JL audio 1000/1 v2 amp - Dodge Cummins Diesel Forum
Accessories & Installations Exterior, Interior & Electrical Accessories help
post #1 of 6 (permalink) Old 02-12-2017, 11:38 PM Thread Starter
Tavo24vv's Avatar
Long story short I came across two Jl audio 1000/1 v2 amps along with 2 13.5 jl w7, I got them for a killer price so I couldn't pass it up. Problem is I have a single cab truck with no space to work with. What I ended up doing was taking the center console out and making a box to place the sub in and using the rear panel to mount the amps. So now that I have my bass problem resolved I now have a issue with my amps for my vocal side of the sound system. Since I have 2 of the same amps I would like to mount the amps mirroring each other. But the question is can I use my other 1000 watt 1 ohm amp for any sort of vocal speaker set up. It does have a HPF setting on it so I'm not sure. I've been told it's not possible but I would love to use that amp and not get rid of it. Any input would be great. Thanks guys.
Tavo24vv is offline
post #2 of 6 (permalink) Old 02-13-2017, 12:53 AM
Connor_H's Avatar
I'm guessing you have another 1000 watt monoblock amp? If that's the case, a vocal setup isn't very practical for that amp and I wouldn't use it, personally.
'97 2500 QCLB 4x4 4.10s, G56, 180 Pump - 4ks & .025s - B&B @18, 5x.016s - 155, S362sxe (62/68/.7) - 52 PSI, Fass 125 w/ Sump, Studs, 5" TBE, DOR 3" Short Arm Lift w/ Shackle Flip & Track Bar,
, Bilstein 5100s,
, Quad Cab Swap
Connor_H is offline
post #3 of 6 (permalink) Old 02-13-2017, 10:51 AM Thread Starter
Tavo24vv's Avatar
I do. Why is it not practical to use. And what is the down side if I was to use it. I'm fairly new to the sound system stuff so I'm not quite sure.
Tavo24vv is offline
post #4 of 6 (permalink) Old 02-13-2017, 03:17 PM
Connor_H's Avatar
1000 watts on one channel won't work for a vocal setup. You need multiple channels, for zoning/staging, and lower power per channel.
, Bilstein 5100s,
, Quad Cab Swap
Connor_H is offline
post #5 of 6 (permalink) Old 02-13-2017, 10:41 PM Thread Starter
Tavo24vv's Avatar
How much vocal power should I look into So the bass doesn't over power my vocals.
Tavo24vv is offline
post #6 of 6 (permalink) Old 02-13-2017, 11:24 PM
Fern's Avatar
It really depends on what speakers you have for the highs.
I'd say between 50-100 x 4 channel amp.
I have 500 watts for 2 jL 10s and just used the stock stereo and the stock speakers and it is plenty.
01 Sport 4x, Quad w/ PV2, Smarty, PhatShaft 62/65/14, 4" turbo back, FASS, Amsoil, 100hp DFI's, TunnelRam, H2 alloys, 5" lift, HD steering, Posi-Lok, Inglewood Trans w/ billet parts. "My work truck"
Fern is offline
