model radio to try your radio in his?
John
post #8 of 15 (permalink) Old 11-05-2008, 09:04 PM Thread Starter
Chris4937's Avatar
Thats what I was thinking aswell.
I got some time now to go mess with it. Hopefully I dont get too pissed off and end up hulk smashing the radio onto the ground.
Dont know of anyone with a truck that I could try it out in, I guess its time to get an aftermarket unit.
post #9 of 15 (permalink) Old 11-05-2008, 10:54 PM
does your clock come on,on your radio?if your clock is on then there is no fuse popped.
post #10 of 15 (permalink) Old 11-05-2008, 11:02 PM Thread Starter
Chris4937's Avatar
Yes the clock displays.
post #11 of 15 (permalink) Old 11-05-2008, 11:09 PM
ok well the fuse ISNT blown your radio is shorted out,so pretty much you need a new one,by the way, do you have a hayes or chelton repair book?if not you can get one from autozone.
post #12 of 15 (permalink) Old 11-05-2008, 11:24 PM Thread Starter
Chris4937's Avatar
I dont have any repair book, nor do I have a user manual.
I downloaded the 2001 user manual online, its a pdf file version.
I figured it was the radio, not a big deal, time for a nice head unit now.
