Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Repairs/Replacements
98.5-02 Repairs/Replacements This section is for helping you know what to do when something breaks. How to replace things, repair them, etc...
Old 06-07-2008, 07:06 PM   #1 (permalink)
MAX340's Avatar
Pics of Dashboard Removal
NOTE: The images are hosted on photobucket. If you access this thread and find no pics, feel free to PM me and I'll send you the pics. Also, if I do this again, I'll get pics of the actual HVAC box disassembly and reassembly.
The pics have details written on them, but I'll try to add in text below if there is further info to pass on.
Better detail of the bracket is below
Both visible bolts must be removed, and have matching twins on the other side. The braket is a bit goofy to get in and out, be careful and patient.
Take careful note that the color of the info is referring to the same color letters on the pic.
Ok, "simply lifts out" means, rotate the top toward the rear of the truck, and with a buddy to help, lift the bottom off the two bolts on the kick panels. It helps to have the seats all the way back, and reclined a bit. Then, after you have it in mid air, go out the passenger side, allowing the dash to sit on the seat, and run around to assist your buddy.
Just under the trans dipstick, you can see a vacuum line. There is a connector here, and you must be VERY careful that the line comes back through the firewall with the evap core ends. If it doesn't, go back and start over, because that line makes it all work.
Max
2000 Ram 2500 QC ISB 47RE 4x4 LWB 3.55 ratio
MAX340 is offline   Reply With Quote
Old 06-07-2008, 07:18 PM   #2 (permalink)
West Virginia Chapter President.
Chris Mallett's Avatar
Nice write up, BUT where is your VIN # plate? Second picture from the bottom.
FOR SALE! $8000.0099 QC LB 4x4 CTD Auto, Suncoast Converter, Dunrite VB W/TC lock, 4" Silverline Turbo-back, BHAF, 315's 3.55's, 2" leveling kit, RV275's, Superchips for speedo, Airdog 150, Power windows/locks/mirrors w/heat, keyless entry, . 2005 Dually in the works...
Chris Mallett is offline   Reply With Quote
Old 06-07-2008, 07:41 PM   #3 (permalink)
MAX340's Avatar
Interesting, I'm pretty sure its on the truck.....Got me curious.....
A brief look shows that the VIN tag is riveted to the firewall, just below where the dash bolts to it. If you look at the VIN tag, on your truck, you'll see the edge of the dash cover just above it. The VIN tag stays in the truck when you disassemble it.
Max
Old 06-07-2008, 07:50 PM   #4 (permalink)
choupique108's Avatar
what is the purpose of doing this
2003 2500 SWB 2wd, Leveled, Smarty Jr., Cool Tube, Silencer Ring & Heater Grid MIA, Train Horns, Magnaflow Muffler, Blue LED Dash and Floor Lights, Recon Big Rig Lights, Prodigy. Power Puck, Gauges, & billet soon to come.
choupique108 is offline   Reply With Quote
Old 06-07-2008, 07:55 PM   #5 (permalink)
mfro00's Avatar
well i found this very helpful as im changing my dash tommrow the old one was very cracked and weathered. great post!
2001 2500 QC SB AT 4X4, 2'' level, Silencer Ring MIA, Muffler MIA, Aridog 100, new vp, Adrenaline w/ Pulse, smoke switch.
mfro00 is offline   Reply With Quote
Old 06-07-2008, 07:58 PM   #6 (permalink)
T-BONE
SouthernCummins's Avatar
To replace a crack up dash....that Dodge is pretty known for. I've heard that if you put Vasaline on your dash instead of Armor all that it will last longer. I've put it on mine a few times...
Tanners' Ride->2006 Dodge 3500, 4x4, Lonestar Edition, 5.9L Cummins, 6 Spd w/ South Bend DD, SMARTY, Volant CAI, AFE Bladerunner, 5" TB, 7" BullHaulers, 3 DiPricols, 4 Train Horns, 2.5" Leveling Kit, BD Cool Down Timer, Connex 3300 CB, Chrome Truck Nutz! Lots of lil' extras AIRDOG IS NEXT! http://www.myspace.com/tanner_bone Thanks you Wally @ FTE Diesel FTEDiesel.com
SouthernCummins is online now   Reply With Quote
Old 06-08-2008, 04:40 AM   #7 (permalink)
Administrator
Graphic Man's Avatar
i am going to move the thread to the Tech section .....nice write up and pics
Scott
2001 4X4 Q-cab Sport black, full billet DTT trans, billet F-plate Mach 7's, B1-B2 twins, Blue Chip Special X VP, Adrenaline, studded & O-ringed, BD-RAD,Flex-A-Lite electric fans, Autometer Gages, Egt, Boost,Fuel, Oil &,drive pressure, trans temp, RASP, Big line kit, Track bars 2" leveling kit, 271 T-case, DSS, 3rd gen trac bar 623 HP 1175tq with old set-up
Graphic Man is offline   Reply With Quote
Old 06-24-2008, 05:54 PM   #8 (permalink)
Moderator
pro99's Avatar
It looks like he's doing the A/C evap to me because you don't have to undo the water lines to replace a dash
When I do a evap I just swing the passengers side dash over to rest on the passengers seat. It's faster to me and you don't need a second person
Charles Estep
pro99 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
