Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Repairs/Replacements
98.5-02 Repairs/Replacements This section is for helping you know what to do when something breaks. How to replace things, repair them, etc...
Old 04-19-2006, 02:56 PM   #1 (permalink)
Tech Specialist
Front wheel bearing removal the easy way
I don't know if this has been mentioned here yet but it's worth covering again. I am doing ball joints on my '99 and this truck has the rotors behind the hub. Not easy to remove. Unless you use this trick: back the four hub bolts out .5 inch, use a deep 1/2 drive 9/16 with a 1" extension, place the socket and extension on a hub bolt and start the truck and crank the wheel. The hub, rotor and everything falls right out. You may have to move from front to back once or twice but it sure beats breaking the old rotor off with a sledge hammer.(Don't ask me how I know)
1999 2500 TST Competition, 275 Injectors. Mcloed Twin Disc, 3.54 LS. Silencer ring MIA, Jake since new, boost and pyro on the A pillar.
6 Speed Synchro-Muncher (NV5600) :fist:
DieselDave99 is offline   Reply With Quote
Old 04-19-2006, 04:13 PM   #2 (permalink)
Illinois Chapter President
Headhunter's Avatar
timing is of the essence! I'll be replacing that assembly tomorrow night!
thanks DieselDave!
Illinois Cummins Crew President Illinois Chapter Forum
2007.5 Ram 3500 6X4X4 DUALLY, 68RFE, Laramie H Pack, Line-X, Luverne Running boards, Front & rear Sunglasses! 6.7L of fun! Sunroof, Auto pilot
Ole Whitey has moved to Texas!
Headhunter is offline   Reply With Quote
Old 04-19-2006, 04:34 PM   #3 (permalink)
Tech Specialist
Headhunter your truck may have the rotors on the outside of the hub assembly, which is a little easier. However this trick worked like a charm. Good luck.
Old 04-19-2006, 04:37 PM   #4 (permalink)
Headhunter's Avatar
ya know now that I think about it.... I think you are right!.... maybe... hell I don't remember> I'll let ya know after I'm done!.... if the trick won't work... we've got a sledge hammer or 2, a lil guy, and a man killer!
Old 04-19-2006, 09:07 PM   #5 (permalink)
Moderator
You mean like this?
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Not stock
Old 04-19-2006, 09:16 PM   #6 (permalink)
Tech Specialist
Yeah that should do it. I used a deep socket and 1" extension, about half the length of that setup, but whatever will fit seems to do it. I figured this wasn't new but is so valuable I didn't want to keep it a secret if it wasn't common knowledge. My socket hit on the casting on the end of the axle. This really takes the pain out of this job. I just wish that there was an easier way to do the ball joints. One side done, the other one I'll do tomorrow!
Old 04-19-2006, 10:44 PM   #7 (permalink)
Guest
Posts: n/a
Excellent info Dave ..thanks for sharing :thumbsup
Old 04-24-2006, 07:53 PM   #8 (permalink)
BSouth's Avatar
Man this would have been helpful a while back!!!!! took me 3 hours to beat my passanger side off, believe me it was a pain!!! 200,000 miles and the hub assembly/rotors had never been off the truck. Owners before me sucked!
05 3500 Yellow 6 speed,Mega cab dually fenders,Rumble Bee Scoop,Edge Juice w/A2,Edge EZ,Smarty,CFM+,ATS Exhaust Mani,Silver 64,90's,Airdog 150,Valair 3600 DD,5" Silverline exhaust,8" tip,Icebox with torque tube,Quad Rail Gauge,Mag-Hytecs,Lorenz Level, 22.5's
BSouth is offline   Reply With Quote
Old 04-25-2006, 09:25 AM   #9 (permalink)
Headhunter's Avatar
got 'er done in about an hour and a half.... had to go and get a 3/4 inch socket set from a buddy! other than that it was painless!
Old 04-29-2006, 09:19 AM   #10 (permalink)
just taking up space
Babyfat's Avatar
Anyone Know What Size The Axle Nut Is ? So I Don't Have To Take All My Big Sockets Home From Work
John
(her's)2000 drw, quadcab lb, hx40/ht4c twins,180's, dtt, edge comp, tst pm3, fuelboss, 6" miters
(mine)2006 drw, quad cab lb, handshaker, 6" miters, smarty jr
(sons)1997 quad cab, 5 sp, longbox, stock
(shop)2004.5 quad cab, sb, stock www.dakins.com
Babyfat is offline   Reply With Quote
Old 04-30-2006, 05:50 PM   #11 (permalink)
Super Administrator
BBRam's Avatar
Thank's for the imfo. We tangled with one this weekend. The socket and ext. worked awsome. We used a slightly larger socket and a 1" ext. so we were able to push against the axle housing instead of the brackets, but the pic. helped get the idea across.THANK'S AGAIN!!!
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 05-03-2006, 04:46 PM   #12 (permalink)
Jakey's'01H.O.'s Avatar
1 and three quarter inch
'01 ETH/SO VP.
[HOLLAND COURT DIESEL PERFORMANCE. COALTRAIN IS THE SH$T
Jakey's'01H.O. is offline   Reply With Quote
