Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 98.5-02 Tech Articles > 98.5-02 Repairs/Replacements
98.5-02 Repairs/Replacements This section is for helping you know what to do when something breaks. How to replace things, repair them, etc...
Old 01-14-2006, 09:02 AM   #1 (permalink)
Guest
Posts: n/a
*Valve Cover Replacement - L
Valve Cover Replacement by
The only tools you’ll need is a ¼ inch drive ratchet and a 10 MM socket
Coolness factor is high on this one
Old 01-16-2006, 09:01 PM   #2 (permalink)
Guest
Posts: n/a
Not just for looks there a major sound insullation benifit also it weight about 4 times the OEM
DM
Old 02-13-2006, 11:54 PM   #3 (permalink)
Jakey's'01H.O.'s Avatar
DM
???? after being powdercoated it got a bit quieter?? or heavier? i like your blue, how would i go about doing it, not many guys powdercoat around here
'01 ETH/SO VP.
[HOLLAND COURT DIESEL PERFORMANCE. COALTRAIN IS THE SH$T
Jakey's'01H.O. is offline   Reply With Quote
Old 02-14-2006, 10:28 AM   #4 (permalink)
Guest
Posts: n/a
ITs about 3 times the weight as the stopcker ...wayyyyy heavier..
It comes powercoated from schieds
DM
Old 02-24-2006, 01:32 PM   #5 (permalink)
2500ctd's Avatar
Is that the same style that Bob Wagner sells?
2500ctd is offline   Reply With Quote
Old 02-24-2006, 01:41 PM   #6 (permalink)
Guest
Posts: n/a
Yes it is
DM
Old 02-28-2006, 03:13 AM   #7 (permalink)
Keyser Söze
Just FYI to anyone with a factory silver rocker cover ('98.5, '99, some '00 MY) the attaching bolts for it have 15mm heads, but they'll work fine on the newer cover. :thumbsup
Mes chers frères, n'oubliez jamais, quand vous entendrez vanter le progrès des lumières, que la plus belle des ruses du diable est de vous persuader qu'il n'existe pas!
And like that, he's gone...
Radio Flyer is offline   Reply With Quote
Old 03-03-2006, 03:48 PM   #8 (permalink)
yes...15mm on mine too... blue valve cover here!! from
Bob Wagner
Cepp is offline   Reply With Quote
Old 03-05-2006, 08:44 PM   #9 (permalink)
2500ctd's Avatar
Bob Wagner
If you dont mind, what did it run you. U can pm me too. I'm thinking of one but havent decided the color yet.
Old 03-08-2007, 10:15 AM   #10 (permalink)
Slow Cummins
Boosted's Avatar
Anyone have a stock valve cover they want to get rid of? I have a friend here in town that owns a powdercoating shop and would like to get one custom done.. I just don't want to take mine off and be without it for a week...
96 Club Cab 2wd 7.3
450RWHP 870TQ
NHDRA #4495
Boosted is offline   Reply With Quote
Old 03-08-2007, 10:23 AM   #11 (permalink)
man this site is costing me alot of
2001 ram 2500 QC, LB, 4x4, auto, 3 inch susp lift, 285/75r16 bridgestone dualer a/t revo`s mounted on 16x8 mickey thompson classic 2 rims, 4.10 gears, dual 4in straight pipe exhaust w/ 5inch tail pipes, edge EZ stacked w/ blue chip FMS, hot rod VP44 injection pump, holley black FP, AFE stage 1, turnbuckle on wastegate, silence ring MIA, triple pillar isspro gauges boots,egt,FP, goerend triple disc converter and valve body.......
aredcrow is offline   Reply With Quote
