P1693 - Dodge Cummins Diesel Forum
post #1 of 58 (permalink) Old 11-17-2008, 10:27 PM Thread Starter
side2000's Avatar
P1693
so. . .i have dead spots when i'm rippin. my fuel press stays at 11 or above, my inj pump is the freshest thing on my motor, i just installed ddp110's, and i'm throwin p1693-with no other codes that could be related to the power loss. truck seemed to be fine for the first couple hund miles after injector installation and i was rippin the whole time.
now from what i understand a scantool will read the code that is settin off the 1693--cuz there has to be another code right?
'02HO w/ SO pump (tapped), nv56, 3.55's, ddp 110's, 42psi, everything ported, studded, a 5 inch w/ all the other nonsense. 285's. 270k.
if its cheap it's not easy, if its easy it's not cheap
side2000 is offline
post #2 of 58 (permalink) Old 11-17-2008, 10:39 PM Thread Starter
side2000's Avatar
buuuuuuuuuuuump
side2000 is offline
post #3 of 58 (permalink) Old 11-17-2008, 11:17 PM
Not like the others......
dieseltracks's Avatar
1693 is not a problem. It's called a "companion code". It just means that there was also a code present in the ECM. Whenever your truck throws a code, the P1693 companion code will show up also.
If you're CEL has come on, then you very well may have a code set of some sort, otherwise, just clear the 1693 code and all should be good.
04 3500 Quad Cab
dieseltracks is offline
post #4 of 58 (permalink) Old 11-17-2008, 11:18 PM
What do you mean......dead spots???
04 3500 Quad Cab
post #5 of 58 (permalink) Old 11-17-2008, 11:20 PM
TylerG's Avatar
P1693 DTC Detected in Campanion JTEC mod Try and google this.
TylerG is offline
post #6 of 58 (permalink) Old 11-17-2008, 11:24 PM
No need to google it..........It means that there is/was another code set in the ECM.
04 3500 Quad Cab
post #7 of 58 (permalink) Old 11-17-2008, 11:27 PM Thread Starter
side2000's Avatar
when i'm rippin it literally defuels for a sec, stutters almost. my turbo even "blows off" sometimes with my foot to the floor (when it gets that bad).
i know it's a companion code, my question is where the hell is the other code? that's the only code im throwin. i assume i need a scantool to read the other one since my truck's not noticin it?
side2000 is offline
post #8 of 58 (permalink) Old 11-17-2008, 11:29 PM Thread Starter
side2000's Avatar
oh and CEL never came on.
side2000 is offline
post #9 of 58 (permalink) Old 11-17-2008, 11:32 PM
Sorry, I misunderstood your ?.
Are you using the key trick to get the 1693 code?? and that's the only code it shows by doing that??
I'm wondering if you're not coming up against the factory rev limiter. Alot of the Adrenaline guys were/are having that same problem.
At what RPM does the stumble occur??
04 3500 Quad Cab
post #10 of 58 (permalink) Old 11-17-2008, 11:35 PM
CUMMINS-POWERED's Avatar
or it could be a bad apps sensor couldnt it?
CUMMINS-POWERED is offline
post #11 of 58 (permalink) Old 11-17-2008, 11:40 PM Thread Starter
side2000's Avatar
generally, it's most prevalent when i start rippin at lower rpm, but it could just be the increased amount of time it has to stutter. my first instinct was IP, but i am almost certain it is not rev limiter cuz it happens when i start rippin at any rpm. like i said it really didnt happen at first. and it makes damn good power when it's not happening.
oh and yes im using key trick
side2000 is offline
post #12 of 58 (permalink) Old 11-18-2008, 01:24 AM Thread Starter
side2000's Avatar
ok ill ask a different question: if my vp was failing, would i definately get the death code? i would say because of how hard it's been buckin' that whatever is wrong would throw a code. . . .
side2000 is offline
