P1694 code ? - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 08-26-2008, 11:33 PM Thread Starter
P1694 code ?
i am getting two different answers for this code
P1694- No bus message recieved from ECM module
P1694- Turbo Charge relief circuit malfuction
the second one does not sound right but what do you guys come up with?
02 QC SB 5-speed, BHAF, Hypertech PPIII, DDP 75HP sticks, Airdog 100, Diprocol EGT,Boost, FP, MaxSpool 2.5 cam, silencer ring and muffler MIA
dirtrider828 is offline
post #2 of 17 (permalink) Old 08-26-2008, 11:42 PM
Steveo24's Avatar
p01694- No ccd message from ecm. I believe that I pulled this code once, and it was a blown fuse in the underhood panel.
98.5 3500 2WD dually, 4:10's, Full Auto Meter, 5" Bullhaulers, Byrds Intake,3.3 whipple/ 63/ 480, HRVP, GHD, Studded and Ringed, 6x.018, .093 tubes, Stage 2 snow, Air Dog 165, Georend trans, VP intercooler boots
Steveo24 is offline
The Following User Says Thank You to Steveo24 For This Useful Post:
TheSaundo (09-23-2012)
post #3 of 17 (permalink) Old 08-26-2008, 11:44 PM Thread Starter
did it start and seem to run fine?
post #4 of 17 (permalink) Old 08-26-2008, 11:46 PM
Steveo24's Avatar
No, I had to run a toggle switch to the lift pump to get it to run. It was one of the bigger fuses in the panel, one of the ones you look down through the top, and under observation it looked to be ok, but when pulled out of the panel and shaken, it was blown.
Steveo24 is offline
post #5 of 17 (permalink) Old 08-26-2008, 11:54 PM Thread Starter
ok i cleared it and it seemed to run fine will see how it runs tommorow and if it pops up again thanks
post #6 of 17 (permalink) Old 01-25-2010, 05:18 PM
p1694
I'm getting this same code. Truck starts fine but I think its running in gimp mode. I'll clear it and it comes right back. Anybody have any ideas. None of the fuses appear to be blown.
mverno3 is offline
post #7 of 17 (permalink) Old 02-18-2010, 07:27 PM
Smourj21's Avatar
iTrader Score: 4 reviews
bump???????
02 QCSB 6 Speed|215 P-Pump 600cc 28*|64/S480|SAC 7x12|131 DVs|AD150|Colt 181|HD Push Rods & Springs|ARP/O-Ringed Head|Fluidampr|Valair Tripple Disk|.084 Lines/Tubes|Tunnel Ram|CFM+|Water/Meth|6"Miter|Dana60/80|4.88|True Trac|35" Toyo MT's|
Smourj21 is offline
post #8 of 17 (permalink) Old 08-07-2010, 04:55 PM
dieselfury's Avatar
bump...........
2011 F350 6.7 2005 VW TDI with sunroof 51mpg 02 4x4 auto quad 4K Box,air dog 150, super b special, bd rad, full billet tranny, 200hp injectors, midwest vp pump<<<Sold.... 01 5sp pulse/adrenaline, airdog 150,valair, 150's FBD,leveled...Sold
dieselfury is offline
post #9 of 17 (permalink) Old 09-28-2010, 10:08 PM
just pulled that code but truck seems to run perfect???
2002 dodge 2500 4x4 LBQC, 6 speed, silencer ring mia, smarty so3, big line kit, fuel press, egt and boost guages, south bend clutch o, BHAF, Raptor 100, 4in. MBRP, 3rd gen. wheels, BG track bar, High idle fooler. cpp 100hp sac injectors
trwill is offline
post #10 of 17 (permalink) Old 10-04-2010, 09:03 PM
ShortyDull's Avatar
Same things just happened to mine, all gauges dead, runs great otherwise, please help, i checked all fuses,connections,new batteries, im lost please help 8602370809
2006 Dodge 2500 Mega Cab 4x4 -100hp Industrial injectors,smarty,s & b intake manifold, s & b cold air intake,4inch mbrp turbo back exhaust,fass titanium 150gph lift pump,mike smiths built transmission , 3 inch ready lift lift. 34x12.50x17 Nitto Terra grapplers.
ShortyDull is offline
post #11 of 17 (permalink) Old 10-04-2010, 09:57 PM
My guages still work but the tack does move up and down when at idle but it is only a 25rpm swath. Ive kind of decided to ignore the code since I cant find anything about it and truck runs fine.
trwill is offline
post #12 of 17 (permalink) Old 10-05-2010, 12:47 AM
NorCal Cummins's Avatar
I've got that code too... no problems though, truck runs great (never run better before actually)... Not sure what to do about it haha
02 2500 Auto 4x4 QCLB, Built Goerend, 64mm , DAP 7x0.12, AFE,Custom Byrds intake, PDI Exhaust Manifold, 4" Turbo back, FASS Titanium 95GPH, EDGE Juice w/Attitude HOT unlock, Carli's. Thanks Diesel Auto Power!
NorCal Cummins is offline
