Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Technical & Diagnostics
98.5-02 Technical & Diagnostics What is it, what does it do... Pretty much the learning center for the 98.5-2002 Dodge Diesel's.
Old 10-30-2005, 05:32 PM   #1 (permalink)
Guest
Posts: n/a
Power Control Module (PCM)
Other wise known as JTEC??? Dont ask me why. The PCM is under the hood on 98.5 and up electronic controled Cummins motors. It is mounted to the firewall near the passenger hood hinge, As input signals to the PCM change the PCM adjustes its response to the output devices, The PCM controls
charging system
speed control
transmission
air conditioning
APPS
CPS
Auto shut down (ASD)
Battery temp
Battery voltage
Brake switch
CCD+
CCD-
CPS
Data link port for scan tool
fuel level
Alternator output
Ignition
Output shaft speed
Overdrive if auto
Cruze control
Tranny temp auto
Tranny pressure auto
ABS braking
SO next time you have the high pressure washer fired up stay away from the PCM or it will bite you
Cheers, Kevin
Old 07-22-2006, 04:48 PM   #2 (permalink)
8V92TA's Avatar
Thumbs up
JTEC stands for Jeep Truck Engine Controller.
8V92TA is offline   Reply With Quote
Old 08-03-2006, 03:06 PM   #3 (permalink)
Hey Whitmore where is the best place to get a replacement PCM? I have already purchased one from a dealership located near me only to find that the part was faulty. Come to find out the dealership and general manager are refusing to warranty the faulty part. So I have filed complaints through the BBB and Chrsyler so we will see what happens there. Anywho I am out $550 for the PCM and my truck is still down so I was just curious if you knew anyone who you would vouch for that might have a new/used PCM. Thanks
Josh :fist:
mgstroker95 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
