Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Technical & Diagnostics
98.5-02 Technical & Diagnostics What is it, what does it do... Pretty much the learning center for the 98.5-2002 Dodge Diesel's.
Old 06-30-2006, 08:14 AM   #1 (permalink)
Interesting VP injection pump failure article
http://www.bluechipdiesel.com/inject...pfailures.html
It is an interesting article on VP pump failures and the why.
Done.Almost, lol:93 5.9 cummins motor, hx35, hx55 twins, POD injectors, water to air intercooler, and air to air aftercooler, BOV, in-cab fully adjustable dual wastgates, alcohol/water injection, C6 full manual pullin tranny, Ford F350 1-ton 4x4 pullin machine.
seeker1056 is offline   Reply With Quote
Old 07-07-2006, 10:26 AM   #2 (permalink)
This is a dated article. The rotor siezure problem is rare now, but was more common with early VP44s. The biggest mechanical problem now is high pressure chamber o-ring seal and diaphram failures. Some times there are also timing piston siezures. The above two failures cause the 0216 code. My belief is the article is right on, concerning fuel pressure requirements, and not necessarily factual on electronic failures caused by the addition of fueling boxes.
Bart Timothy is offline   Reply With Quote
Old 07-07-2006, 11:32 PM   #3 (permalink)
LinemanTater's Avatar
I may have read it before..........but interesting!!!!!
91k miles on the inj pump, still running strong w/standyne lubricity formula but ya still never know.............
07,5.9, 4wd Mega Cab, 3500, Dually, Auto, Rhino Liner, SMARTY CR, (Thanks To Mr. Wagner!!) Quadzilla Commander, (Diesel Nut) ICEBOX Intake w/DPP Torque Tube, Fleetguard FS20000 Lubricity adding, 5 micron Fuel Filter setup. (W/Custom made Bracket)
LinemanTater is offline   Reply With Quote
Old 09-27-2006, 12:05 AM   #4 (permalink)
cumminspower79's Avatar
So if lubrication is a factor, especially with this low sulpher diesel like we have here in CA, what does everybody suggest for more lube. Ive heared of no ash 2 cycle oil, marval mystery, etc., whats the best solution?
2002 Quad Cab Short Bed 4x4 4.10 gears auto, AFE intake, 4inch turbo back exhaust, Hypertech Power programmer, isspro fuel pres. pyro trans temp, boost gauges.
cumminspower79 is offline   Reply With Quote
Old 11-29-2006, 07:43 PM   #5 (permalink)
2 Cycle Oil Guru
Mopar1973Man's Avatar
Use the two cycle oil!!
Don't use MMO... It contains Mineral Spirits, Benzene, Naptha... It's not a lubricant at all... It might cause problems...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
