Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Technical & Diagnostics
98.5-02 Technical & Diagnostics What is it, what does it do... Pretty much the learning center for the 98.5-2002 Dodge Diesel's.
Old 10-30-2005, 10:11 PM   #1 (permalink)
Guest
Posts: n/a
*Intake Air temp IAT - A
Applys to all 98.5 and up Cummins.The intake air temp sensor is located on the drivers side of the motor just above the lift pump and rearward of the fuel filter on the intake manifold. The IAT sensor reads the manifold air temp and sends a signal to the ECM to regulate intake ait grid heaters,fuel timing,fuel control, As fuel to air temps vary the sensors resistence changes the signal to the ECM. It has been my experience that if an exhaust brake is used that the IAT can become fouled with soot and the sensor becomes inaccurate, I personally clean mine every 10k miles with carburator cleanor, this make the allmighty Cummins happy and idles better as well as better overall performance including MPG.
Cheers, Kevin
Old 11-14-2005, 11:34 PM   #2 (permalink)
Guest
Posts: n/a
Great tech article and pics of the IAT cleaning HERE
Old 11-29-2006, 10:50 PM   #3 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
I've got a write up as well that is very similar...
IAT Sensor Cleaning and Testing...
IAT Sensor
And Map Sensor Cleaning...
MAP Sensor
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
Mopar1973Man is online now   Reply With Quote
