What is an ADD .... - A - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Technical & Diagnostics
98.5-02 Technical & Diagnostics What is it, what does it do... Pretty much the learning center for the 98.5-2002 Dodge Diesel's.
Old 04-15-2006, 02:50 PM   #1 (permalink)
Guest
Guest
Posts: n/a
2002
2001
1998.5-2000
This simple plug-in device allows you to get an additional 10% horsepower and torque from your engine! Add it with injectors for a super combination! When using the ADD with boxes that have a MAP Sensor provision, always plug the ADD directly into the MAP Sensor, then plug the box harness to the ADD. To explain it simply: The ADD has a microprocessor that acts as a electronic voltage regulator, thus never allowing the engine computer to see an over-boost signal.
Thanks To www.haisleymachine.com/
Old 04-15-2006, 07:15 PM   #2 (permalink)
Jakey's'01H.O.'s Avatar
Talking
ive got mccabes...and its the same as haisleys...ohh
'01 ETH/SO VP.
airdog II. smarty. compounds. rev springs. hellmann sump. lincoln logg'd 80.
Jakey's'01H.O. is offline   Reply With Quote
Old 04-15-2006, 09:29 PM   #3 (permalink)
MI Chapter President
IC-Smoke's Avatar
If you have the drag comp you dont need it, It keeps the truck from de-fueling. I had one on my truck and it was nice but I dont think its worth the money. If youre running a defueling box there is no sence in purchasing this from haisley. You plug your wastegate elbow as well
Ian
IAN COLEMAN - President Great Lakes CUMMINS Crew
1990,2001,2005,1962 M37
IC-Smoke is offline   Reply With Quote
Old 04-15-2006, 10:16 PM   #4 (permalink)
Talking
yea...acts as drag comp, mine was $40, and drag upgrade was $100..lol so it was worth saving a few bucks...
'01 ETH/SO VP.
Old 04-15-2006, 10:21 PM   #5 (permalink)
Guest
Guest
Posts: n/a
I wont be running A Combo Box so this is a must for me to Boost Fool
DM
Old 04-15-2006, 10:28 PM   #6 (permalink)
did you just call me a fool???
'01 ETH/SO VP.
Old 04-15-2006, 11:03 PM   #7 (permalink)
Guest
Guest
Posts: n/a
if your an ADD then yes ,,,,
Maybe you have ADD
DM
Old 04-16-2006, 11:11 AM   #8 (permalink)
This account not in use anymore!!
wtfd6's Avatar
so an ADD is nothing more than a boost fooler. ok. as far as i know all edge boxes and the like do the same function. am i wrong?
2000 Ram3500
MaumeeValleyPullers
Proud Member Of The Ohio Coal Rollers
wtfd6 is offline   Reply With Quote
Old 04-16-2006, 11:17 AM   #9 (permalink)
Guest
Guest
Posts: n/a
Even with the boost fooler it will Still defuel Hints EDGE COMP
The DRAG Comp adds the anti defueling advantage .,..
The ECM Defuels the VP44 by %'s above a certian RPM 2300 I belevae that means at 2350 it defuels 10% and at 2400 it defuels @ 20% so on and so forth ..
Add the ADD to the Edge Comp and you have an Edge Drag Box that is THE only diffrence
DM
Old 04-17-2006, 01:23 PM   #10 (permalink)
IC-Smoke's Avatar
It is what the name says "ADD" = "Anti-Defueling Device"
Ian
Old 04-17-2006, 01:58 PM   #11 (permalink)
Guest
Guest
Posts: n/a
IAn PM NOfullpullEL
AS hes running the Drag Comp and the ADD
See what he says
DM
Old 04-18-2006, 02:53 PM   #12 (permalink)
TNRIPNROR's Avatar
So if you run a ADD with a comp is it the same as a drag comp are is it better is they a differance??RIP
1998.5 2500 4x4 (53 Block)5 speed red club cab 20% tint,cb radio,Blue LED dash light kit from CEPP, 2-10" fozgate subs,EDGE comp,JammerIII's,AMSOIL 4510 BHAF with AFE torque tube,Valair Inc. 450 hp ferimic clutch,Pryo,Boost,& 2 fuel press. guages in a dash pod,GDP Walbro 392 pump kit,DSS,AGR steering box,4.5" skyjacker lift,Thuren trackbar,37" Dirtgrips, hypertech tuner for spedo fix and codes, Lonestar front bumper, 4" open pipe into two 5" smokepoles in the process of reworking my suspension with 3" lift CSS springs DT profab arms custom mini leaf pack 4 blistein 5100's and custom traction bars and 35" tires then a bigger turbo and a Smarty after I get my house built...
[SIGPIC][/SIGPIC]
Proud to Support CUMMINS FORUM.com
TNRIPNROR is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
