Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Repairs/Replacements
98.5-02 Repairs/Replacements This section is for helping you know what to do when something breaks. How to replace things, repair them, etc...
Old 09-30-2008, 06:40 PM   #1 (permalink)
SandBoy98's Avatar
no speedo...abs/brake light on!
speedo doesnt work and both abs and brake dash lights are on...put a new speed sensor on the rear end, nothing...any suggestions? maybe the abs module thats mounted under the hood? any ideas? thanks
98.5 24v 4x4,smarty,edge comp,4" TB exhaust with straight pipe and 6" tip,afe stg1 intake,2" leveling kit,stock chevy rear blocks,33x13.50x18 mtz's,newer style towing mirrors,18x9 KMC Badlands,FASS 150
SandBoy98 is offline   Reply With Quote
Old 09-30-2008, 08:49 PM   #2 (permalink)
totalloser's Avatar
The sensor on the rear end is not the speedometer sensor. It is an ABS sensor. The Speed sensor is on the side of the transfer case towards the rear. I would look at the wires/plug first. I would take a look at your brake fluid just in case it is a coincidence. Better safe than sorry, though it is most likely from a bad speedometer circuit.
01 24v 100hp tips, 4"ss BDbrake &steering brace PSCpump 1.5"dom steering tapped box 1.5"ram manual CAD switch dual carters 3.55's LSD, big shaft nv5600/241HD 6 35's inners pulled in (no spacer) Ugly black and thrashed!
totalloser is offline   Reply With Quote
Old 09-30-2008, 11:03 PM   #3 (permalink)
Tech Specialist
check the wire that runs along the differential. found one before that had been hit hard with a rock and busted the wire inside the conduit. good luck
Ramtech is offline   Reply With Quote
Old 10-01-2008, 05:25 AM   #4 (permalink)
SandBoy98's Avatar
alright thanks for the info guys...ill take a look at it tomorrow...i checked the brake fluid not to long ago and i know it has enough...what do you mean by checking it?
