Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Technical & Diagnostics
98.5-02 Technical & Diagnostics What is it, what does it do... Pretty much the learning center for the 98.5-2002 Dodge Diesel's.
Old 01-28-2009, 04:14 PM   #1 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Exclamation P1689 ERROR CODE - Cause of code Found!
Well gang...
Mopar1973Man is back out in his shop and found the cause of P1689 error codes.
P1689 - No Communication Between ECM and Injection Pump Module Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
A lot of us assume its the injection pump that causes this which in most cases could be. But I was doing a fuel pressure test (cranking). This requires to pull the fuel system relay out of the PDC box under the hood...
Lower left side labeled fuel pump...
When this relay is missing the VP44 doesn't energize nor pump fuel. It allows you to do the cranking test. But it also sets a P1689 and CEL light. So for all of you that have a P1689 error code present check your fuel pump relay first by trading with another relay!
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
Old 01-28-2009, 04:59 PM   #2 (permalink)
Super Moderator
rbmchief's Avatar
Thanks Mike, that would be awesome if that fixed my issue.
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin stanadyne. [url]
http://www.cumminsforum.com/forum/wyoming/
rbmchief is offline   Reply With Quote
Old 01-28-2009, 05:02 PM   #3 (permalink)
Super Moderator
rbmchief's Avatar
also moved this to the tech forums.
Old 01-31-2009, 12:11 AM   #4 (permalink)
Here is a quick video of the relay and the cranking test for your lift pump that does produce the P1689 error code...
YouTube - P1689 Error code found & Testing Cranking pressure
