| 98.5-02 Technical & Diagnostics What is it, what does it do... Pretty much the learning center for the 98.5-2002 Dodge Diesel's. |
Hogg Innovations
Instrument cluster diagnostics
I ran across something that most people dont know about on these trucks. I Have tried this trick on an 01 and my 02 truck, but I can't say if it works on any older models. Beware your trip odometer will be reset after the test. Start the test with the ignition off. Press the odo/trip odometer button and while holding it, turn the ignition on but do not start the truck. Continue holding the button until "chec" appears in the odometer window. The instrument cluster will then begin its self diagnostic mode. when it is finished, the door alarm will chime several times and the normal pre-start lights will be lit. If there is a problem, it will spit out a 3 digit code in the odometer window. Record it and then push the trip button to continue the test. INSTRUMENT CLUSTER FAILURE MESSAGE Message Description Correction 110 A failure has been identified in the cluster CPU, RAM, or EEPROM. 1. Replace the faulty cluster. 900 The CCD data bus is not operational. 1. Check the CCD data bus connections at the cluster. 2. Check the cluster fuses. 3. Check the CCD data bus bias. 4. Check the CCD data bus voltage. 5. Check the CCD data bus terminations. 920 The cluster is not receiving a vehicle speed message from the PCM. 1. Check the PCM software level and reflash if required. 2. Use a DRBIIIT scan tool to verify that the vehicle speed message is being sent by the PCM. 921 The cluster is not receiving a distance pulse message from the PCM. 1. Check the PCM software level and reflash if required. 2. Use a DRBIIIT scan tool to verify that the distance pulse message is being sent by the PCM. 940 The cluster is not receiving an airbag lamp-on message from the ACM. 1. Check the CCD data bus connections at the ACM. 2. Check the ACM fuse. 950 The cluster is not receiving an ABS lamp-on message from the CAB. 1. Check the CCD data bus connections at the CAB. 2. Check the CAB fuse. 999 An error has been discovered. 1. Record the failure message. 2. Depress the trip odometer reset button to continue the Self-Diagnostic Test. Hope this helps someone!!!
02.5 2500 4X4 reg cab white HO 6spd Tapped Edge Comp with TST plate and Bosch RV 275 sticks. Stacks by Hogg innovations to roll the coal... Hogg innovations lift pump/filter big line setup, Multi function shifter stick,Solenoid High Idle LED's all over, and CF stickers too!! ![]() |
#2 (permalink) |
Great information, thank you.
1999 2500 Quad Cab, 5spd, 4X4, 3.55 LSD, 152K miles, Buckstop w/9K winch, Torque King M/S, K&N FI Perf Kit, 275HP Inj., TST PM3/Smarty stack, PDR boots, Wabro/Areomotive and 1/2" line, PAC Brake w/SWAC, Summit Turbo back 4" pipe, EZ drain, silencer ring MIA, pyro/boost/FP gauges, SBC Con OFE w/HD Adj Hyd, Brite Box, DSS, Centramatics, BFG LT285/75R16/E |
#3 (permalink) |
2 Cycle Oil Guru
I add to this... I've got a page with pictures showing the same thing but I don't have the troubleshooting part though... Cluster Test Maybe a little visual will help people...
Michael Nelson - 2002 Dodge Cummins ![]() |
